Getting used to the Arrow...and I like it...a lot!
Old April 16th 05, 06:59 AM
Jack Allison
Robert M. Gary wrote:
Jack,
In a previous post, it sounded like you fly near Sacramento. If you
need any advice on shops for various types of work, let me know. I used
to have an Arrow, I now have a Mooney. The two are VERY similar. The
only noticable difference to the pilot is the wing. The Arrow has the
easy going Piper wing and the Mooney has the laminar wing.
Yes, I'm in the Sacramento area. Currently based at MCC but plan to be
at LHM as soon as a hanger opens up.
Shop recommendations greatly appreciated. Thanks!
Jack Allison
PP-ASEL-IA Student
Student Arrow Owner, N2104T
"When once you have tasted flight, you will forever walk the Earth
with your eyes turned skyward, for there you have been, and there
you will always long to return"
- Leonardo Da Vinci
(Remove the obvious from address to reply via e-mail)
Old April 16th 05, 07:03 AM
Jack Allison
Turbo Arrow wrote:
you turn on the boost pump on landing?
Are you sure your suppose to do that?
Yes, part of the pre-landing checklist for non-turbo version.
Jack Allison
PP-ASEL-IA Student
- Leonardo Da Vinci
Old April 16th 05, 07:33 AM
Turbo Arrow
I have not have problems with thermals making me float down the runway
Matt Barrow wrote:
"Turbo Arrow" wrote in message
I have 2 ways of flying my arrow, in the winter I come in with no flaps
and
summer I use full flaps because of the change in air density,if I used
full
flaps in the winter I would float sometimes
More likely you would float during the summer from the thermals associated
with ground heating.
Old April 16th 05, 07:36 AM
Turbo Arrow
yes I have the optional electric primer and hi/lo rocker.
I flew a normally aspirated arrow a couple of times that did not have the electric
primer and it also did not require the boost pump, but all I have flown are arrow
III's, the older ones may be different.
john smith wrote:
It depends on the Arrow and which fuel primer system you have.
Do you have the optional system with the primer button on the panel and
a HI/LO fuel pump rocker switch in the bank of rocker switches with the
MASTER? Or, do you have another arrangement?
In my turbo arrow boost is not required for landing or take off, you can use it
on low boost to reduce vapor on hot days prior to take off but other then that
its not touched unless there is an emergency. Thats in the t-arrow, I would
think the normally aspirated one would be the same.
Old April 16th 05, 07:37 AM
Turbo Arrow
yes I know, maybe I should have said MP pressure instead of power, but I
assumed most people would have known what I ment.
kage wrote:
just a note, on decents, instead of reducign power to come down, you can
just
pull the prop back
Pulling the prop back IS reducing power.
Karl
"Curator"
N185KG
Old April 16th 05, 07:41 AM
Turbo Arrow
I was not talking about landings, I am talking about comming down from say,
12,000 ft.
As I said, this is in the book, not something I made up off the top of my head.
john smith wrote:
just pull the prop back
I was taught not push the prop forward until I had the runway made.
(Pulling back reduces RPM, pushing it forward increases RPM)
Do you know how your prop "fails" when the engine stops pumping oil to
the governor?
Old April 16th 05, 07:45 AM
Turbo Arrow
I see its a 1971, is that an Arrow II ?
Its a nice looking plane BTW
Jack Allison
PP-ASEL-IA Student
- Leonardo Da Vinci
  #28
Old April 16th 05, 11:35 AM
Mortimer Schnerd, RN
Something else you may want to consider: in cruise, rather than flying at
2400/24", find another power combination that gives the same percentage of power
but uses lower RPM / higher manifold pressure. It yields noticably less noise
and makes for a more pleasant ride.
I wasn't paying attention... we're not talking about a Turbo Arrow, are we? If
we are, forget I said anything about 24". Less RPM still means less noise.
Your passengers will appreciate it, as will your wife when you're 50 and saying
"what?" all the time.
VE
  #29
Old April 16th 05, 04:14 PM
Matt Barrow
An airplane impervious to ground effect?
flaps
and
full
associated
  #30
Old April 16th 05, 04:43 PM
kage
I knew you knew, but this is "Usenet" and I just had to harangue you! In a
crew situation being very succinct is important.
Plus others might be afraid to pull the prop back due to some OWTs.
Best,
Karl
can
just
pull the prop back
Karl
"Curator"
N185KG
Fun weekend buying an Arrow (long) Jack Allison Owning 44 April 20th 05 01:29 PM
Fun weekend buying an Arrow (long) Jack Allison Piloting 45 April 20th 05 01:29 PM
Ongoing Arrow alternator/charging problem Chuck Owning 6 December 22nd 04 02:18 AM
Remember the Arrow onsitewelding Piloting 5 August 28th 04 07:47 PM
CF-105 AVRO Arrow etc. Ed Majden Military Aviation 4 February 22nd 04 08:00 PM
