Noise reduction
Old July 15th 05, 04:20 AM
David Findlay
Default Noise reduction
I'm in the early stages of the homebuilding disease :-P and still don't
know exactly what I want to build, just that I want to build something.
I'm interested to know what people have done in their aircraft to reduce
the interior noise level? Can such noise insulation be added to plan or
kit built aircraft without too much difficulty? Is it possible to reach
car or commercial airline jet noise levels in a homebuilt? Thanks,
David
Old July 15th 05, 04:23 AM
Robert Schieck
Build a glider g...
sorry , couldn't resist
Rob
Old July 15th 05, 04:58 AM
Kyle Boatright
"David Findlay" wrote in message
David
There are plenty of ways to reduce noise in a homebuilt, but unless you're
willing to go to extreme lengths, you'll have a hard time getting a
homebuilt down to the levels you mention. The 4 stroke rotax engines are
relatively quiet, so a design using one of those would be a good starting
point. Beyond that, you'd need to add insulation and go to thicker glass to
make a noticable difference.
Noise cancelling headsets are the most cost and weight effective method to
reduce percieved noise.
KB
Old July 15th 05, 05:18 AM
Jim Logajan
"Kyle Boatright" wrote:
aircraft to reduce the interior noise level?
you're willing to go to extreme lengths, you'll have a hard time
getting a homebuilt down to the levels you mention.
I'm curious about the noise aspect also and was wondering whether pushers
are any quieter or smoother rides than pullers?
Old July 15th 05, 08:49 AM
Smitty
David
There was a great article in the April 2005 issue of Sport Aviation (EAA
publication) entitled "Taming the Noise." It's a great article,
explaining the acoustic principles at work, and offering insights into
how to deal with many different types of noise in different ways.
Insulation is only one tool in the battle against noise. Taming the
source (i.e. prop and engine balancing,) preventing the transmission
(isolation mounts,) and absorbing the reflected noises (carpeting and
other upholstery) are some of the other measures discussed. The author
and his associates were able to reduce the noise in their "test
airplane" by almost 8 dB fairly readily, at a modest penalty of 23 lbs.
It's also important to have a well-sealed cockpit. Stop the air leaks
and you stop all of the direct noise leaks. The rest of the noise is
"just" transmitted noise that comes in the form of vibration.
Old July 15th 05, 02:20 PM
Corky Scott
On Fri, 15 Jul 2005 02:20:37 GMT, David Findlay
David
There's a LOT you can do to reduce noise in the cockpit. Most of it
has to do with proper use of insulating materials but there are other
things like taking extreme care in sealing things like doors and
windows. Using double panes in the side windows will help. Using a
thicker plexiglass for the windshield makes a difference and adds
value in bird strike protection. Putting an effective muffler on the
engine will help too. All this costs money and adds weight.
I recently added two mufflers to my V-6 engine mounted on the test
stand because I thought the neighbors would object to the very loud
barking of the headers while I ran it for extended periods. The
mufflers cut the exhaust noise to a muted burble, but the prop is
sounding loud now even though I haven't had it beyond 1,500 rpm yet.
I won't be able to use the mufflers in the airplane because they are
too big to fit. They are also too heavy. But there are other
mufflers that I could use that are much more slender and lighter when
the time comes to install the engine in the fuselage for good.
Corky
Old July 15th 05, 04:43 PM
Michael Pilla
"Corky Scott" wrote in message
David
SNIP
Corky
While building my RV-4, experienced builder/flyers strongly recommended that
I add very lightweight angle aluminum stiffeners along the long expanses of
unsupported aluminum sheet. These very thin strips of right-angle aluminum
stiffeners are intended to reduce the oil-canning and reduces noise from the
slipstream drumming along the sheet metal expanses.
Michael Pilla
Old July 17th 05, 12:43 PM
David Findlay
I'd be interested to know that too, because the main candidate aircraft for
me is a pusher prop one(The Aircar - it's a 4 seater wooden seaplane).
Thanks,
David
Old July 17th 05, 01:25 PM
George A. Graham
My airplane is fairly quiet inside. I borrowed a Db meter, and it
registered 82 in cruise IIRC, about the same as my van with the window
open. Mine is a pusher which may help, and it is built of foam and
fiberglass, not metal, which may also help.
We do wear headsets most of the time, but can talk without them if our
ears get tired of being clamped. I have no speaker installed, so can't
hear the radio without them.
George Graham
RX-7 Powered Graham-EZ, N4449E
Homepage http://bfn.org/~ca266
Old July 17th 05, 01:32 PM
George A. Graham
Egads, my memory is shot! I just checked my website.
The Db meter was 93 at 150 mph, and 97 at 185 mph.
Sorry about the misinformation. Still it seems quiet.
George Graham
Small plane noise is destroying my life Robert Morien General Aviation 5 December 1st 04 06:01 PM
Cherokee Strobe Noise Jonathan Goodish Owning 20 November 2nd 04 03:42 AM
Funny noise update Peter Duniho Piloting 1 July 1st 04 03:58 PM
Ear plugs and noise filtering Top Spin Piloting 12 January 16th 04 05:52 AM
Prop noise vs. engine noise Morgans Piloting 8 December 24th 03 04:24 AM
