#11
On Tue, 25 Jan 2005 19:25:52 -0600, "pwm" wrote:
So far, I am down to two concepts: 1) feed header tank from either main fuselage tank or upper wing tank with a main/aux selector valve 2) feed header tank from only the main fuselage tank; fill main fuselage tank (only until sight gauge shows full) from the upper wing tank via a shutoff valve Any other suggestions? (keep 'em simple) Monty The simplest is to plumb the wing tank through the aux side of the fuel selector valve directly to the gascolator and use a vented cap. You haven't really given enough detail about how your main and header tanks are set up and connected. Will you have a fuel pump or is everything gravity feed? Ed |
![]() The simplest is to plumb the wing tank through the aux side of the fuel selector valve directly to the gascolator and use a vented cap. You haven't really given enough detail about how your main and header tanks are set up and connected. Will you have a fuel pump or is everything gravity feed? =20 Ed Everything gravity feed is the objective. The header tank sits on the = cockpit floorboard, directly underneath the main fuselage tank. The = 12gal main tank is plumbed directly with fittings to the aft end of this = cylindrical header and the gascolator is mounted on the foreward end of = it on the engine side of the firewall. The main tank has a vented filler = cap, as does the upper wing tank. Presently, I can find no shutoff = valves installed, but plan to install one when I figure this out. Thanks, Monty |
Putting the wing fuel caps on backward on a Taylorcraft will not suck the fuel
out of them. It will just not let them flow into the main tank. All you have to do is land and turn the caps around and you are good to go. Lyman |
![]() " jls" wrote in message ... "Corky Scott" wrote in message ... On Tue, 25 Jan 2005 08:13:09 -0800, Ed Sullivan wrote: I'm not sure why you have a header tank unless it is for inverted flight. On my Jungster the wing tank feeds into the fuel valve as does the fuselage tank. I can then select either the wing or fuselage tank, but not both otherwise the wing tank could overflow the fuselage tank. I have both upright and inverted vents on the fuselage tank and inverted tank. On the wing tank I just use a vented cap. Ed Sullivan Really? You can't just plumb the wing tanks into the header tank? Thought that was done all the time. Is it necessary to vent the header tank if the wing tanks are properly vented? Thanks, Corky Scott Well, maybe, but wing tanks on a Taylorcraft are vented with ram-air tubes on the caps and so is the header tank. In flight those tubes make positive pressure on the 6-gallon wing tanks and the 12-gallon header tank. I've seen a few times, too, that the wing tank gets balky emptying into the header tank during flight, despite the ram-air tubes. Let me elaborate on this rather uncomplicated fuel vent system on the Taylorcraft. The 12-gallon header tank is fixed to 4130 fuselage tubes and sits behind the firewall and in front of the panel. Its vent --which is merely an acute angle cut facing forward in a vertical tube rising from the filler cap on the boot cowl just forward of the windscreen -- is also the hole through which the fuel gauge wire moves up and down according to the quantity of fuel in the header tank. Obviously the positive pressure supplied by this vent tube is slightly less than the pressure provided by either of the ram-air tubes on the wing tank caps. Otherwise, wing tank flow into the header tank might not occur. And I've seen that happen with Taylorcrafts other than mine. Some people install glorified ram air tubes on their wing tank caps. They braze onto the caps longer tubes pointed into the slipstream and bellmouth them. The apparent fix gives them a better pressure differential to push wing tank fuel down into the already pressurized fuselage tank. Of course, with the valves on the wing tanks closed, the fuselage tank must have some way of its own to maintain positive pressure to feed gasoline through the gascolator and into the carburetor bowl, especially in a climb where sometimes gravity alone is not enough. C. G. Taylor, also the designer of the Cub, must have been thinking about those steep climbs in a Taylorcraft when he designed the ram-air tubes on the wing tanks because they are bent more than 90 degrees downward so they face directly into the slipstream during a steep climb. On the subject of a small header tank in addition to a fuselage tank, that sure does sound a little like Rube Goldberg to me. It must a device to cure a history of fuel starvation, something I have never heard of in a simple system like the Taylorcraft's. OTOH,maybe there's a good reason for it. I have flown a Taylorcraft since the eighties and never had it give trouble feeding from the wing tank to the fuselage tank, with one or two exceptions. And never ever had a fuel starvation problem. Here are the exceptions: You know those socks you put over a 172's pitot tube to keep bugs out while you're sitting on the ramp? Well, those bugs, angry at the socks on 172's, will seek out and set up housekeeping in your ram-air tubes. So you just take a length of .016 safety wire and punch the little *******s out. When you get one in your 172's pitot because like me you were too slack to put on the sock, the cure is not so easy. |
