2-stroke diesel is the (near) future?
Old July 8th 05, 03:44 PM
Don Stauffer
mastic wrote:
1. Desiel injection timing is differant than on an Otto engine. The
fuel is injected during the intake cycle on the Otto engine and the
fuel is injected during the ignition cycle on the Desiel.
An Otto engine is any four stroke engine, diesel, gasoline, LPG makes
no difference.
And there is no "ignition" stroke. BTW, it is not ignition, or intake,
or combustion "cycle". There is only one cycle in either a four stroke
cycle or two stroke cycle engine. What is different is the number of
strokes in a cycle. Cycle means repeating operation. A two-stroke
cycle engine repeats its operation every two strokes, a four-stroke
repeats every four strokes.
I believe if we must shorten the terms then four-stroke and two-stroke
are better terms, because in both cases we are talking about what
happens in one cycle, not in two or four CYCLEs.
  #112
Old July 8th 05, 03:51 PM
Don Stauffer
Sport Pilot wrote:
mastic wrote:
Bryan Martin wrote:
Not so. In the Otto cycle, the fuel and air are introduced to the cylinder
during the intake stroke. In the Diesel cycle only the air is introduce to
the cylinder during the intake stroke, the fuel in injected at the end of
the compression stroke.
Wrong. Mr Otto invented the four stroke cycle and it is named after
him. The fuel or when it's introduced has nothing to do with it, Otto
refers to the cycle.
SO? He didn't mention fuel in the part you snipped. Diesel is a
differant cycle named after Mr. Diesel.
Actually, today's Diesels can operate over several cycle types. Modern
high speed Diesels as used in cars are closer to the Otto cycle than
they are to Rudolph's cycle. In his original engine the fuel was
supposed to be injected at a rate to create a constant combustion
temperature or a constant pressure. This really would take a feedback
of temperature or pressure during the combustion stroke, and was- and
is- extremely hard to do. The slower the speed of the engine, the
better current Diesels approach the intended Diesel cycle, as seen on an
indicator diagram. The indicator diagram on high rpm Diesel auto
engines look a lot like the diagram of an Otto cycle.
There are people developing Diesel systems using closed loop pressure
sensing to adjust fuel injection rate, but to my knowledge no Diesel car
or truck engine using this feature has ever made it to production.
Current production Diesels use open loop injection, so it is a hybrid
cycle, somewhere between true Otto and true theoretical Diesel.
  #113
Old July 8th 05, 03:58 PM
Sport Pilot
mastic wrote:
"MJC" wrote:
"Andrew P." wrote in message
link.net...
Wandering aimlessly about the Web, I heard Sport Pilot say:
You have most of it right. Some things you have wrong,
fuel is injected during the ignition cycle on the Desiel. On the
Desiel the fuel injection cycle starts just before TDC and ends well
after TDC. The fuel ignites as soon as it hits the hot air.
etc., etc. --- SNIP ---
It's Diesel, not "Desiel".
Andrew P.
Well if you're going to get picky, it's "Auto" engine, not "Otto" engine.
MJC
Picky, picky, picky. It's not an Otto engine as such. Otto is used to
refer to the standard four stroke cycle because Otto was good enough
to invent the four stroke cycle.
no difference.
Completely wrong, the Otto cycle has nothing to do with four stroke
engines. Don is right its not four cycle, I used it incorrectly. The
Otto and Diesel cycles are actually refering to the thermodynamics
chart of temperature pressure and volume, they invented their cycles on
paper and books, the engines we use are only close approximations. The
two stroke ignition engine uses the Otto cycle as it is has the four
phases of intake, compression, power, and exhaust, and the pressure is
not constant. The Diesel two stroke is a Diesel cycle because it also
includes the same phases and the fuel burns at a fairly constant
pressure.
