Sensenich Wood Prop Question
Old April 4th 05, 02:39 AM
Default Sensenich Wood Prop Question
Can someone tell me what the difference is between a "CK" and a "C"
designation on a Sensenich prop? I am looking at a used prop for my
Aeronca Champ which currently has a W72CK-44 cruise prop. The used
propeller that's for sale is a W72C-42. I have a C-65-8 taper shaft--
will the C work on my engine?
Thanks,
- Brett
Old April 4th 05, 03:23 PM
shaft--
try calling
Sensenich Wood Propeller Co.
2008 Wood Court - Plant City, FL 33563
Phone: (813) 752-3711
jon
Old April 4th 05, 03:32 PM
Deborah McFarland
Thanks,
- Brett
Check the type certificate data sheet for your model Champ at
http://www.airweb.faa.gov/Regulatory...e?OpenFrameSet
For all models:
1. Wood Propellers - fixed pitch
Models 7AC, 7BCM, 7CCM, 7DC
Models 7EC,7FC, 7JC
10 lb.
(-52)
(-54)
(a) Sensenich 72C-44 (Models 7AC and S7AC)
Sensenich 72CK (Model 7BCM)
Sensenich 72CK-44, -45, -46 (Models 7DC, S7DC)
Sensenich 72GK-48, -49, -50 (Models 7CCM, 7EC, S7CCM, 7FC, 7JC)
(b) Flottorp 72A50, 52 (Models 7CCM, S7CCM, 7EC, 7FC, 7JC)
(c) Any other approved fixed pitch wood propeller which is eligible for the
engine
power and speed and which meets the diameter and static r.p.m. limits
specified
under "Propeller Limits" for the pertinent model.
For an A-65-8:
Propeller Limits Static rpm at maximum permissible throttle setting:
(For fixed pitch Not over 2250, not under 1960. No additional tolerance
permitted.
wood propeller) Diameter: not over 72 in., not under 70 in.
Hope this helps. It's best to ask these questions at www.aeronca.com or
www.aeroncapilots.com.
Deb
1946 Luscombe 8A (His)
1948 Luscombe 8E (Hers)
1954 Cessna 195B, restoring (Ours)
Jasper, Ga. (JZP)
Right prop, wrong prop? Wood prop, metal prop? Gus Rasch Aerobatics 1 February 14th 08 11:18 PM
Constant speed prop oil leak DP Piloting 23 April 21st 04 11:15 PM
Auto conversions & gear boxes Dave Covert Home Built 56 April 1st 04 07:19 PM
IVO props... comments.. Dave S Home Built 16 December 7th 03 12:43 AM
Metal Prop vs. Wood Prop Larry Smith Home Built 21 September 26th 03 08:45 PM
