#61
"Roger" wrote in message ... I once flew IFR to OSH around the South end of Lake Michigan. As you well know they sent me what seemed like half way to Kentucky to stay well clear of ORD's airspace, climb corrodors, and preferred routes in and out. Although, looking at a map shows the distance to OSH from Midland (3BS) to be about the same whether you go around the North or South end of the lake (possibly a tad shorter around to the South) it will work out to be far longer going South if you are IFR. Unless you plan a stop within Chicago approach control airspace. Then you're no longer a thruflight, you're an arrival and a departure. But then you may be routed over a bit more water than you'd like. |
#62
Exactly. Going to Midway the first time IFR I ended up over the lake
much farther out than I liked. Next time I went down to the same area I put "no over-water routing please" in my remarks, which worked - I was routed around to the west instead. A bit longer, but I'd prefer that. My CFII told me this little story. A colleage of his (another CFII) was doing practice approaches VFR with MKE approach. At one point he told them he was several miles out over the lake and he'd like a turn. He was told he'd have one shortly. Another few minutes and another few miles and he squawks 7700. "What's your emergency?" "I'm over the lake in a piston single." He got his turn. Steven P. McNicoll wrote: "Roger" wrote in message ... I once flew IFR to OSH around the South end of Lake Michigan. As you well know they sent me what seemed like half way to Kentucky to stay well clear of ORD's airspace, climb corrodors, and preferred routes in and out. Although, looking at a map shows the distance to OSH from Midland (3BS) to be about the same whether you go around the North or South end of the lake (possibly a tad shorter around to the South) it will work out to be far longer going South if you are IFR. Unless you plan a stop within Chicago approach control airspace. Then you're no longer a thruflight, you're an arrival and a departure. But then you may be routed over a bit more water than you'd like. |
#63
#64
Paul Folbrecht wrote in
: Anyway, on to my question. A couple times now, when I've been navigating direct, either to a fix or airport identifiable by VORs or one that isn't (such as an uncontrolled field with no navaid), I've been asked to "verify direct XXX" when I'm off course by a quite small amount - no more than 10 degrees. Or, perhaps, I've gotten off course a bit and have a larger heading correction (20-25 degrees) in to get back on track, momentarily. I've never had a controller sound annoyed, but it does concern me a bit that they see fit to more or less ask "Are you sure you know where you're going"?? Was it the same controller who gave you the clearance? How far off course were you with respect to miles, not degrees? Especially during controller changes and/or handoffs, controllers may not always have clearly documented the last clearance they gave you. The next controller confirms this either by asking you to verify, or giving you the clearance again. I've had this happen to me numerous times. Generally speaking, though, I have found that a "correction" will only be made if you are off by more than a couple of miles and don't seem to be correcting, or if your error threatens to cause separation issues (although this is more common with altitude busts than heading busts). I look at it as a good thing, not a bad one. One time when flying IFR in IMC I managed to miss a waypoint on an airway. As I flew off the "real" airway I was asked to verify I was on the airway. When I confirmed they indicated that I looked like I was direct to the next waypoint (I think it was RBV or SAX VOR) and not on the airway. When I realized the error and fessed up, they cleared me direct to where I was going anyway - presumably no one else was around, and it was only a few degrees different. But had there been other traffic in the area, and had they not corrected me (ie: RADAR down or what not), it could have led to bad things... Accidents happen, people are only human and do make mistakes. That's why ATC is not annoyed to help you. They're there to help you. They will get annoyed if they have to correct you frequently (READ: NY TRACON if it's more than once, or if they just corrected someone else before you). But everyone gets an occassional correction - I've even heard it happen to Heavies! ![]() |
#65
#66
"Steven P. McNicoll" wrote in message link.net... "Chip Jones" wrote in message ink.net... Because it isn't just a NATCA meeting... Odd, then, that that's what it's called. LOL, is not.... :-P Chip, ZTL |
#67
Dan Luke wrote:
"G. Sylvester" wrote: Lastly, I have to admit I'm far from an expert. That is well established. at least I'm humble. Now I think I understand what you guys are doing. For an intersection defined by 2 VOR's within receiving range of the VOR for your current position, you would tune-ident-twist for each radial defining the intersection. fly to it and have the needles center. that is your intersection. If you have a TSO-C129 GPS, you can tell it to go to that intersection and you are good to go. Nice and easy. If you have a handheld, then you tell it to go but you still must use the VOR's as your GPS database could be 12 years old. Basically you are using the handheld to just help you out to get to the point. Your VOR's are your primary means of defining that that intersection though. That is pretty logical and normal as if you didn't have a handheld. Now if the intersection is 500 nm away and out of VOR reception, then the handheld is your primary means and only means of navigation. The FAA might very well say you are legal but reckless. You can say you monitored VOR's along the way but I'd have a hard time seeing the FAA not seeing you as reckless without an TSO'd GPS, INS, Loran, etc. But I'm not the judge. Do as you see fit and hopefully you never have to sit at the end of a table with men in black suits and dark sunglasses. BTW, I asked the DPE I'm using for my checkride about this. He said he would have failed me if I used a non-TSO'd GPS for IFR operations. He's not a court of law though. Cheers, Gerald Sylvester |
#68
G. Sylvester wrote: Now if the intersection is 500 nm away and out of VOR reception, then the handheld is your primary means and only means of navigation. The FAA might very well say you are legal No, they wouldn't say that. but reckless. Can't see how unless you somehow manage to wreck the plane because of your handheld. BTW, I asked the DPE I'm using for my checkride about this. He said he would have failed me if I used a non-TSO'd GPS for IFR operations. He's not a court of law though. He is correct. |
#69
#70
"G. Sylvester" wrote in message .. . at least I'm humble. Now I think I understand what you guys are doing. For an intersection defined by 2 VOR's within receiving range of the VOR for your current position, you would tune-ident-twist for each radial defining the intersection. fly to it and have the needles center. that is your intersection. If you have a TSO-C129 GPS, you can tell it to go to that intersection and you are good to go. Nice and easy. If you have a handheld, then you tell it to go but you still must use the VOR's as your GPS database could be 12 years old. Basically you are using the handheld to just help you out to get to the point. Your VOR's are your primary means of defining that that intersection though. That is pretty logical and normal as if you didn't have a handheld. Now if the intersection is 500 nm away and out of VOR reception, then the handheld is your primary means and only means of navigation. The FAA might very well say you are legal but reckless. You can say you monitored VOR's along the way but I'd have a hard time seeing the FAA not seeing you as reckless without an TSO'd GPS, INS, Loran, etc. But I'm not the judge. Do as you see fit and hopefully you never have to sit at the end of a table with men in black suits and dark sunglasses. Being reckless isn't enough, at least not according to the regulation. FAR 91.13(a) states; "No person may operate an aircraft in a careless or reckless manner so as to endanger the life or property of another." Whose life or property is endangered by the use of a handheld GPS for IFR enroute operations? |
| Clearance: Direct to airport with /U | Judah | Instrument Flight Rules | 8 | February 27th 04 07:02 PM |
| Direct To a waypoint in flightplan on Garmin 430 | Andrew Gideon | Instrument Flight Rules | 21 | February 18th 04 02:31 AM |
| "Direct when able" | Mitchell Gossman | Instrument Flight Rules | 18 | October 21st 03 02:19 AM |
| Filing direct | John Harper | Instrument Flight Rules | 10 | October 9th 03 11:23 AM |
| Don Brown and lat-long | Bob Gardner | Instrument Flight Rules | 30 | September 29th 03 04:24 AM |
