Flight over densely populated areas
Old March 27th 05, 09:57 PM
JK
Default Flight over densely populated areas
I have been planning to build my own airplane for quite a while, but I have
a nagging question that I never see addressed. FAR Part 91.319 (c) appears
to prohibit flight of experimental aircraft over "densely populated areas"
(whatever that means).
The entire text is: "Unless otherwise authorized by the Administrator in
special operating limitations, no person may operate an aircraft that has an
experimental certificate over a densely populated area or in a congested
airway. The Administrator may issue special operating limitations for
particular aircraft to permit takeoffs and landings to be conducted over a
densely populated area or in a congested airway, in accordance with terms
and conditions specified in the authorization in the interest of safety in
air commerce."
How do the rest of you deal with this? Does the "Unless otherwise
authorized ..." part help somehow? Do you avoid densely populated areas?
Thanks
John
Old March 27th 05, 11:09 PM
Marc J. Zeitlin
JK asks:
..... Does the "Unless otherwise
Yup. The operating limitations you get when you get your airworthiness
certificate will allow you to fly anywhere you want (in essense, remove
the restriction) after you finish your 25 or 40 hour restricted Phase I
period.
....Do you avoid densely populated areas?
Nope. Don't have to.
Marc J. Zeitlin
http://marc.zeitlin.home.comcast.net/
http://www.cozybuilders.org/
Copyright (c) 2005
Old March 27th 05, 11:11 PM
Kyle Boatright
"JK" wrote in message
link.net...
appears
an
air commerce."
Thanks
John
This limitation is only in effect during "Phase 1" testing - the first 25 or
40 hours of flight. After that, your experimental can fly anywhere a
certified ship can.
Five years or more ago, the rule was as you quoted in your post, but it (or
the interpretation) has changed. Older homebuilts may still carry the
restriction in their operating limitations. However, the Feds will update
those "old" operating restrictions if the owner requests.
KB
Old March 28th 05, 12:09 AM
abripl
The typical newer operating limitations have two parts relating to
that.
(5) Except for takeoffs and landings, this aircraft may not be operated
over densely populated areas or in congested airways.
(6) This aircraft is prohibited from operating in congested airways or
over densely populated aras unless directed by Air Traffic Control, or
unless sufficient altitude is maintained to effect a safe emergency
landing in the event of a power unit failure, without hazard to persons
or property on the surface.
It still has a statement relating to such flights but it really affords
a way out. (5) allows you to go into/outoff airports. (6) allows you to
go over any densely populated area if directed by ATC (all you need is
flight following, or permit to transgress the airspace (normal for any
GA)) and it allows you to go over the area if you are high enough with
gliding distance to a "safe landing". With a gliding ratio of 10 you
should be able to glide to a non populated area if you are at 10K feet
easily in most cases.
Some limitations place (5) into phase one only. But think about it: (5)
allows to fly without ATC guidance into/outoff populated area airports.
Does anybody have operating limitations without either (5) or (6)?
I have
appears
areas"
in
has an
congested
over a
terms
safety in
air commerce."
areas?
Thanks
John
Old March 28th 05, 05:50 PM
L.D.
that.
I have
appears
areas"
in
has an
congested
over a
terms
safety in
air commerce."
areas?
Thanks
John
About 10 years ago I got my hands slapped for flying over a congested
area. I ask them what a congested area is. They said if more than 1
building was in a sq. mile, it is congested. I said show me in the regs
and they couldn't. When they said if I agree to a letter of instruction
in my records that would be removed in 2 years if no other violations of
this type occurred , I agreed to that.
Old March 28th 05, 07:46 PM
Montblack
(L.D. wrote)
Did they replace the Letter of Instruction in your file with a form stating
that a Letter of Instruction had been expunged from you records? g
BTW, you are now on double-secret-probation for not trimming your post :-)
Montblack
Old March 28th 05, 11:20 PM
abripl
Amazing that you even agreed. One building per sqare mile is hardly a
farm house per farm section. Don't count the barn. Thats crazy.
There is hardly any place you could fly in US with that definition.
regs
instruction
of
Old March 29th 05, 12:46 AM
Morgans
AND for not posting in plain text. That post showed up so big, I had to
scroll back and forth to read it, which I didn't. g
Jim in NC
Old March 29th 05, 02:55 AM
Montblack
("Morgans" wrote)
His post showed up in plain text on this end - and I will, from time to
time, get posts where I must scroll back and forth to read them - but his
looked 100% normal here.
I'm using Outllok Express 6.0 ...still (I gave up on T-bird for newsgroups.
I tried all of the suggestions. In the end I stuck with OE as my newsreader)
Montblack
Old March 29th 05, 03:27 AM
Morgans
"Montblack" wrote His post showed up
newsgroups.
newsreader)
Montblack
O.K., I'm puzzled. I also am using OE 6.0, and his font was about 2 times
the size of normal, on my end. Any ideas on what I am doing, or what
feature I am missing?
Jim in NC
Letter at end of flight number? Laura Piloting 1 December 17th 04 04:14 AM
new theory of flight released Sept 2004 Mark Oliver Aerobatics 1 October 5th 04 11:20 PM
Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP vvcd Piloting 0 September 22nd 04 08:13 PM
