Teflon gap seal tape...
Old April 2nd 05, 08:03 AM
Marc Ramsey
Default Teflon gap seal tape...
I need to replace the flap/aileron gap seal tape on our LAK-17A. The
control surfaces are bottom hinged, and the gap was factory sealed on
the bottom with what is apparently ordinary polyethylene tape. The tape
cracks over the hinges, which I would have to patch periodically, plus
it shrinks over time, limiting control movement and increasing stick forces.
It seems like Teflon tape is the way to go. I poked around and found
multiple online sources of 1" x 18 yard Teflon PFTE tape with high
temperature silicone adhesive on one side, available in thicknesses from
..0035" (~$25/roll) to .0115" (~$75/roll). There are less readily
available variations with acrylic adhesive, along with "High Density"
PFTE (100% stretch instead of 300%). Does anyone have any idea what
thickness and type of tape would be best for my needs?
Thanks,
Marc
Old April 2nd 05, 09:53 AM
John Ferguson
Look for teflon tape on this page
http://www.streifly.de/Price1-00.htm
If you ask they will do you a complete kit, I'm on
my third kit and haven't been disappointed yet, third
glider in 4 years, LS7 Cirrus and Ventus cT
Old April 2nd 05, 04:29 PM
Not sure that tape is the way to go, Mark. I have found that properly
installed Mylas is all that is necessary. Proof--------when the seals
on my Nimbus 3 needed replacing, I eliminated the internal seals and
also got rid of that ridiculous lower mylar that went inside the gap,
never did understand the reasoning there. Replaced it with Mylar on top
and bottom, nothing else. She climbed and cruised right with another
Nimbus 3 with factory seals.
Another data point..............The ASW-20 had a terrible reputation
for dropping a wing and entering a spin, when they first came
out.................then the spin problem seemed to go away, why? Most
20's today have Mylar, top & bottom. Was the external tape triggering
separation at low speed?
Something to think about,
JJ
Old April 2nd 05, 05:50 PM
Udo Rumpf
I agree with J.J.
Make sure the edge of the tape wipes and makes contact at the bottom
of the aileron when deflected. Install samples at discrete points to find
out if you have the correct radius and position for the Mylar.
Bottom hinged flap/aileron Mylar seal require a slightly different approach
versus the top.
Regards
Udo
"Marc Ramsey" wrote in message
m...
control surfaces are bottom hinged, and the gap was factory sealed on the
bottom with what is apparently ordinary polyethylene tape. The tape cracks
over the hinges, which I would have to patch periodically, plus it shrinks
available variations with acrylic adhesive, along with "High Density" PFTE
(100% stretch instead of 300%). Does anyone have any idea what thickness
Thanks,
Marc
Old April 2nd 05, 08:41 PM
Marc Ramsey
When JJ and Udo agree on something it must be true 8^)
Here is what I was thinking, and I am prepared to be proven completely
wrong. First, Mylar seals (combined with anti-peel tape) appear to be
thicker than Teflon tape, so unless I'm willing to go to the trouble of
routing a groove to inset the Mylar (which I'm not), the Mylar would
seem to me to be every bit as likely to trip the airflow as the Teflon
tape. Second, the point behind external tape (or internal seals) is to
prevent airflow through the gap. Are properly fitted Mylar seals
actually going to prevent this flow? Would it make sense to use Teflon
tape to seal the gap, then put Mylar over the tape?
Thanks,
Marc
Old April 2nd 05, 09:15 PM
Bob Fidler
Mark,
We installed mylar seals on the bottom just behind the tubulator tape. We
installed the 1 1/4" wide teflon tape attaching 1/4 " to the wing just
behind the 1/2" wide adhesive for the mylar seals. The thickness of the
adhesive and the teflon is the same about .007". With the flaps pushed up to
simulate max refax ( the flap and airelon will go up farther), You can mark
the flaps and airleron only with the aircraft assemble and refaxed with full
airleron stick deflection. With the wing turned upside down and the flap and
airleron set to the previously marked position you can then apply the teflon
tape.
The teflon tape is not easy to apply and get the edge straight. I suggest
you practice on some scrap pieces before yo attempt to apply the 25' of
continuous application you will need. If someone in your club has previous
expertise you may want to ask for help.Wings and Wheels sells the tape which
is lite brown in color and costs about $50.
The last tibbit of info is that getting the teflon down flat and without
airbubbles will offer you an additional challenge. If you are an absolute
perfectionist, you may want to investigate professional installation. It
will be difficult to do without flaw.
Good Luck,
Bob Fidler
m...
Thanks,
Marc
Old April 2nd 05, 09:58 PM
Udo Rumpf
The hinge line can be detrimental to the relative thick boundary,
if not covered properly to guide the flow over the hinge line,
the flow could separate.( there is an exception to this if the hinge line is
used
as a transition point)
The tape you are referring to would be just a seal but would not contour
the shape.
The edge of the Mylar tape .010" plus the edge tape .002" it
should not effect turbulent flow. A gap, covered by a sealing tape could.
The Mylar seal if it wipes it will seal. If you were to have difficulties
with this
a separate seal would be the way to go, as long as it does not interfere
with The Mylar.
Sometimes if the hinge is to close to the bottom surface it would be
difficult to get a wiping action
through all the motion of the flap and aileron.
I hope I understood your question.
Udo
om...
routing a groove to inset the Mylar (which I'm not), the Mylar would seem
to me to be every bit as likely to trip the airflow as the Teflon tape.
Second, the point behind external tape (or internal seals) is to prevent
airflow through the gap. Are properly fitted Mylar seals actually going
to prevent this flow? Would it make sense to use Teflon tape to seal the
Thanks,
Marc
Old April 2nd 05, 10:19 PM
the Mylar would
Teflon
to
Teflon
Thanks,
Marc
I have seen it done this way (mylar & tape) Just have come to the
conclusion it isn't necessary. I fit foam rubber in the flap well to
seal any cross-flow at each end of flap and aileron, then the mylar
comes over this area and prevents any air from entering.
I believe the big bug-aboo with tape only is the leading edge starts to
come loose and this = some real drag on that wing.
JJ
Old April 2nd 05, 10:44 PM
Marc Ramsey
difficulties with this
with The Mylar.
Yes, it does answer my question. I suspect the best solution is that
used by Bob Fidler on his LAK, use Teflon tape to act as both a flow
seal and a wiping surface, then put a Mylar seal over it.
Thanks to all,
Marc
Old April 2nd 05, 10:45 PM
HL Falbaum
If I recall correctly, Dick Johnson tested Sam Fly's Ventus 2 with oil flow
and found that the mylar alone did not prevent cross flow from bottom to
top. He removed the ailerons and installed S-seals and stopped the flow. As
I further vaguely recall, this did only a little for the performance! There
was considerable data scatter.
Does anyone know of any hard data that shows, one way or the other, if the
mylars are effective?
Hartley Falbaum
ASW27B "KF" USA
the Mylar would
Teflon
to
Teflon
Thanks,
Marc
JJ
Water dump valve rotary seal Bill Daniels Soaring 6 May 10th 04 12:02 PM
BrandNew-Vector Heavy Duty Plastic Construction Tape Dispenser 13 Peaces Left [email protected] Aviation Marketplace 0 April 30th 04 12:43 AM
Remove oil seal from vacuum pump adapter on Lycoming IO320 HOW????? Ron Home Built 2 February 24th 04 05:34 PM
TURBULATOR TAPE ON VENTUS B Ventus B Soaring 5 February 18th 04 09:27 PM
Premium 3M (483) Poly Tape Soaring 1 November 27th 03 06:41 AM
