Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Restoration
restoring a DC9 restroom... at home
Old July 9th 05, 04:26 AM
Flyingmonk
A 15" medicine cabinet was designed to fit between standard 2x4 studs on 16"
centers. The blades dropped into the inter-wall space created by those
2x4s. A quick calculation for a medicine cabinet at 5' high, 15" wide,
3.5"
deep shows a space of some 3150 cubic inches. Assuming the blades
were
about 1" x 2" x 0.005, this gives a blade volume of.01 cubic inches.
You
could drop 315,000 blades into the slot before the space filled up. If
you
changed blades every other day, you had a little over 1700 years of
capacity.
That's assuming that they all fall flat and ended up end to end down at
the bottom of the space right?
Old July 9th 05, 04:44 AM
CJ Adams
"Flyingmonk" wrote in message
A quick calculation for a medicine cabinet at 5' high, 15" wide, 3.5"
were about 1" x 2" x 0.005, this gives a blade volume of.01 cubic inches.
You could drop 315,000 blades into the slot before the space filled up.
If
you changed blades every other day, you had a little over 1700 years of
capacity.
It's also just shy of 900 lbs. Which would give out first? Cubic capacity
or the structure of the wall?
Maybe its just as well that nobody's fixed for blades any more!
Cheers
CJ Adams
Arte et Marte
Old July 9th 05, 05:01 AM
Edgar
16"
3.5"
were
You
you
capacity.
Or left (depending on your viewpoint).
But, the perfect razor alignment is due to the earth shake.
  #24
Old July 10th 05, 08:28 AM
A quick calculation
you're hired. Now, second problem that's giving me nightmares....
How many "Sanitary Napkins" am I required to have in there?
  #25
Old July 10th 05, 07:49 PM
LCT Paintball
How many do you use?
  #26
Old July 10th 05, 08:20 PM
Edgar
"LCT Paintball" wrote in message
news:OcdAe.156158$nG6.130994@attbi_s22...
At least one (for that spot over the door where I keep smashing my head).
faa home study graduation certificate Falky foo Piloting 19 February 11th 05 12:38 AM
[Media] A Marine's journey home Michael Wise Military Aviation 0 May 3rd 04 05:57 AM
[Media] A Marine's journey home Michael Wise Naval Aviation 0 May 3rd 04 05:57 AM
Home Inspection Listings Patrick Glenn Home Built 4 April 26th 04 12:52 PM
N94 Airport may expand into mobile home community, locals supportive William Summers Piloting 0 March 18th 04 04:03 AM