  #114
Old July 8th 05, 04:09 PM
Sport Pilot
Here is an animated link showing the differances of the Otto and Diesel
cycles.
http://www.ulb.ac.be/sma/testcenter/...osedcycle.html
Notice the near instant burning in the example gives very nearly a
constant volume, in actual practice some compression is going on at
this time.
Also during a Diesel cycle it is hard to maintain a constant pressure,
it would actually drop off, especially near the end of the down stroke.
  #115
Old July 9th 05, 04:39 PM
Don Stauffer
pressure.
I guess I'd quibble with the statement that the Otto cycle has nothing
to do with four-stroke engines- it was the first successful cycle to
incorporate four strokes. yes, there are other four stroke cycles, but
the Otto cycle is still by far the most common. There have been several
other four-strokes, several two-strokes, at least on six stroke- I
suspect several also.
New IC engine designs are among the most numerous US patents. Just
because something is patentable, of course, does not make it good or
successful, and most of these patents were for approaches that offered
insufficient advantages.
BTW, as I understand the new Miller cycle, I don't consider it a truly
new cycle- just a clever mod on the Otto. I don't consider the Otto
cycle to require valve openings at closings at the top or bottom dead
center, exactly.
  #116
Old July 11th 05, 04:20 PM
Sport Pilot
pressure.
center, exactly.
The confusion is that Otto invented the first four stroke engine and
called it the Otto cycle, not because of thermodynamics but because he
put it in a motorcycle. However the thermodynamic cycle can be
reproduced with a two stroke engine. Its just that the intake and
exhaust cycle's are much shorter.
  #117
Old July 12th 05, 03:45 PM
Don Stauffer
pressure.
center, exactly.
I am not sure what you mean by exhaust and intake "cycles". There is
one cycle- the actions that the engine goes through before everything
repeats. Do you mean the portions of the cycle during which the exhaust
and intake take place- they definitely take less crankcase revolution angle.
In the Otto cycle it is easy to break it down into four operations, each
lasting one stroke. A two-stroke is more complicated, because it still
has (existing, contemporary ones, do anyway) four seperate functions of
intake, compression, combustion and exhaust, but have to do it in two
strokes.
  #118
Old July 12th 05, 03:54 PM
Sport Pilot
pressure.
center, exactly.
strokes.
Sorry for the confusion, the two stroke doesn't take a stroke for those
functions so I used cycle, can't think of anything else to call it.
  #119
Old July 12th 05, 10:55 PM
Morgans
strokes.
And some of the operations are happening simultaneously.
  #120
Old July 12th 05, 11:30 PM
Bill Daniels
"Morgans" wrote in message
news
strokes.
There is one very efficient 2-stroke variant that does have separate and
distinct intake, compression, combustion and exhaust functions - the
opposed-piston 2-stroke diesel with the pistons driven by cams, not
crankshafts.
As the pistons move apart (power), the exhaust port is uncovered first by
one piston (exhaust) and then the intake is opened by the other piston so
high pressure air from the supercharger can scavenge the last bits of
exhaust gas from the space between the pistons. After the cylinder is
scavenged, the first piston closes the exhaust port leaving the intake port
open so the supercharger can charge the cylinder with air (intake). Then
both pistons move together closing the intake port (compression). Fuel is
injected directly into the space between the pistons which forms a spherical
combustion chamber (ignition). The cams are designed to optimize the timing
and duration of the port openings as well as contour the compression and
power strokes.
This design makes extreme demands on metallurgy and lubricants so is just
now becoming practical.
Bill Daniels
2-stroke diesel is the (near) future? Max Kallio Home Built 134 July 18th 05 01:39 AM
BSFC vs gas mileage, 2 stroke vs 4 stroke Jay Home Built 10 August 24th 04 03:26 PM
Diesel Jodel information..........and .........diesel plane groups Roland M Home Built 1 January 4th 04 05:04 AM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M Home Built 3 September 13th 03 01:44 AM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M Rotorcraft 2 September 13th 03 01:44 AM
