Removing Decals
Old September 7th 05, 06:27 AM
Dan, U.S. Air Force, retired
Juan Jimenez wrote:
Hmm, shifts the CG forward a tad reducing the counterweight
needed up front, and thereby the total weight by a bit more too,
right? Or don't the 5js need a forward counterweight.
That's a very good observation. Yes, it does. On most BD-5J's you are
required to have some type of ballast on the nose, usually lead bars. On
Bishop's jets, the ones being used for surrogate cruise missile work for the
military, we resolved this by replacing the huge NICAD batteries with gel
cells and moving them forward behind the panel. We also moved just about
everything else that could fit in there. The specialists who did the
installation said they had never before managed to fit 2 pounds of **** in a
1 pound box. I can send you pictures of that installation if you like, it's
amazing. I designed the panel layout but the real work was done by the
installers.
OK, you bought the project 98% complete then pay other people to do
your work for you. Have you done anything at all on it?
  #82
Old September 7th 05, 03:19 PM
BobR
installers.
We sure know he hasn't flown it!
  #83
Old September 9th 05, 11:55 PM
Juan Jimenez
Juan Jimenez wrote:
N1 is the turbine rotation speed, expressed in percentage. This is a
plain-jane turbojet.
And what happens next after 'light off'?
Watch your EGT, don't let it go too high, slowly bring the RPM up to a
stabilized idle around 51-55%. ...
And after that?
You operate it as with any other turbojet, and monitor the instruments.
  #84
Old September 9th 05, 11:56 PM
Juan Jimenez
"Dan, U.S. Air Force, retired" wrote in message
newsEuTe.9726$dm.6283@lakeread03...
I worked on several jets with single spools. Not one used N1, it was
simply RPM.
Nothing I can do about ancient history.
  #85
Old September 9th 05, 11:57 PM
Juan Jimenez
news:tTuTe.9730$dm.314@lakeread03...
OK, you bought the project 98% complete then pay other people to do your
I can't help it if your reading skills will not allow you to read logs.
Maybe you can get your ex-wife to do that for you. Or are you paying someone
else to work on her?
  #86
Old September 9th 05, 11:58 PM
Juan Jimenez
"BobR" wrote in message
D-ooh! Yuk! You think, BillyBob!? chuckle
Removing water repelent from fiberglass lay-up? Roger Home Built 2 December 2nd 04 11:15 PM
You can now by water-slip inkjet decals by the sheet Charlotte Gaisford Restoration 0 November 8th 04 02:00 PM
You can now by water-slip inkjet decals by the sheet Charlotte Gaisford Aviation Marketplace 0 November 8th 04 01:59 PM
Removing old antennas Jay Honeck Owning 30 March 21st 04 04:34 PM
Info needed to make decals for missiles TJ Simulators 1 January 16th 04 02:29 PM
