Brake Rivet Problem
Old May 16th 05, 02:22 AM
Jonathan Goodish
Default Brake Rivet Problem
I am trying to replace the brake linings on my Cherokee. I have had new
linings and brass rivets for some time now, along with a rivet tool.
The problem I'm having is that the rivets aren't forming a decent head,
but are simply being "squashed" more or less. They are spreading
slightly, so the result is a tight fit, but I don't think that they're
spreading enough to form an adequate head.
The holes in the backing plates do not look oversized, and I am using a
brake rivet tool, so I'm not sure of the problem.
Any suggestions?
Thanks,
JKG
Old May 16th 05, 04:08 AM
Newps
Any suggestions?
Put 'em on and use them.
Old May 16th 05, 04:23 AM
Jonathan Goodish
Any suggestions?
Yes, I'm not sure whether they're supposed to be like that or not. The
ones that came off of there had nice large, rounded lip heads, but who
knows when they were put on or by whom, because it was long before I
ever owned the aircraft.
I just don't want to put them on and have them come flying off.
JKG
Old May 16th 05, 03:36 PM
Newps
Any suggestions?
The heads on the rivets that I installed on my brakes are smashed like
you said yours were. If the brake pads are solid then use them If they
come flying off of there, which is highly unlikely, then put new ones
on. I have had brake lines break on 3 or 4 occasions and shoot all the
fluid out the crack. One operating brake is plenty.
Old May 17th 05, 12:32 AM
Jonathan Goodish
I had a local mechanic finish mine up, and the rivet heads are a little
better but not much--they're pretty much smashed. So that's the way
they're supposed to be, I guess.
JKG
Old May 17th 05, 01:42 AM
Jay Masino
The most important things are that the pads are being held tight, and that
you didn't smash the rivets so much that the pads crack.
__!__
Jay and Teresa Masino ___(_)___
http://www2.ari.net/jmasino ! ! !
http://www.oceancityairport.com
http://www.oc-adolfos.com
Old May 17th 05, 01:56 AM
Ric
"Jay Masino" wrote in message
When you say smash do you mean hammer? Brake rivets should be squeezed not
hammered.
Ric
__!__
Old May 17th 05, 03:04 AM
Jonathan Goodish
hammered.
I guess they can be hammered if you're skilled at it, but I think that
he's referring to the head of the rivet, which looks "smashed" by the
brake rivet tool.
In my case, the linings were tight, but the rivets didn't look like the
factory ones, so I wasn't sure whether I was missing something.
JKG
Old May 17th 05, 05:32 PM
Don Hammer
JKG
The factory puts them on with a roto-pien (sp?) tool. You won't be
able to duplicate that. The rivets are a shear device and carry very
little load under tension. I always put them on with a light hammer
and only tight enough to secure the pad tightly. You don't want to
crack the pad.
Posted Via Usenet.com Premium Usenet Newsgroup Services
** SPEED ** RETENTION ** COMPLETION ** ANONYMITY **
http://www.usenet.com
Old May 18th 05, 02:45 AM
Jay Masino
hammered.
Sorry. Probably a poor choice of words.
--- Jay
__!__
Transient alternator problem John Clonts Owning 6 July 11th 04 07:01 PM
Captain sim Mig-21 brake chute Lee Hutchinson Simulators 7 June 1st 04 11:51 AM
Real World Problem in FS9 The Real Cali Kid Simulators 12 December 6th 03 12:15 PM
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) Snowbird Home Built 78 December 3rd 03 10:10 PM
Brake line design question Charlie Smith Home Built 0 July 2nd 03 01:31 PM