![]() "Hatz Lyman C" wrote in message ... Putting the wing fuel caps on backward on a Taylorcraft will not suck the fuel out of them. It will just not let them flow into the main tank. All you have to do is land and turn the caps around and you are good to go. Lyman I think you're probably right, but I've never had the experience, having learned long ago to pre-flight. This practice was reinforced after a line-boy gassed us up and put those lids on backwards in Kankakee. |
On Wed, 26 Jan 2005 09:38:14 -0500, " jls"
wrote: C. G. Taylor, also the designer of the Cub, must have been thinking about those steep climbs in a Taylorcraft when he designed the ram-air tubes on the wing tanks because they are bent more than 90 degrees downward so they face directly into the slipstream during a steep climb. There is another possible reason for angling the ram tubes slightly downward: it prevents rain drops from entering the vent system while in flight, and sitting on the ground. Corky Scott |
On Tue, 25 Jan 2005 16:25:13 -0800, Ed Sullivan
wrote: Corky, I don't know why you need a header tank with a fuselage tank. Sorry, this was a part of the post I missed. I did not realise that was the situation. I was thinking purely about wing mounted tanks plumbed into a header tank. Corky Scott |
about those steep climbs in a Taylorcraft when he designed the ram-air tubes on the wing tanks because they are bent more than 90 degrees downward so they face directly into the slipstream during a steep climb. The down angle is to keep rain out. The airflow will be parallel to the top of the wing in any attitude except full stall. On the subject of a small header tank in addition to a fuselage tank, that sure does sound a little like Rube Goldberg to me. It must a device to cure a history of fuel starvation, something I have never heard of in a simple system like the Taylorcraft's. OTOH,maybe there's a good reason for it. Some airplanes had tiny header tanks to increase usable fuel. In a slip or steep nose-down glide (especially with flaps on some aircraft) the fuel moves away from the tank outlet and the engine might starve if the tanks are low. The small header is intended to keep the engine supplied while in that attitude. The Glastar had a retrofit kit of two small headers to overcome the starvation problem, since the very effective flaps resluted in a rather large unusable fuel quantity, limiting range. Other airplanes use two tank outlets, one front and another rear, plumbed together. Citabria is a good example. Dan |
On the Champ, wing tanks drain directly into fuselage tank. There's a
valve for each wing tank. If you open that valve before the fuselage tank has drained sufficiently, gas will spray out the filler cap vent onto the windshield. Corky Scott wrote: On Tue, 25 Jan 2005 13:14:41 -0500, " jls" wrote: Well, maybe, but wing tanks on a Taylorcraft are vented with ram-air tubes on the caps and so is the header tank. In flight those tubes make positive pressure on the 6-gallon wing tanks and the 12-gallon header tank. I've seen a few times, too, that the wing tank gets balky emptying into the header tank during flight, despite the ram-air tubes. Well if the header tank is below the wing tanks, and the header tank is vented, what's preventing the wing tanks from overfilling the header tank as Ed Sullivan suggested? Does the header tank vent have a checkvalve? I was picturing the header tank being downstream of the wing tanks and not being vented. In effect, the header tank is simply a distorted downstream fuel line. Thanks, Corky Scott -- John Kimmel Naturally, these humorous remarks are all entirely my own opinion, based solely on rumor, supposition, innuendo and damned lies, and should be interpreted in a spirit of fun. My memory is faulty, also. |
spaceship one | Pianome | Home Built | 169 | June 30th 04 05:47 AM |
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve | Bill Berle | Home Built | 0 | January 26th 04 07:48 AM |
Ram air assist | Rich S. | Home Built | 10 | November 11th 03 05:58 PM |
Yo! Fuel Tank! | Veeduber | Home Built | 15 | October 25th 03 02:57 AM |
Pumping fuel backwards through an electric fuel pump | Greg Reid | Home Built | 15 | October 7th 03 07:09 PM |
