How do you leave this airport IMC?
Old May 28th 05, 04:13 AM
Ron Rosenfeld
On Fri, 27 May 2005 17:30:21 -0500, Journeyman
Looking at the plates, 10/28 has minima 300-1 and 600-1 respectively.
The procedure for runwya 10 is to climb runway heading to 2300 before
proceeding on course. The MSA for the area is 4200. How do you get
from the DP to the nearest Victor airway safely when it's 300 and 1?
One way:
Depart Rwy 28; cross the end at least 35'AGL; climb at least at 200 ft/nm
until the MEA.
It seems like a straight forward DP to me. What is it that is confusing to
you?
(And I won't get into the lack of a legal requirement for most Part 91
flights).
Old May 28th 05, 04:14 AM
Ron Rosenfeld
On Fri, 27 May 2005 20:59:29 -0400, "Paul Lynch" wrote:
Unless there are specified takeoff minimums, a flight conducted under Part
91 does not have any departure weather requirements,
At least for small GA a/c, there are no legal departure weather
requirements even if there ARE specified takeoff minimums.
(Whether taking advantage of that rule is smart or safe is another matter).
Old May 28th 05, 05:49 AM
Andrew Sarangan
I have not seen anyone directly answer the question raised by the
poster. What exactly is 'on-course'? Which airway are you supposed to
intercept? MSA may not be operational in nature, but it does tell us
there are 3200' ft obstacles within 25NM. If you proceed at 2300', how
can you remain clear of these obstacles?
"Bob Gardner" wrote in
You may be remembering some Canadian regs. The MSA is irrelevant. It
has no operational significance and is not part of an instrument
approach procedure. Under Part 91, you don't have any takeoff
minimums.
If you are really concerned, climb over the departure airport until
you feel comfortable in proceeding.
Bob Gardner
"Journeyman" wrote in message
On the way to Pinckneyville last weekend, I stopped at Jimmy Stewart
Field, Indiana, PA. KIDI. I had to shoot the GPS 28 approach with
a cirle to land 10. There's a nice transition off the Revloc VOR.
Since we had a late start, we had planned to stop there for the
night, but by the time we left for the hotel, the overcast had broken
up and it was clear. Next morning, we left VFR.
Morris
Old May 28th 05, 01:10 PM
Ron Rosenfeld
On 27 May 2005 22:49:31 -0500, Andrew Sarangan
I don't have the charts in front of me right now, but, as I recall, there
is no instruction to "proceed at 2300'". And the manner of flying a DP is
to continue climb at 200 ft/nm until at the MEA.
The airway you are supposed to intercept is the one to which you have been
cleared.
"On Course" for the rwy10 DP (if that's the one with the climb to 2300'
instruction) means the direct route from the point at which you attain
2300' to the closest point on the airway to which you have been cleared.
For the other runway, it would be after attaining 400' AGL.
And you should not hit obstacles because these routes with the restrictions
cited in the DP's have been checked for obstacle clearance.
Old May 28th 05, 01:40 PM
Paul Lynch
Under 91 there are no takeoff minimums (unless specifically stated in a
departure procedure) for any size aircraft, including a 747.
"Ron Rosenfeld" wrote in message
matter).
Old May 28th 05, 02:13 PM
Matt Whiting
91 does not have any departure weather requirements, only
destination/alternate requirements. That is where judgement comes into
play. You can legally takeoff with only enough viz to see the centerline.
Is that smart??
Maybe. All depends on the circumstances. :-)
Matt
Old May 28th 05, 02:14 PM
Matt Whiting
Bob Gardner wrote:
You may be remembering some Canadian regs. The MSA is irrelevant. It has no
operational significance and is not part of an instrument approach
procedure. Under Part 91, you don't have any takeoff minimums.
I thought published takeoff minimums applied to Part 91 operations. No??
Matt
Old May 28th 05, 02:23 PM
Matt Whiting
approach procedure. Under Part 91, you don't have any takeoff minimums.
I just reviewed 91.175 and a Part 91 operation isn't included in the
takeoff minimums section.
Matt
Old May 28th 05, 02:27 PM
Andrew Sarangan
Ron Rosenfeld wrote in
Good point. In other words, the aircraft should climb on runway heading
to 2300', and then turn to any heading and continue climbing at 200ft/NM
to the minimum IFR altitude.
there is no instruction to "proceed at 2300'". And the manner of
flying a DP is to continue climb at 200 ft/nm until at the MEA.
been cleared.
2300' instruction) means the direct route from the point at which you
attain 2300' to the closest point on the airway to which you have been
cleared.
restrictions cited in the DP's have been checked for obstacle
clearance.
Old May 28th 05, 02:35 PM
How do you infer that you can proceed at 2,300 feet? That is a turn
restriction to avoid the antennas to the south. It is NOT a level off
altitude. With a ODP worded like this your minimum level-off altitude is
either your ATC-assigned altitude, which should be (will be if issued
correctly) at, or above, the MEA of the route to be flown.
It's up to you, as the pilot, to fit the ODP with your filed or clearance
route. This ODP is 40:1 clear once above close-in obstacles. Apparently
the procedures specialist decided the close in obstacles were too hazardous
to be overflown with a climb gradient, thus the ceiling and visibility
minimums.
Although Part 91 operators are not required to use takeoff minimums anyone
who ignores mandatory ceiling/visibility minimums (as opposed to standard
takeoff minimums) can be placing himself in harm's way, especially at an
airport where he lacks detailed local knowledge about the airport and
close-in obstacle hazards.
A case in point quite a few years ago was at KLGB (Long Beach, California).
At about 3:00 AM a guy taxis out in an Aztec and wants a climb to on-top
because the weather is basically zero-zero in ground fog. He wanted Runway
16L, which had a 600-1 mandatory (for commercial operators) take-off
minimum. The controller tried to convince the pilot to instead use Runway
30, the ILS runway with standard takeoff minima (actually,
lower-than-standard for commercial operators because of lots of runway
markings and lights).
The pilot got his way and shortly after takeoff at about 500 feet, above
airport elevation, he crashed into a giant natural gas steel structure,
then, in a burning remains of an Aztec nose-dived into a warehouse, through
the roof onto the concrete floor.
I remember it well, because I did some work on that needless, senseless
tragedy.
The 600-1 takeoff minimum for Runway 16L was for the natural gas storage
tank and associated steel structure.
Iowa City Airport in the News John Galban Piloting 40 April 17th 05 04:41 AM
Iowa City Airport in the News Dave S Piloting 0 April 6th 05 11:24 PM
SWRFI update... Moving again (argghh!!)... Dave S Home Built 14 October 15th 04 04:34 AM
Please help -- It's down to the wire Jay Honeck Owning 24 July 14th 04 07:05 PM
Please help -- It's down to the wire Jay Honeck Piloting 18 July 14th 04 07:05 PM
