Clearance with an Odd Intersection
Old March 10th 05, 06:50 PM
Jose
...but if you cannot accept any revised clearance your only
alternative is to cancel IFR.
No, my other alternative is to fly the clearance I already have.
But the point isn't that I can't accept =any= revised clearance (at
all), but rather, that I can't accept =any= (arbitrary) revised
clearance. You can't create capabilities in my aircraft by talking on
the radio, and you can't assume that any IFR aircraft is capable of
magic either.
If the original clearance was an option there never would have been a
reroute.
The original clearance was an option when it was given to me. It
remains an option throughout my flight. It is ATC's job to ensure that
it remains an option. ATC may, with the pilot's cooperation negotiate a
reroute. Usually this is done unilaterally with no problem. But ATC's
failure to ensure that my clearance remains viable does not impose upon
me an obligation to endanger myself (such as by climbing to an icing
altitude and/or flying sixty miles offshore).
ATC: Amend altitude, climb maintain niner thousand
Me: Unable due to ice.
ATC: Ok, I'll cancel IFR for you.
Me: Negative, we're IMC.
ATC: Well, you're no longer IFR, so you're in violation. I'll pull the
tapes and have an inspector waiting when you arrive.
Jose
Math is a game. The object of the game is to figure out the rules.
  #82
Old March 10th 05, 07:36 PM
Roy Smith
**** happens. Weather changes. Navaids fail. Traffic doesn't flow
as originally expected. Airports or runways close down. You need to
accept the possibility that your original clearance may no longer be
available.
Insisting that you MUST be able to continue as originally cleared is
as silly as insisting that a pilot MUST accept any altered clearance.
  #83
Old March 10th 05, 08:38 PM
Jose
**** happens. [...] You need to accept the possibility
that your original clearance may no longer be available.
True. My issue is "your only alternative is to accept the new clearance
or cancel IFR", and "You've accepted the clearance just by reading it back."
Jose
  #84
Old March 10th 05, 10:31 PM
jsmith
No it isn't. You can negotiate an alternate routing.
Steven P. McNicoll wrote:
Correct, but if you cannot accept any revised clearance your only
  #85
Old March 10th 05, 10:46 PM
Steven P. McNicoll
"jsmith" wrote in message
An alternate routing would require a revised clearance.
  #86
Old March 10th 05, 11:30 PM
Jose
You can also negotiate to keep your original clearance (done that too).
But you are in a better position to do so if you have not =accepted= a
clearance merely by confirming that you correctly understand ATC's
request. And you can't do any of that NORDO.
Jose
  #87
Old March 11th 05, 12:53 AM
Doug Carter
back."
So if you "accept" a clearance and then figure out you don't like it,
what happens when you try and change it? Does, in real life, ATC refuse
your request to change or do they really insist that you, for example,
climb into known icing conditions in your uncertified airplane?
In other words, is ATC really mean and uncaring? Never happened to me,
but my experience is limited; every time I've asked ATC to help me fix
something, regardless of whos screwup, they have been reasonable.
  #88
Old March 11th 05, 01:33 AM
John Clonts
"Jose" wrote in message . com...
ATC gives you a clearance and you read it back. You have accepted it.
OK, so how do I acknowledge that I have heard and understood (correctly) the clearance you have given me, but
am NOT accepting it until I can verify that it won't take me sixty miles out over the ocean?
It seems to me that this would be a perfect place to use the distinction between "Roger" and "Roger, Wilco",
but I lament that it's never used that way!
Cheers,
John Clonts
Temple, Texas
N7NZ
  #89
Old March 11th 05, 02:21 AM
Charlie Derk
Typically, if you file your IFR flight plan with /G, I think ATC assumes
that its an IFR Certified GPS and that the intersection is in the
database. I've gotten something like this before, but it was enroute
and ATC asked me if I could identify the intersection. After I
acknowledged that I could, ATC told me "Direct to" that intersection.
Regards,
Charlie
Marco Leon wrote:
Has anyone received a route clearance that included an intersection that was
only on an approach chart and not in an Enroute Chart?
Flew IFR from FRG to GON with the following clearance: Farmingdale Three,
radar vectors BDR, direct MAD, MAD 126 radial to MONDI, direct.
For the life of me I couldn't find MONDI on the enroute. However, it was in
my (up-to-date) Garmin 430 database and it was pretty much on the way
(albeit a bit of a dogleg) so I didn't make it an issue. Turns out MONDI is
only on the KGON ILS RWY 5 and it's not even an IAF. The GPS RWY 33 was the
active approach which made it even more difficult to figure out.
Is this commom anywhere else? Should they have told me it was only on an
IAP chart? Are all the fixes on any of a given airport's approach charts
fair-game to include in an enroute clearance?
Regards,
Marco Leon
  #90
Old March 11th 05, 02:23 AM
Steven P. McNicoll
"Charlie Derk" wrote in message
database.
Why would ATC assume anything else?
No SID in clearance, fly it anyway? Roy Smith Instrument Flight Rules 195 November 28th 05 11:06 PM
Clearance: Direct to airport with /U Judah Instrument Flight Rules 8 February 27th 04 07:02 PM
Q about lost comms on weird clearance Paul Tomblin Instrument Flight Rules 34 February 2nd 04 10:11 PM
Alternate Intersection Name in Brackets? Marco Leon Instrument Flight Rules 7 January 22nd 04 05:55 AM
Picking up a Clearance Airborne Brad Z Instrument Flight Rules 30 August 29th 03 02:31 AM
