Aluminum Prop Dings
Old May 25th 05, 12:45 PM
Ron Natalie
guynoir wrote:
The curved side of the blade is called the "back" or "cambered side". The
flat side is called the "face" or "thrust side". The back usually doesn't
get many nicks in it.
I get more dings in the back (the side facing the pilot) than I ever get
in the front.
Old May 25th 05, 12:59 PM
Dave S
While well intentioned, there are many ISP's that have issues with the
bandwidth used by posting large files, such as photos, on usenet. There
is a specific usenet newsgroup that is appropriate for posting pics. You
can post ABOUT em here, and say go check it out there.... or you can
post a link to a website that hosts the picture files.. Actually putting
them here is discouraged, from what I understand.
alt.binaries.pictures.aviation is the place that most of us use.
NOT the USENET police... and nice pics, by the way..
Dave
Old May 25th 05, 08:00 PM
guynoir
The side facing the pilot is the face. The side away from the pilot is the
back, unless you fly a pusher.
Ron Natalie wrote in
m:
The flat side is called the "face" or "thrust side". The back
usually doesn't get many nicks in it.
get in the front.
J Kimmel
www.metalinnovations.com
"Cuius testiculos habes, habeas cardia et cerebellum." - When you have
their full attention in your grip, their hearts and minds will follow.
Old May 27th 05, 02:04 AM
Filing or dressing out prop nicks is a job for a licensed
mechanic, since there are legal specs that must be adhered to, and the
prop manufacturer has more dimensional limits that need to be checked.
They learned these things the hard way; don't you go doing the same.
The right sort of nick, in the right place, given enough time in
operation, will result in a crack that could see a chunk of prop
disappear, and the imbalance could tear the engine off the airplane.
The airplane will not glide with its engine missing, so nicks need to
be taken seriously.
I've seen some badly repaired nicks that actually make the
prop more likely to fail.
Dan
Old June 3rd 05, 10:49 AM
ahc
Do NOT try to dress out the prop yourself. Even a small nick can cause a
prop to fail in flight. If this happens at full power, the engine can be
ripped off the airplane in less than a second! Without the engine, the
airplane becomes extremely tail heavy and a violent crash is unavoidable.
Certain types of nicks on certain models or propellor are fixable. A
licensed mechanic with a powerplant rating knows how to properly dress a
prop if it's possible, and rebalance and repaint the prop. Don't try to
paint the prop yourself. Even a small amount of paint on one side can
seriously unbalance a prop. Some propellors are balanced by simply
applying varnish to one side...that's all it takes! Get a prop shop or a
powerplant mechanic to work on it.
be taken seriously.
Dan
Old June 5th 05, 09:21 AM
Roger
On Wed, 25 May 2005 14:00:21 -0500, guynoir
That terminology is as intuitively backwards as some of the computer
stuff I work with.
www.rogerhalstead.com
om:
get in the front.
Old June 7th 05, 01:44 PM
Robert Bonomi
stuff I work with.
Just think of it as 'little endian' vs. 'big endian'. *GRIN*
It makes sense, if you think of it in terms of which 'side' of the prop is
doing the work. It's the one to the rear that actually pushes the air around.
Right prop, wrong prop? Wood prop, metal prop? Gus Rasch Aerobatics 1 February 14th 08 10:18 PM
my ignorance LCT Paintball Home Built 25 April 9th 05 06:54 PM
Ivo Prop on O-320 Dave S Home Built 14 October 15th 04 03:04 AM
IVO props... comments.. Dave S Home Built 16 December 6th 03 11:43 PM
Metal Prop vs. Wood Prop Larry Smith Home Built 21 September 26th 03 07:45 PM
