#31
#32
On Sat, 06 Aug 2005 15:10:05 +0100, W.J. (Bill) Dean (U.K.). wrote:
In all normal flight the maximum lift, i.e. stalling, AoA is constant. However, at the very low speeds met with in light winds at the start of take-off and the end of landings, the stalling AoA is very much less. Whereas in all normal flight conditions, from 1G "stalling speed" to Vne, the stalling AoA remains constant at a figure probably between 16 and 19 degrees, at 5 or 10 mph it is around 10 degrees. This is interesting, it explains a lot. I would like to read up some more. Do you know of any references (perhaps on the net, or Reichman) that describe this effect? Also is there any "hysteresis" in this effect. In other words, if an airfoil is "flying" at say 12 degrees angle of attack, and you reduce the airspeed, to say 20 km/h, until it "stalls", not in the conventional sense - in that it is not producing lift to support the aircraft mass at 1G, but because the airflow separates and the co-efficient of lift deteriorates. Will the same airfoil, at the same angle of attack "unstall" if the speed is increased above 20 km/h, or will it require a higher speed, say 25 km/h before the airflow normalises and the expected co-efficient of lift returns? In my experience, in a glider with marginal aileron (or rudder) control, in a hot & high cross wind take off, it is better to keep the controls neutral until the glider has some airspeed before correcting for a wing drop (or yaw). If you immediately apply full control deflection then wait for the speed to build up, it seems to take longer before the controls "unstall" and become effective enough to correct the situation. (Either way the left hand is never far from the release...) Thanks Ian |
#33
"Ian" wrote in message
news
On Sat, 06 Aug 2005 15:10:05 +0100, W.J. (Bill) Dean (U.K.). wrote: In all normal flight the maximum lift, i.e. stalling, AoA is constant. However, at the very low speeds met with in light winds at the start of take-off and the end of landings, the stalling AoA is very much less. Whereas in all normal flight conditions, from 1G "stalling speed" to Vne, the stalling AoA remains constant at a figure probably between 16 and 19 degrees, at 5 or 10 mph it is around 10 degrees. This is interesting, it explains a lot. I would like to read up some more. Do you know of any references (perhaps on the net, or Reichmann) that describe this effect? Also is there any "hysteresis" in this effect. In other words, if an airfoil is "flying" at say 12 degrees angle of attack, and you reduce the airspeed, to say 20 km/h, until it "stalls", not in the conventional sense - in that it is not producing lift to support the aircraft mass at 1G, but because the airflow separates and the co-efficient of lift deteriorates. Will the same airfoil, at the same angle of attack "unstall" if the speed is increased above 20 km/h, or will it require a higher speed, say 25 km/h before the airflow normalises and the expected co-efficient of lift returns? In my experience, in a glider with marginal aileron (or rudder) control, in a hot & high cross wind take off, it is better to keep the controls neutral until the glider has some airspeed before correcting for a wing drop (or yaw). If you immediately apply full control deflection then wait for the speed to build up, it seems to take longer before the controls "unstall" and become effective enough to correct the situation. (Either way the left hand is never far from the release...) Thanks Ian I do not know of any references. We discovered this effect when we first flew the Slingsby Kestrel 19 at Lasham in the 1970s. We discovered that we had a low speed control problem on take-off; there were many theories as to why, and as to what to do. Then someone discovered that using negative flaps at the start of the ground run "worked", so we all did it without understanding why it worked. Later we were told it was a Reynolds number effect, which resulted in a lower stall AoA at very low speeds; my memory is that it was Derek Piggott (our Chief Flying Instructor) who told us, whether he worked it out himself or whether he consulted others such as Frank Irving I have no idea. I do not understand about Reynolds numbers, but I understand that they change with density as well as with speed, so that the behaviour of a glider at say 20,000 ft. at a 1 G stall may well be different to that at sea level at a 1 G stall. Also, I understand that model builders find that an exact model of a glider may fly differently from the real thing, because both the wing chord and the speed are different and it flies at a very different Reynolds number; I think that models cannot get as good an L over D as the real thing. I should be very surprised if there is any hysteresis effect as the speed changes. If you are using aileron when this results in tip stalling and lateral instability, you will have more to do when the aileron starts flying properly; just as if you use aileron when stalling in flight it can trigger a