Mooney 201 prop
Old August 20th 05, 03:39 PM
Nathan Young
Default Mooney 201 prop
Walking out to my plane yesterday, I had the opportunity to walk
through a number of A/C to get to mine. I passed a Mooney (looked
like a 201) and realized that the width of the prop blades was
significant... It was much wider than my fixed pitch Sensenich,
wider than the blades on the Bonanza sitting next to it. In fact, it
had about the widest blades on the ramp (besides maybe a Navajo and
the turbines). So my question - why?
Blade width should create additional frontal drag. I would think you
would want to minimize that. A 201 has 200hp, so it isn't like it
needs to get several hundred HP transferred to the air.
Since Mooney's sit low, does this mean prop clearance is an issue?
Hence a short prop, hence a fat blade?
Inquiring minds want to know.
Thanks,
Nathan
Old August 21st 05, 05:40 PM
Frankie
You probably have it right.
From my observations, prop design seems to be more of an art than a science.
This topic is very confusing.
An interesting aspect of prop design is not only the chord shape but also
the number of blades. People generally think that more horsepower requires
more blades. But witness the Piper Malibu's two-blader (350 hp) and the
Piper Turbo Seminole's three-blader (180 hp).
Mooney's Ovation was initially sold with a three blade prop but later
changed to a two blade (Ovation 2) and it picked up 8 knots of airspeed.
Evidently this was due to the efficiency gains of the two blade, the same
reason it was chosen for the Malibu.
I believe three bladers are preferred for their reduced vibration, quiter
operation, greater low speed thrust, and appearance. Chord design probably
is the main factor in determining the efficiency of the prop regardless of
Frankie
Old August 21st 05, 11:31 PM
john smith
Look at the early P-47 Thunderbolt props and their performance.
Then look at the replacement prop and its performance.
Old August 22nd 05, 12:24 AM
Frankie
....not familiar with this example. Perhaps you could fill us in.
Frankie
Old August 22nd 05, 04:40 AM
George Patterson
Early P-47s had a fairly typical military prop when they first came out. The
planes were heavy for a single (over 7 tons). They had pretty good high altitude
performance, unbeatable dive characteristics, could take immense amounts of
punishment, but they didn't maneuver well (compared to planes like the Spitfire)
and they guzzled gas. Later in the war, the Thunderbolt was re-equipped with a
prop which had comparatively wide blades -- the pilots called it a
"paddle-blade" prop. Rate-of-climb and maneuverability immediately improved to
the point that a good Jug pilot could out-maneuver a Spitfire. Fuel consumption
also improved a bit. The prop simply made better use of the engine's power.
Not sure this is applicable to the Mooney. I suspect that the short legs on the
Mooney make a short prop necessary, so a paddle blade gets the best results.
Don't forget that a prop is essentially a rotating wing. Increase the width of a
wing and you will increase lift (at the expense of increased drag). When the
wing is your prop, that increased "lift" translates to increased thrust. With
the P-47, the plane had the power to make the increased drag unimportant.
George Patterson
Give a person a fish and you feed him for a day; teach a person to
use the Internet and he won't bother you for weeks.
Old August 22nd 05, 08:53 AM
Seth Masia
Specifically, here's the first XP-47 prototype with its conventional
four-blade prop: http://www.warbirdsresourcegroup.org...es/xp47j-1.jpg
And here's the late-war P-47D with the paddle blade prop. Note the cuffs
around the prop roots. http://home.att.net/~historyzone/p-47d-27-re.JPG
"George Patterson" wrote in message
news:qWaOe.2407$SW1.1776@trndny09...
The planes were heavy for a single (over 7 tons). They had pretty good
high altitude performance, unbeatable dive characteristics, could take
immense amounts of punishment, but they didn't maneuver well (compared to
planes like the Spitfire) and they guzzled gas. Later in the war, the
Thunderbolt was re-equipped with a prop which had comparatively wide
blades -- the pilots called it a "paddle-blade" prop. Rate-of-climb and
maneuverability immediately improved to the point that a good Jug pilot
could out-maneuver a Spitfire. Fuel consumption also improved a bit. The
on the Mooney make a short prop necessary, so a paddle blade gets the best
results.
width of a wing and you will increase lift (at the expense of increased
drag). When the wing is your prop, that increased "lift" translates to
increased thrust. With the P-47, the plane had the power to make the
George Patterson
Old August 22nd 05, 09:12 AM
Seth Masia
My mistake. The "XP-47" I found in the previous post is really an 1943
XP-47J speed-record prototype and it probably has a fat prop. I can't find
an online pic of the original prop -- I have plenty of books around here
that show it. The paddle blade prop increased high-altitude climb
performance by about 400 feet per minute.
"Seth Masia" wrote in message
four-blade prop:
best results.
George Patterson
Old August 22nd 05, 03:52 PM
Newps
How does a prop change make the plane more manuverable?
Old August 22nd 05, 04:54 PM
Matt Barrow
"Newps" wrote in message
Better thrust, acceleration...
Old August 22nd 05, 07:38 PM
Seth Masia
Steep bank=higher wing loading=more drag. More thrust means you overcome
the added drag. Think of it as having the thrust to pull through a tight
turn -- especially a climbing turn.
Right prop, wrong prop? Wood prop, metal prop? Gus Rasch Aerobatics 1 February 14th 08 11:18 PM
Ivo Prop on O-320 Dave S Home Built 14 October 15th 04 04:04 AM
IVO props... comments.. Dave S Home Built 16 December 7th 03 12:43 AM
Metal Prop vs. Wood Prop Larry Smith Home Built 21 September 26th 03 08:45 PM
New Prop on my Mooney Ovation Charles Talleyrand Owning 1 July 7th 03 11:30 PM
