Rotax 912 questions
Old April 9th 05, 06:46 PM
Sully
Let me first start this by saying that I have the 912S so there may
and I'm sure there are differences from the 912 other than the
obvious. Now having said that the "coolant" is more for keeping the
cylinder heads an even temp. The 912 is air/ oil cooled and atleast
in my manual they reference oil operating temps rather than coolant
temps. I have talked to quite a few people who are flying or have
built the planes with the 912 and many have even left off the water
radiator and went with an oil cooler only installation. I know that
mine does have both and I have even installed an oil thermostat that
you can get from Lockwood Aviation. I does take mine a little while
to warm up but the thermostat has helped a lot and now instead of my
temps being around 142-155 when flying it is closer to the bottom of
the normal range (190-230). In the fall though I went as far as
covering the radiators or atleast most of them to help with the warm
up and to help raise the temps a little since they say to get it above
210 for a few minutes as a minimum during flight to boil out any water
in the oil from condensation. I have thought about eliminating the
water radiator or atleast looking for a smaller one but it is kind of
nice during the summer when everyone else is complaining about
overheating on climb out and I'm having no trouble at all!
Hope this helps you some.
Gary
On 4 Apr 2005 17:31:22 -0700, "RPar"
I've talked to Lockwood about the chatter. They did not seem to think
it was out of the ordinary. I would feel better if I had some input
from people running them though.
I'll have to check the inertia spec. It was professionally made for the
912 so I assume that it is correct, but it definitely never hurts to
check.
I did read the installation manual and yes I do get the bulletins. My
912 had to have the oil pump drive pin and new stator assembly
installed ($$$). This was performed, along with a complete inspection,
prior to installation and first start-up.
Thanks for your input.
- RP
You are asking a news group instead of an authority such as Lockwood,
a
certified Rotax repair station? http://www.lockwood-aviation.c**om/
OK here goes:
A five (or ten!) year old 912 certainly should have been gone through
before installing it on your airframe. It will need new rubber seals
on
the water pump as a minimum. The gear box on the 912 80 HP (black
valve
covers) has been very good. Not true with the 912S 100 HP engine (with
the green valve cover). Rotax has added a slipper clutch and a higher
torque starter for the 912S. Your problem may be related to the prop.
Does it meet the inertia spec for the Rotax? Too high an inertia will
eat your gear box.
Have you read the installation manual at www.rotax-owner.com and
signed up for service bulletins?
Old April 10th 05, 01:39 AM
jonladd
I think discussion of your mother's virtue is off limits. As for the
rest of it ...
Today we synched the carbs on my friends Rotax 914 and it made an
incredible difference in its smoothness. I bet it will help you as
well.
Old April 11th 05, 02:48 PM
GTH
Gary,
Your mention of no coolant radiator is a bit surprising as the coolant
heat rejection is 2-4 times that of the oil on a Rotax 912 or 912.
There are hundreds of Rotax 91x powered aircraft around here and it is
the first time I hear of dispensing with a coolant radiator..
Could you be more specific as to what type of aircraft, etc ?
Thanks,
Regards,
Gilles Thesee
Grenoble, France
Rotax 914 MCR 4S with cowl flaps
Old February 12th 09, 04:12 PM
fly away fly away is offline
Junior Member
First recorded activity by AviationBanter: Feb 2009
Quote:
Originally Posted by RPar View Post
Hi all.
I have recently completed my airplane and have begun taxi testing. For
an engine I chose the Rotax 912. I purchased the engine from a
Trade-A-Plane ad where it was advertised as being "new in the box".
When I inspected the engine prior to buying it did appear to be brand
new and was still bolted into the shipping container. I bought the
engine in 1999 and it has not been run until recently. Not only that,
but the serial numbers indicate that the engine was 5 years old in
1999. The age of the engine probably does not matter, however, I
mention it only as background information.
I have been happy for the most part with the engine. But there are some
odd things about it. I have no experience with 912's so I thought I'd
seek some wisdom from others. First, the engine has an incredible
amount of gearbox chatter at around 1600 all the way to about 1950 RPM.
It's swinging a large 72" wood prop. I have set the idle to 2000 RPM in
an effort to get out of the gearbox chatter zone, but with a 72" prop
that still results in quite a bit of thrust. In other words, when I
chop the power on landing (when I get to that point) I'll still have a
bit of power pulling me along. Is that normal? Also, I know the 2
stroke Rotax's are notorious for gearbox chatter, but you don't hear as
much about that from the 912. Is my engine behaving normally? What are
others doing to deal with the chatter?
The other unusual thing about the engine is that it is very cold
natured. It takes a very long time for the water temp to come up. I've
even gotten to the point of covering up half the radiator with a piece
of cardboard until the temperature comes up. I'm starting to suspect
that perhaps I have a thermostat that is stuck open (perhaps due to the
prolonged time in storage). Is that reasonable or is that normal
behavior for the 912 ?
Thank you in advance for any help or advice you can offer.
- R. Parsons
It seems that the carburetors should be balanced.
If have made best experiences with a synchronizer from www.boehm-synchrontester.de
This german company is specialized in producing synchronizers for carburetors with capsule pressure gauge and zero adjustment. Scale range 0....17.7" HG.
On the website ou will find many informations about the Rotax aircraft engine
ROTAX 275 questions Eric Greenwell Soaring 0 January 6th 05 03:43 AM
Questions Rotax Engines Mark Smith Home Built 2 August 14th 04 12:01 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 08:29 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 10:02 PM
Rotax 912 Questions Steve Robertson Home Built 1 November 14th 03 10:01 PM
