Musings on SOARING cover photos
Old March 5th 05, 08:39 PM
RichardFreytag
Bo Brunsgaard wrote:
btw that photo is he
http://soaring.aerobatics.ws/Soaring...84Mar_full.jpg
It's a Rutan Solitaire, unless I'm very much mistaken.
Self-launcher with an interesting engine installation concept. The
engine is placed in the fuselage in front of the pilot rather than in
the rear fuselage.
I seem to recall that one of them was built here in Denmark in the
late 1980's or early 90's, either from a kit or bottom-up from
drawings. I think it was sold out of the country a few years later.
Bo Brunsgaard
I communicated back in the late 1980s with a US gentleman that was
selling a Rutan Solitaire homebuilt you see in the picture (email
lost). He indicated some concern about his Rutan Solitaire being
tricky for an inexperienced pilot. Apparently the canard was designed
to stall first causing a nose pitch down - as you would expect. Except
that the transition could be abrupt and in the landing flare this would
put your nose abruptly in contact with the pavement.
Perhaps this thread will get forwarded to said owner and he'll fill in
the details.
Best,
Richard
RichardFreytag
the rear fuselage.
Bo Brunsgaard
the details.
Best,
Richard
Old March 5th 05, 09:42 PM
F.L. Whiteley
"RichardFreytag" wrote in message
the rear fuselage.
Bo Brunsgaard
the details.
Best,
Richard
Kind of defeats the purpose of having a canard. Perhaps it was built wrong.
Frank Whiteley
Old March 5th 05, 11:47 PM
Andreas Maurer
On Sat, 5 Mar 2005 13:42:15 -0700, "F.L. Whiteley"
I think this is exactly how a canard plane is supposed to work: Canard
stalls first, nose goes down, aircraft picks up speed again. AoA of
main wing always stays within the safe range, aileron always stays
effective, no wing drop.
Bye
Andreas
Old March 6th 05, 07:35 AM
F.L. Whiteley
"Andreas Maurer" wrote in message
wrong.
Bye
Andreas
Yes, you are right. Long time since I last thought of canards.
Frank
Old March 6th 05, 06:50 PM
Andy Blackburn
to work: Canard
again. AoA of
always stays
Bye
Andreas
of canards.
Frank
Of course this is also the basic problem with canards.
Because you want the canard always to stall first the
main wing can never reach max Cl, the minimum flying
speeds for the overall aircraft are high and the climb
performance suffers. If you enforce dynamic stability
(canard loses lift first even when pitching up) - it
gets even worse. Of course having the whole contraption
pitch UP at stall is worst of all.
Canard designs often are touted as 'stall-proof'. This
might be technically true, but it is a pointless argument
if the canard has a sharp break at stall leading to
a sharp nose drop.
Perhaps it's a coincidence, but I haven't seen Burt
Rutan produce a new canard-configured design in quite
a while.
9B
Old March 7th 05, 06:28 AM
Bruce Hoult
a while.
Hmm. The last few have been conventional (SS1/WhiteKnight/GlobalFlyer)
but the starship, proteus and boomerang are all canard. As are the UAVs
I think.
Bruce | 41.1670S | \ spoken | -+-
Hoult | 174.8263E | /\ here. | ----------O----------
Old March 7th 05, 05:47 PM
Mark James Boyd
This is the big lie behind canards. Of course they
stall. After the mains touch down, holding the nose up
with the front canard until it stalls makes a good
bang onto the nose gear. If the C.G. is far enough aft,
you can stall both wings in flight. And inverted, all bets are off.
The Speed Canard is a certified aircraft in Europe.
Although the "stall" speed (really maximum
"sink" speed) is below 60 knots, we used to fly it on
at 80 and do a wheel landing and lower the nose before
the forward canard stalled.
We had to use 3000ft runways or longer for this, and
even that was edgy.
It was fun for a little while, until I realized that an
off-field landing would be, gulp, interesting. I'm
NOT a fan of high stall (or max "sink") speeds.
The interesting thing about a canard glider, however, is
that the weight to span ratio means something different because of
two wings. Maybe a good way to get out of using this
ratio for experimentals?
I suspect that if the 32:1 ratio I saw for the Solitaire is correct,
the forward canard was a "stall all at once" design,
so keeping the nose unscarred must have been "interesting."
In article . com,
roups.com...
the rear fuselage.
Bo Brunsgaard
the details.
Best,
Richard
Mark J. Boyd
Old March 7th 05, 05:55 PM
Mark James Boyd
Does it surprise you that a forward wing built for high
performance also has an abrupt stall? It wouldn't surprise me.
I do wonder how yaw control was done. For the Speed Canard, it was wingtip
"airbrakes" so you just slowed down one or the other.
If you hit both, it worked to just slow down.
Frank Whiteley
Mark J. Boyd
Old March 8th 05, 03:30 AM
Andy Blackburn
lyer)
As are the UAVs
I think.
Starship was more than 20 years ago - not sure about
the others.
Certainly the argument that canards are more efficient
or inherently safer has been debunked by now. The Starship
was barely faster than a King Air, burned more fuel
and had a smaller cabin. It was also significantly
more expensive to produce -- however, it did look cool.
You may have noticed that Beech has quietly been buying
them back and grinding them up.
9B
Best. Soaring. Cover. Ever. [email protected] Soaring 9 March 5th 05 06:57 PM
Possible future legal problems with "SOARING" Bob Thompson Soaring 3 September 26th 04 12:48 PM
ADV: June SOARING cover, quiet spreads (USA) David Campbell Soaring 1 June 10th 04 03:03 AM
Lastest "Soaring" cover. Pete Reinhart Soaring 5 February 29th 04 12:01 AM
'SOARING' Oct. Cover Photo Ray Lovinggood Soaring 1 October 5th 03 04:00 AM