wing drop against the aileron moving down. I don't know what you mean by " "stalls", not in the conventional sense - in that it is not producing lift to support the aircraft mass at 1G,". The wing is either stalled or it is not. If it is stalled then an increase in AoA will produce a decrease in lift, and whether or not the lift at the stalling AoA is more or less than the weight of the glider is irrelevant. Those who cable launch must be trained and practiced at recovering from launch failures. A recovery from a break when in a steep climb may involve a push over to the recovery attitude during which the speed drops well below the 1G stall speed as you go over the top; provided the AoA is kept well below the stall AoA the glider is not stalled even though the wing is not producing enough lift to support the glider. I have no experience of "hot and high", the highest glider site in the UK is the Long Mynd at about 1,400 ft. It may well be that there is a change in behaviour at high density altitudes, either in quality or in relation to indicated speeds; but I would expect the same principals to apply. I think most glider handbooks give an indication of the maximum density altitudes flown when test flying (by implication the height at which the glider was tested to Vne). I suspect that glider flying in the hot and high parts of the USA may reveal things about a glider which the designers and test pilots did not know. W.J. (Bill) Dean (U.K.). Remove "ic" to reply. |
#34
"W.J. (Bill) Dean (U.K.)." wrote in message ... "Ian" wrote in message news
On Sat, 06 Aug 2005 15:10:05 +0100, W.J. (Bill) Dean (U.K.). wrote: Snip------ Those who cable launch must be trained and practiced at recovering from launch failures. A recovery from a break when in a steep climb may involve a push over to the recovery attitude during which the speed drops well below the 1G stall speed as you go over the top; provided the AoA is kept well below the stall AoA the glider is not stalled even though the wing is not producing enough lift to support the glider. Very true. I have no experience of "hot and high", the highest glider site in the UK is the Long Mynd at about 1,400 ft. It may well be that there is a change in behaviour at high density altitudes, either in quality or in relation to indicated speeds; but I would expect the same principals to apply. I think most glider handbooks give an indication of the maximum density altitudes flown when test flying (by implication the height at which the glider was tested to Vne). I suspect that glider flying in the hot and high parts of the USA may reveal things about a glider which the designers and test pilots did not know. W.J. (Bill) Dean (U.K.). Remove "ic" to reply. I have spent my whole flying career flying gliders and airplanes at very high and hot western US conditions and have never experienced or heard of any differences in handling or stall/spin characteristics due to high density altitudes. The noticeable differences are the faster ground speed at which the glider takes off and lands, the amount of runway required, the much lower rate of climb on air tow and the higher cross country speeds achievable in the high thin air. Of course, you need oxygen on almost every flight. Bill Daniels |
#35
On Sat, 06 Aug 2005 23:36:39 +0100, W.J. (Bill) Dean (U.K.). wrote:
I have no experience of "hot and high", the highest glider site in the UK is the Long Mynd at about 1,400 ft. It may well be that there is a change in behaviour at high density altitudes, either in quality or in relation to indicated speeds; but I would expect the same principals to apply. It's very simple, but very real. In a "hot & high" (low altitude density) take off, you need a significantly faster ground speed in before you gain control authority. However your average wing runner does not run any faster. Net result there is more time for things to go wrong between the time the wing runner lets go and the time the pilot has control. I used to fly off a narrow tar strip at 5200' altitude and 30 deg plus temperatures common in summer. The prevailing wind was 60 degrees off the runway, but fortunately not normally stronger than 10 knots. But when it did blow, we discovered many gliders have marginal control characteristics taking off in these conditions. Lots of time was spend briefing wing runners. They had to run the downwind wing (there is a natural tendency to hold the wing back a little which helps keep the glider straight). A skilled wing runner would start running with the wing held a little behind his back, then when he reached full speed he would allow the wing to overtake but still kept it under control until it was at full stretch in front, effectively add some speed to their run. Some guys would hold the wing by the leading edge then when they let go it would fly out from under their palm, allowing them to prevent it lifting up (which the downwind wing tends to do) for a short extra distance of the run. We lined up the gliders pointing to the downwind side of the centerline, so the weathercock effect would turn them straight. Tail wheels were better than skids. If you had one, you held the stick back to keep it on the ground (except if you had a V tail). C of G hooks were always more of a problem than nose hooks. The standard class guys often used airbrakes. Then off course the flap ships always started in negative flaps. But most important of all was to be ready to release when things went wrong. Sometimes it took two or three attempts to get a sensitive glider airborne in marginal conditions. So long as the run off area was kept clear and the pilot aborted at the first signs of things going wrong, there was no danger of damage. Regards Ian |
