Tach Generator Cessna 340
Old March 29th 05, 04:26 PM
Default Tach Generator Cessna 340
My RPM gauge does not show anything at startup on right engine. Then at
runup it comes to life at high RPM. Then after that it works fine. It
wobbles a bit sometimes in the air. My take is that my tach generator
is the problem. Any other ideas. Also do you know where to get a
replacement unit or overhaul?
Old March 29th 05, 05:07 PM
Mike Rapoport
Are you sure that it even has a tach generator? If it does, it could be
either that or the guage. Try swapping things side to side until the
problem switches sides.
Mike
MU-2
Old March 29th 05, 05:31 PM
Allen
Because of the location of the tach generator it is susceptible to getting
oil into the cannon plug connector. The first thing I would try is to undo
this connector, thoroughly clean and re-connect. If that doesn't help you
can try swapping sides as Mike suggests to determine if it is the generator
or the tach itself.
Allen
Mechanical tach failure? Rich S. Home Built 25 November 6th 04 04:30 PM
Tachometer or Tach Cable Rich Owning 14 October 14th 04 03:54 AM
Analog tach replacement Mike Noel Owning 12 July 20th 04 11:20 PM
Logging Time Consistently - Hobbs AND Tach Carl Orton Piloting 11 June 29th 04 10:52 PM
Tach Vs. Hobbs Time John Roncallo Owning 33 January 7th 04 01:42 AM
