quick disconnect hydraulic fitting
Old January 6th 05, 11:18 PM
Default quick disconnect hydraulic fitting
Anybody know of a quick disconnect hydraulic fitting that won't
introduce air in the system when it is disconnected and reconnected?
Something inline and sized for typical light aircraft brake lines?
Joa
Old January 6th 05, 11:38 PM
Wayne Lundberg
Go to Parker Hannifin and look there.
Joa
Old January 7th 05, 12:17 AM
williamhenry
you want flat face zero drip couplings , high dollar
Old January 7th 05, 12:19 AM
Blueskies
"Wayne Lundberg" wrote in message
Joa
All of them that I know of will introduce a little air when reconnected, even the 'zero leakage' ones....
Old January 7th 05, 04:45 AM
C.D.Damron
"Blueskies" wrote in message
om...
Yes, you would have to have multiple valves to be truly zero-leakage. Are
there such animals? Can somebody suggest a simpler setup than the setup I'm
thinking about? I would think that you would lose a bit of fluid while
bleeding, but avoid introducing air.
line-----shut-off/bleed valve------connector end--| |--connector
end-----shut-off/bleed valve-----line
Old January 7th 05, 05:26 AM
Drew Dalgleish
On Fri, 07 Jan 2005 03:45:04 GMT, "C.D.Damron"
. com...
If you install the fittings so the female one points up you could fill
it with oil before connecting then join them without getting any air
into the system. My question is why do you need this.
Old January 7th 05, 07:22 AM
Bogone
Boeing 747 quick change brake calipers?
Old January 7th 05, 03:41 PM
GeorgeB
I've read the suggestions, and agree with looking at the Parker units.
They have several which will be substantially zero leak. They have
diagnostic versions (look at the "PD" series) which are
double-shut-off. The female ends are heavy by my terminology. Take a
look here for more info.
http://www.parker.com/quickcouplings...ecF%20Diag.pdf
If your flows are as small as I expect, there is a great additional
option. I use diagnostic fittings extensively. The fitting is
substantially zero leak. The hose end IS NOT. The hoses normally
used have adequate pressure rating (9000-10000 psi), with an ID of
about 2mm.
In my work, I use the larger "1620" fitting because it is more
standard in industry. There is a smaller (and lighter) "1215" series.
Stauff, Schroeder, and Hydrotechnik are the 3 manufacturers I think of
first with the 1215 series; I prefer Hydac for my 1620, but they don't
do the 1215.
Of those in the 1215 market, I am most familiar with the Schroeder
catalog, and sell their products to my customers who have a need for
the 1215 stuff ... see
http://www.schroederindustries.com/pdf/Schroeder%20Check%20(L-2458).pdf
for more info.
ROUGH costs from Schroeder ... test points are around $12, hoses kinda
$25+$1/ft. The hoses are made to order, and you have to get $100
worth at a time. Testpoints are available singly, but freight charges
eat you up. Hose prices can go way down in the multiple quantity of
similar item situation.
THIS IS NOT AN OFFER TO SELL: THEY have local distribution everywhere
in the US. Their website lists distributors.
George (a hydraulics nut)
Old January 7th 05, 04:28 PM
C.D.Damron
How would you disconnect pressurized line?
If you can deal with a little bit of air, there are a number of options.
Straight restrictor fitting? nauga Home Built 5 April 15th 04 02:06 PM
Hydraulic CS prop converting to Adjustable prop? Scott VanderVeen Home Built 0 December 5th 03 06:54 PM
