ATC User Fees
Old April 29th 05, 11:49 PM
Peter
Steven P. McNicoll wrote:
"Peter" wrote in message
Yes, it might be almost as complex as this post managing to find its way
through a network of thousands of computers without any central control.
I'm sure the system will immediately fall apart and you'll never see this
response.
How do the consequences of losing a message compare to the consequences of a
midair collision?
I expect one of the criteria before transitioning to a more distributed
computerized system of ATC would be that it would reduce the probability
of collisions. I'm not expecting it to happen anytime soon.
Old April 29th 05, 11:53 PM
Steven P. McNicoll
Same thing that happens now. If the runway isn't clear when he starts to
land then he does a go around and negotiates a new reservation slot in the
queue. If he's far enough back when the delay occurs then he slows or
does a 360. Certainly the algorithms would be different for ATC than
computer networks ('retransmit after collision' can work for packets but
isn't so good for aircraft), but I don't see it as inherently less
soluable.
What's the backup to the computer?
Old April 29th 05, 11:56 PM
Newps
Larry Dighera wrote:
On Fri, 29 Apr 2005 15:02:19 -0600, Newps wrote
in ::
The aircraft on takeoff roll has to abort and as you
know there could be a million reasons for that. Perhaps it's a non
mechanical reason, and therefore not known by the computer, a deer ran
on to the runway. How does the aircraft on final know what to do? It
all has to be inputted into a computer immediately.
If the computer is aware of the position of the aircraft it is
controlling through GPS interrogation, RADAR/transponder, ADDS-B, or
..., it would be programmed to issue the appropriate instructions to
the aircraft. Beyond departure and destination information, little
else need be "inputted" into the computer.
The computer doesn't know that the aircraft aborted, only that it has
been released and will fly the computer assigned heading. It knows whre
the plane is but not why it isn't doing what it's supposed to.
  #24
Old April 29th 05, 11:57 PM
Larry Dighera
On Fri, 29 Apr 2005 21:47:41 GMT, "Steven P. McNicoll"
wrote in
et::
"Larry Dighera" wrote in message
So you agree that the information wouldn't need be "inputted" into the
computer?
  #25
Old April 29th 05, 11:59 PM
Newps
the queue.
So the pilot isn't busy enough and now has to be a controller?
or does a 360.
No airplane on final in busy airspace does a 360. Ever.
soluable.
I said the computer could do it. The problem is the controller can do
it better. You cannot make a computer do what the controller does and
do it more efficiently. You will never remove the human.
  #26
Old April 30th 05, 12:03 AM
Steven P. McNicoll
computer?
Of course, but the computer would certainly need input. A computer without
input is not particularly useful.
  #27
Old April 30th 05, 12:36 AM
Jose
I think the idea is that the pilot, with sufficient information in a
sufficiently good display and interface, would be able to handle
separation (under IMC) as well as he could under VMC. If this is true
(and I'm not convinced that it is yet), then much of the need for the
IFR system would be eliminated.
I am aware that under high traffic conditions this breaks down (which is
presumably why we have alphabet airspace to begin with)
Jose
Get high on gasoline: fly an airplane.
  #28
Old April 30th 05, 02:07 AM
David Dyer-Bennet
"Matt Barrow" writes:
"Jay Honeck" wrote in message
news:2mqce.34479$r53.15777@attbi_s21...
To truly privatize it would require free market competition among
providers
of ATC services. That simply is not possible.
They used to say that the phone company or the utility companies needed to
be monopolies.
And, in fact, there is only *one* gas pipe, *one* water pipe, *one*
sewer pipe running down the street out front of my house. And only
*one* set of electrical wires in the neighborhood. And *one* set of
phone wires. And *one* set of cable company coax.
It's possible to multiplex services from different companies on them,
to some extent. It's not very meaningful for the water, phone,
electricity, or sewer; for the phone wires, also used for DSL, it
actually seems to work well to allow multiple ISPs to connect
through those lines. But tht's because it's a separate run from the
switching office to each house, whereas all the rest use shared
wiring/piping.
David Dyer-Bennet, , http://www.dd-b.net/dd-b/
RKBA: http://noguns-nomoney.com/ http://www.dd-b.net/carry/
Pics: http://dd-b.lighthunters.net/ http://www.dd-b.net/dd-b/SnapshotAlbum/
Dragaera/Steven Brust: http://dragaera.info/
  #29
Old April 30th 05, 02:13 AM
Steven P. McNicoll
So it's pretty much outside the scope of this discussion then.
  #30
Old April 30th 05, 02:27 AM
Rich Lemert
in ::
Your comment assumes that all unusual circumstances can be identified
in advance and therefore prepared for. Unfortunately we are past the
point where this is true.
Rich Lemert
User Fees Dude Owning 36 March 19th 05 06:57 PM
NAA Fees to the US Team Doug Jacobs Soaring 2 October 29th 04 02:09 AM
LXE installation XP, strict user permissions. Hannes Soaring 0 March 22nd 04 12:15 AM
The Irony of Boeing/Jeppesen Being Charged User Fees! Larry Dighera Piloting 9 January 23rd 04 01:23 PM
Angel Flight pilots: Ever have an FBO refuse to wave landing fees? Peter R. Piloting 11 August 2nd 03 02:20 AM
