#21
All experimentals come with a set of Operating Limitations. Within this
document can be placed a restriction to follow what ever FAR they want to impose. "Must be Maintained by an A&P" and then that is a requirement. Must write a maintenance manual and have it approved by the MIDO then that must be done before flight. Must follow FAR 91.xxx then that what you have to do. The FARs may remove regulations, the OpLims put them back in spades. -- Cy Galley EAA Safety Programs Editor Always looking for ideas and articles for EAA Sport Pilot "Juan Jimenez" wrote in message ... "Ron Wanttaja" wrote in message ... There are two main airworthiness categories: Standard and Special. Standard airworthiness aircraft are proven to meet certain FAA standards, and The FAA waiver usually demands that these planes receive professional-type maintenance similar to that of standard airworthiness aircraft (e.g., the L-39 instructor won't be allowed the maintain the plane himself unless he has an A&P license). Ron "It's *albatross* bloody flavor" Wanttaja I'm curious what warbird experimentals come with a restriction that A&P's must maintain them. Far as I know, all experimentals are still exempt from FAA Part 43, and all of them carry the same annual condition inspection requirement in the operating limitations... 43.1.(b) This part does not apply to any aircraft for which the FAA has issued an experimental certificate, unless the FAA has previously issued a different kind of airworthiness certificate for that aircraft. ?? |
Ron Wanttaja wrote in message . ..
Sorry for being late. I was busy during the last days so I couldn't answer. There are two main airworthiness categories: Standard and Special. Standard airworthiness aircraft are proven to meet certain FAA standards, and they must be maintained to ensure their continued compliance with those standards. At given intervals they must be inspected to ensure they still conform to the Type Certificate they receive. Since these aircraft are known quantities, they may be placed into commercial service with no further FAA certification action (although some additional equipment may be required for some operation). Standard airworthiness includes normal, aerobatic, utility, transport, commuter, and transport categories. Special airworthiness is used for airplanes that either have not undergone the FAA certification process, or specific changes are made to them that take them outside the limits established by their type certificate. Operation of Special airworthiness aircraft is basically governed on a *per aircraft* basis. The FAA assigns operations limitations to each aircraft, and these limitation are not blanket to a given aircraft type nor are they transferrable to an identical aircraft. Ok. So that means if I build a kitplane and get an airworthiness certificate this doesn't necessarily mean that my neighbour building the exactly same kit with exactly the same parts. Understandable, as even with the same parts the quality of work may differ. Special airworthiness categories include Limited, Primary, Restricted, Special Light Sport, and Experimental. Commercial operations are *not* prohibited, but they require specific FAA approval. The degree to which the FAA grants such permission varies. Ok. So if I want to use my experimental commercially I need to get FAA approval first. The Experimental category under the Special Airworthiness includes a number of categories, such as racing, market survey, R&D, Exhibition, experimental LSA, and amateur-built. Racing is clear. What is the difference between the other categories? I assume amateur-built means a plane built by hobbyists. R&D probably is something like an experimental airplane from a plane manufacturer like the YF-22, right? What is experimental LSA? I also wonder when a plane is amateur-built. I assume it's the case if someone without special knowledge builts a plane by itself. What about if he does that commercially (building planes and selling them)? Or what about if a aircraft construction engineer builds a plane? He probably can't be considered as amateur? The FAA's *policy* may be to deny permission for these aircraft to operate commercially, but such policies can be waived. You just have to give the FAA a good reason why the waiver is a good idea. So in the end that means it's basically not allowed to use them commercially, but this can be overcome by a waiver. As others have described very nicely, the L-39 Albatross may be a safe, professionally-designed aircraft, but it never was awarded a US type certificate, nor any similar type certificate that the US is treaty-bound to honor. Hence, it can never be operated normal or any other Standard category. That tosses it into the Special airworthiness category, and the category it apparently best fits into the Experimental/Exhibition one. I understand. Obviously, with dozens L-39s being imported to the US, having a school that can check folks out in them is a real good idea. So the FAA will issue a waiver allowing them to operate one or several aircraft to train folks. Similarly, having a school for training civilian test pilots is also beneficial to aviation, hence a waiver was possible. Similarly, manufacturers of high-performance homebuilts have received waivers allowing them to provide training in a company-built example. I understand The FAA waiver usually demands that these planes receive professional-type maintenance similar to that of standard airworthiness aircraft (e.g., the L-39 instructor won't be allowed the maintain the plane himself unless he has an A&P license). So basically if You maintain Your plane according to the manufacturer standards and if You have a valid reason chances are good that You can get a waiver to allow commercial operation. Thank You very much for your very detailed explanation. And of course to everyone here that answered to my (probably somehwat stupid) questions. JJ. |
On Wed, 13 Apr 2005 07:56:06 -0700, Richard Riley
wrote: On Wed, 13 Apr 2005 06:38:44 GMT, Ron Wanttaja wrote: :I also wonder when a plane is amateur-built. I assume it's the case if :someone without special knowledge builts a plane by itself. What about :if he does that commercially (building planes and selling them)? Or :what about if a aircraft construction engineer builds a plane? He :probably can't be considered as amateur? : :Correct, and the plane can't be registered as Experimental Amateur-Built. Whaaa? Ron, I agree of course as to part 1 of his question (doing it commercially) but if an "aircraft construction engineer" builds an airplane solely for his or her own education or recreation, it can be registered under 21.191g. You're right, of course...I was still thinking of a build-for-hire situation. The "Amateur-Built" moniker is convenient, but the important thing is whether the builder is doing it for pleasure or education, not for a profit. Ron Wanttaja |
PA-32 on Experimental Certificate | Mike Granby | Owning | 3 | July 21st 04 03:04 AM |
Crashing Experimental on America's Funniest Home Videos | Jay | Home Built | 7 | March 10th 04 12:11 AM |
USA: Experimental Certificates | C.Fleming | Soaring | 4 | October 30th 03 10:48 PM |
A couple Questions-Ramp Checks and Experimental Operations | Badwater Bill | Home Built | 48 | October 8th 03 09:11 PM |
2 Place Experimental.... | [email protected] | Soaring | 8 | September 7th 03 03:03 AM |
