prop test engine- cheap
Old March 7th 05, 04:28 AM
Default prop test engine- cheap
What have folks found to be the cheapest engine to swing a prop for
function and reliability testing? Needs about 100 hp at 2500rpm with
maybe a little extra up to 2800rpm. I would rather not go direct drive
if I can help it but that might be the cheapest way.
I thought about jacking my truck up and using a shaft off of the
driveline in some sort of big steel fixture. Now that would be
interesting. Heck, I could make a barge for my truck and "drive" it
around the lake like a big airboat
Seriously though, what's the cheapest option out there?
Joa
Old March 7th 05, 04:36 AM
MikeR
Joa
How about a junkyard motor?
Old March 7th 05, 08:18 AM
Jan Carlsson
If you want to test a prop, for reliability, you must test it with that sort
of engine it is supposed to be on, for vibration reasons.
Jan Carlsson
www.jcpropellerdesign.com
skrev i meddelandet
Joa
Old March 8th 05, 07:27 PM
Yes, it will definitely get tested later on the correct engine. I want
to do an initial run to veryify a few things first though.
What 100hp junk-yard engine could be readily adapted to a prop but not
have nasty torsional issues?
Joa
that sort
Jan Carlsson
Flight Test RealAir Griffon Spitfire Dudley Henriques Simulators 1 December 4th 04 12:46 PM
ROP masking of engine problems Roger Long Owning 4 September 27th 04 08:36 PM
New test aircraft engine forum. R Lundahl Home Built 0 September 23rd 04 06:23 PM
Engines and Reliability Dylan Smith Piloting 13 June 30th 04 04:27 PM
What if the germans... Charles Gray Military Aviation 119 January 27th 04 12:20 AM
