#71
![]() "Steven P. McNicoll" wrote in message ink.net... "Ron Natalie" wrote in message . .. Mine are integegral to the comm. Not all of them are. Nobody said it had to be universal. You asked "what bizarre failure causes you to lose comm and transponder and still leaves you confident that your other avionics (presumably navigational gear) active?" And the answer is that most of us carry a GPS that is entirely independent of the aircraft electrical system. I've been twice in two different aircraft that have had the electrical systems go dead (and in the case of mine, we had several failures in a row). One was even IFR. In one case I had a GPS (and no backup comm) in the other case I had backup COMM (without NAV). |
#72
![]() "Ron Natalie" wrote in message . .. Nobody said it had to be universal. You asked "what bizarre failure causes you to lose comm and transponder and still leaves you confident that your other avionics (presumably navigational gear) active?" And the answer is that most of us carry a GPS that is entirely independent of the aircraft electrical system. I've been twice in two different aircraft that have had the electrical systems go dead (and in the case of mine, we had several failures in a row). One was even IFR. In one case I had a GPS (and no backup comm) in the other case I had backup COMM (without NAV). Follow the damn thread. The question was directed at someone who hypothesized losing comm radios and transponder but did not lose the nav radios. |
#73
![]() "Steven P. McNicoll" wrote in message ink.net... Follow the damn thread. The question was directed at someone who hypothesized losing comm radios and transponder but did not lose the nav radios. I am following the damn thread. Mr. Thomas was arguing that he would hold until the ETA in a lost comm situation. I agree with you that it doesn't make sense, but you then asked what sort of bizarre failure would (presumably, I'm interpretting here because you were terse as usual as to what you were specifically asking) let you navigate the hold once you've lost comm AND transponder. As several pointed out, lots of us have handheld GPS's either already out for situational awareness even if they don't use them for primary nav, or onboard for backup (or other VFR use). It's also not unheard of two lose complete electrical. It's happened to me in two different aircraft (one an alternator mechanical failure, and the other an electrical circuitry failure). So while it might make no operational sense to fly around in holds in a lost comm/transponder situation, it's quite possible in a existant part of the GA fleet to do so. |
#74
Regardless, a failed electrical system constitutes an emergency in my book. If that happens, I want to be on the ground ASAP,
and certainly before my handheld's batteries die. Last thing I want to be doing is changing batteries while hand flying (electrical system is gone, which also means no autopilot) in the clag. Using the emergency authority, I'm going to do whatever it takes to get me on the ground asap without taking undue risks. I'd rather fill out the paperwork than have to have my hiers fill it out. Ron Natalie wrote: "Steven P. McNicoll" wrote in message ink.net... Follow the damn thread. The question was directed at someone who hypothesized losing comm radios and transponder but did not lose the nav radios. I am following the damn thread. Mr. Thomas was arguing that he would hold until the ETA in a lost comm situation. I agree with you that it doesn't make sense, but you then asked what sort of bizarre failure would (presumably, I'm interpretting here because you were terse as usual as to what you were specifically asking) let you navigate the hold once you've lost comm AND transponder. As several pointed out, lots of us have handheld GPS's either already out for situational awareness even if they don't use them for primary nav, or onboard for backup (or other VFR use). It's also not unheard of two lose complete electrical. It's happened to me in two different aircraft (one an alternator mechanical failure, and the other an electrical circuitry failure). So while it might make no operational sense to fly around in holds in a lost comm/transponder situation, it's quite possible in a existant part of the GA fleet to do so. -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 |
#75
![]() "Ron Natalie" wrote in message . .. I am following the damn thread. Mr. Thomas was arguing that he would hold until the ETA in a lost comm situation. I agree with you that it doesn't make sense, but you then asked what sort of bizarre failure would (presumably, I'm interpretting here because you were terse as usual as to what you were specifically asking) let you navigate the hold once you've lost comm AND transponder. Here's the part of Mr. Thomas' message that you missed: If you are in IMC and loose communication then one should start any available instrument approach into the destination airport at the ETA within the filed flight plan (ETD + Time Enroute). If you're early and its solid IMC you hold. Simple as that. The reason for this is Air Traffic is expecting you to arrive at the airport at that ETA so they will have cleared the airspace in its entirity, expecting you to start any published instrument approach into the airport. This is particularly relevant if your transponder has also failed... how are Air Traffic supposed to know where you are? As several pointed out, lots of us have handheld GPS's either already out for situational awareness even if they don't use them for primary nav, or onboard for backup (or other VFR use). It's also not unheard of two lose complete electrical. It's happened to me in two different aircraft (one an alternator mechanical failure, and the other an electrical circuitry failure). Only a complete idiot would choose to hold until the ETA with a handheld GPS after an electrical failure. |
#76
On Wed, 17 Sep 2003 23:22:36 GMT, Newps wrote:
If it ain't on the enroute chart or the chart of the approach you are going to be doing it makes no sense to pull a holding pattern out of your ass from some other approach. C'mon. Don't hold back. How do you really feel about this? ![]() Mark Kolber APA/Denver, Colorado www.midlifeflight.com ====================== email? Remove ".no.spam" |
#77
Ray Andraka writes:
Regardless, a failed electrical system constitutes an emergency in my book. If that happens, I want to be on the ground ASAP, and certainly before my handheld's batteries die. Last thing I want to be doing is changing batteries while hand flying (electrical system is gone, which also means no autopilot) in the clag. Using the emergency authority, I'm going to do whatever it takes to get me on the ground asap without taking undue risks. I'd rather fill out the paperwork than have to have my hiers fill it out. No one is questioning your legal authority to do whatever. The discussion has been about what action is less likely to have your heirs fiilin out the paperwork. Ari. |
#78
So shouldn't we try to help the complete idiot?
Or are you trying to improve the gene pool? ---JRC--- "Steven P. McNicoll" wrote in message = ink.net... =20 =20 Only a complete idiot would choose to hold until the ETA with a = handheld GPS after an electrical failure. =20 |
#79
#80
![]() "John R. Copeland" wrote in message ... So shouldn't we try to help the complete idiot? By doing what? |
Screw hold repair in fabric? | Brian Huffaker | Home Built | 11 | May 29th 04 02:07 AM |
Need Hold Harmless Waver for Ultralight or Experimental Sale | Larry Smith | Home Built | 9 | August 19th 03 02:47 AM |
Need a Waiver/ Hold Harmless Agreement for UL / Experimental Sale | Richard_Tonry | Home Built | 2 | August 17th 03 12:58 PM |
