light planes collide over Seattle?
Old August 6th 05, 09:12 PM
Neil Gould
Recently, Peter Duniho posted:
"Neil Gould" wrote in message
This aspect of the report confuses me, as well. If the aircraft were
on "nearly parallel" flight paths, how could the sun be much of a
factor?
No one has said that the sun *was* a factor. There simply have been
people who have suggested that it *might* have been a factor.
I see...
I would agree that the "sun in the pilot's eyes" and the "parallel
flight courses" possibilities are mutually exclusive, assuming that
the parallel flights were in the same direction. If they were on a
head-on course (and I haven't heard any suggestion that they were),
the sun and visibility generally could have been a factor.
I thought about the head-on course as a possible explanation to cover the
"sun in the...", but it seems to me that could only have been a problem
for one of the pilots. The other would most likely have had a hard time
not noticing the shiny object hurtling toward him.
Neil
  #42
Old August 6th 05, 09:31 PM
Peter Duniho
Well, as I mentioned in my previous post, "the sun should only have been a
factor for one of the pilots at most". This is true regardless of the
relative flight paths.
Pete
  #43
Old August 7th 05, 02:32 AM
George Patterson
Seth Masia wrote:
Agreed. A full stall landing isn't a good idea on floats, because it means
you come down on the tail of the floats -- and this could mean pitching
sharply forward and possibly going up and over. Instead, you want to settle
at minimum sink rate on the step, regardless of whether it's water, grass,
snow, plowed field or pavement, and come to as gradual a stop as possible
using the keels as your brakes. Which is exactly what happened in this
case. Bravo.
Have you *seen* the photos? There's no way you could bring that plane down on
the tail of the floats. The miracle is that the noses didn't dig into the grass.
George Patterson
Give a person a fish and you feed him for a day; teach a person to
use the Internet and he won't bother you for weeks.
  #44
Old August 7th 05, 06:41 AM
Seth Masia
No, I didn't see the photos. I'm just talking about floatplanes in
general -- stalling at low altitude is the last thing I'd want to do in a
floatplane, for exactly this reason. Do you have a link to the pix?
Seth
"George Patterson" wrote in message
newsEcJe.4152$eR.3067@trndny04...
means you come down on the tail of the floats -- and this could mean
pitching sharply forward and possibly going up and over. Instead, you
want to settle at minimum sink rate on the step, regardless of whether
it's water, grass, snow, plowed field or pavement, and come to as gradual
a stop as possible using the keels as your brakes. Which is exactly what
happened in this case. Bravo.
on the tail of the floats. The miracle is that the noses didn't dig into
the grass.
George Patterson
  #45
Old August 8th 05, 03:59 AM
George Patterson
Try http://images.ibsys.com/2005/0805/4812340_400X300.jpg
George Patterson
Boeing Boondoggle Larry Dighera Military Aviation 77 September 15th 04 03:39 AM
Parachute saves light plane's passengers randall g Piloting 0 April 9th 04 08:42 PM
The light bulb Greasy Rider Military Aviation 6 March 2nd 04 01:07 PM
