Physics question
Old September 12th 05, 04:57 AM
RST Engineering wrote:
Several people, most of whom have at least had physics, and at least one
with a degree in physics have stated that you are wrong and why. Suggest
you read the thread before you post.
"BRO" wrote in message
With the correct lead the bullet and the ME-109 colide, at which point the
tragectory of the bullet is drasticaly altered such that it, and teh
ME-109 all fall/fly to earth as one mass.
No. With the _correct_ lead he can hit.
The _correct_ lead is different from how he would lead if
he was firing from a fixed position.
The _correct_ lead is incompatible with firing when the ME-109 is
directly behind the B-17. He cannot correctly lead the Me-109
AND fire when the Me-109 is directly behind the B-17. But he
CAN correctly lead AND fire straight back.
In fact, he correct lead if the ME is at a range of 50 yards,
when the B17 crosses the flight path of the ME-109,
is to fire straight back. Then he will hit when the Me-109
is fifty yards behind the B-17.
The problem is not with what he said, but with what he did
not say. He didn't say what part of the original problem
he was changing in order to introduce his new condiditon,
_correctly_ leading he Me-109. Maybe he didn't realize
there was an incompatibility, or mybe he thought it
would be obvious which statement he was dropping.
Which just serves to demonstrate the conventional wisdom
about assumptions.
FF
  #63
Old September 14th 05, 02:05 PM
CB
All 'a dem Fokkers wuz Messerschmits!
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 05:03 AM
Accurate plane performace? R Simulators 27 December 19th 03 04:54 AM