#36
#37
Ian Johnston wrote:
If I'm holding the tip before launch and, say, having to apply a significant up force, I let it go down about half way. Normally the pilot's reflexes kick in with some opposite aileron, the load comes off and I bring the wing up to level again. If that doesn't work I tell the pilot what the problem is. I instruct my wing runners to balance the wing, not hold it level. I've found some wing runners don't really know what level looks like when they are 50 to 60 feet from the other tip, and the wing is drooping because of the water weight. Wind and slight control deflections play a role, too, but if the wing is balanced, it won't drop. Being level is generally not important. If balanced is way off level, the pilot should notice something is wrong, and he should determine the cause. It might be the ballast is not equal, for example. I would rather not have the wing runner attempting to "correct" the situation. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
#38
Hi all, 1.I have a guess at the question of airbrakes improving low speed response-they simply deflect extra air around their sides, increasing the airflow over ailerons and wing root. 2.One point I must take issue with was in regards to Reynolds numbers. Qoute:"I doubt that. Turbulence is associated with high Reynolds number, and that depends directly on speed. Low speed - low Re - less turbulence." At low RE the boundary layer is much more easily transitioned to turbulent flow(In fact at RE=60,000 flow is considered critical and boundary layer attachmnent will fail), therefore turbulence is much more likely at low RE NOT high RE. Interesting that no one else noticed that eh? But as a modeller as well as fullsize pilot I have studied the effects of low RE a lot more I guess..... 3.I fly a Hornet often, an aircraft with I believe the same fuselage as the Mosquito, and it also shows the wing drop on ground run tendency, due to high AOA in the two point position. 4. Small chord tips at low speed may well be sub RE60,000, not creating ANY lift until RE60K is reached!(RE is proportional to speed, chord and air density). Regards & Safe flying to all Dave Lawley -- dav ------------------------------------------------------------------------ Posted via OziPilots Online [ http://www.OziPilotsOnline.com.au ] - A website for Australian Pilots regardless of when, why, or what they fly - |
#39
dav wrote:
1.I have a guess at the question of airbrakes improving low speed response-they simply deflect extra air around their sides, increasing the airflow over ailerons and wing root. Looking at top views of gliders, it appears the spoiler is always well inboard of the aileron, so I don't see how significant air can be deflected to them. With my ASW 20, the improvement occurred whether the airbrakes were open 10 mm or 50 mm, so I think the improvement is caused by spoiling lift rather than any deflected flow. Tufting the wing between the spoilers and ailerons would allow a direct check of the change in airflow. This could be done in a 20 mph wind, so the glider would not even have to be moving. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
#40
Once it starts moving, even slowly, the wing is producing lift. The
more lift is produced, the more difficult it is to cause a wing to drop, as this lift distributed over the whole wingspan damps a tendency to roll. Eliminate this damping by opening the spoilers and now the feeble aileron is able to cause a roll. Try this experiment: On a day with a light wind, sit in the glider while it's pointed into the wind. Starting from a wings level position, start rocking the wings. With the spoilers open, you will find that you are able to go steeper and make quicker reversals. If the wind is very light, it may all you can do just to keep the wings level. -Tom |
| Thread Tools | |
| Display Modes | |
| more radial fans like fw190? | jt | Military Aviation | 51 | August 28th 04 05:22 AM |
| ASW-20 flaps setting VS speed | AttentionLEcureuil | Soaring | 4 | March 10th 04 12:25 AM |
| Speed Astir | Guy Acheson | Soaring | 0 | December 11th 03 03:24 AM |
| Overweight takeoff / flight | Koopas Ly | Piloting | 50 | December 4th 03 12:53 AM |
| Flaps and V-Tails of Death | Wallace Berry | Soaring | 59 | November 26th 03 10:54 PM |
