Barnyard--- Auto engines
Old August 8th 03, 06:38 PM
Larry Smith
"Corky Scott" wrote in message
On Fri, 08 Aug 2003 07:38:54 -0500, Barnyard BOb --
It will be interesting to find out how the fire was caused. I've
pointed out for years that the engines themselves rarely fail but the
ancillary parts can be problematic. If a fuel line broke because of
improper use of materials or using a solid connection rather than
something that flexes, that could cause a fire real quickly.
Even the professionally built Stewart S-51 had a number of engine
outs, none of them caused by the engine itself.
Corky Scott
Professionally built means what?
Squat?
Barnyard BOb -
No sorry, that wasn't what I meant.
What I meant was that the engine and installation was done by people
who knew and understood what was and was not airworthy.
Sorry I confused you.
Corky Scott
You didn't. You may have aggravated a pre-existing condition.
Keep us all posted on how the Ford is doing.
I'm working on an engine now with aluminum block. It's amazing how deck
height and bearing bosses and all the flanges and alignment can change, or
shift. But then the block is said to be seasoned and can be re-machined,
after which it usually is fairly stable.
I had a rear case on an A-65 dramatically change shape, so bad it had to be
hung up as a conversation piece, which I take to chapter meetings to show
how the bosses for the mags have cocked inwards about 7 degrees apiece and
the mating surface is no longer flat. It's magnesium, though. VW
successfully used magnesium cases for years and years, however.
LOM engines Salem Farm & Garden Home Built 2 July 22nd 03 11:30 PM
Single-rotor Mazda engines.... any flying our there? Pete Home Built 1 July 18th 03 01:50 PM
