Flying Lessons
Old September 20th 05, 08:36 AM
Steve
Default Flying Lessons
I'm considering taking up flying as a hobby. It's something I've been wanting to do
since I was a kid. The ultimate goal is to learn how to fly lear jets or should I say private
light jets. What flight training classes would I have to take and how many hrs would I
have to perform. I can pretty much fly as many times a week as necessary to get the
training my job schedule is highly flexible. I have noticed that most courses run from 5
to 7 k. To get a private pilots license. But what would it take to have the licensing to fly
a lear. And can those courses be taken right after getting my PPL. I saw where I could
get a PPL for 8,000 and get instrument training for another 6,000. Is there another
course needed to fly a lear and can all the classes be taken concurrently.
Old September 20th 05, 03:15 PM
Jay Honeck
wanting to do
hrs would I
to get the
courses run from 5
where I could
there another
As long as you've got the time and the aptitude, all it takes is money,
Steve. Lots and lots of money.
Getting type-rated in a Lear won't be cheap. I have no idea how much -- but
I'll bet a bunch of people here know!
Good luck!
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Dan Luke
"Steve" wrote:
...But what would it take to have the licensing to fly
a lear.
You will need an Airplane, Multi Engine Land rating and type rating for
almost any jet you want to fly. Both require instruction, written tests and
check rides.
Yes. In fact, you could do it all at the same time, but it would most likely
be impractical.
Dan
C-172RG at BFM
Old September 20th 05, 03:31 PM
Larry Dighera
On Tue, 20 Sep 2005 06:36:01 GMT, "Steve" wrote in
Actually, flying is a bit more than a hobby like Chess or wood
working, as an airman commands the public trust over those whom he
flies and whom he carries as passengers; flying is a life and death
matter after all.
It's something I've been wanting to do since I was a kid. The ultimate goal is to learn
how to fly lear jets or should I say private light jets.
Whose Lear jets are you planning to fly, you're own? Or are you
considering commercial operations for your hobby? You should be aware
they require two flight crew as well as a type rating and recurrent
training. Some light jets only require one pilot.
have to perform.
Flying jet aircraft is probably going to require a minimum of 500
hours of flight time and an instrument rating before an insurance
company will consider you.
A minimum of two 1-hour lessons a week is required for good progress
in flight training, in my opinion. There are cram courses that
guarantee you a certificate in only a matter of days, but I have no
experience with them, and personally wouldn't recommend them.
a lear.
It depends. Do you plan to do that commercially or privately? You
might want to peruse the FAA licensing regulations:
http://ecfr.gpoaccess.gov/cgi/t/text...14cfrv2_02.tpl
While it is not contrary to Federal Aviation Regulations to receive
that training concurrently with your Private Pilot training, it would
require significant time and effort.
I saw where I could
Why are you in such a hurry?
Old September 20th 05, 03:33 PM
Paul kgyy
Well, once you get your PPL and IR, you just move on to the
multi-engine by renting a Piper Seneca and working your way up to the
LJ, or go directly to the LJ. I hear they are not all that hard to
fly. I have no idea what the rental cost would be, but fuel alone for
those babies costs a mint. You'll probably have to rent from a flight
school, and they charge more than your local FBO who might have a twin
available for training.
As others have said, just a matter of time and money. I might also add
aptitude, since some people turn out to have no ability to fly.
Old September 20th 05, 05:03 PM
Jim Burns
If you can fly when ever you want, also meaning that you can pay what ever
it takes, you could realistically knock out your PPL and your Instrument
rating in 6-8 months. I'm sure others will say it can be done faster and
they'd be correct, but starting with 0 time you need to give yourself enough
time to actually learn and build experience. Multi-engine can be done in a
long weekend for under $1500. From there you can go to one of the
specialized type rating schools for the Lear work, however they may require
a minimum number of hours before you qualify to enroll.
My question would be who's Lear will you fly? With minimal hours in type,
you won't be able to rent one. If you buy your own, you will have problems
finding insurance. Best case scenario... you are independently very wealthy
and you can just buy a Lear and not worry about insurance. And you can also
afford the BEST training and you'll make recurrent training your top
priority.
Be careful. Do some self examination and understand your motivation. It can
be done, but learn how to do it safely and correctly. Do not let your need
for speed surpass your capabilities.
Thurman Munson, the Yankee catcher, had 516 hours TOTAL flight time, 33
total hours in Citations, and had owned 4 different airplanes during the 18
months that he was a pilot. Too much money. Too much airplane. Too much
speed. Too little experience. Touch and goes in a jet. The last one he
didn't use his checklist. First forgot to lower his gear, then he forgot to
lower his flaps. Way behind the power curve, too slow on final with the
flaps up, they sank into the trees. 516 hours TT 18 months more money
than experience.
Please be careful.
Old September 20th 05, 05:47 PM
Robert M. Gary
I"m not sure if you are saying "Lear Jet" because that's the jet that
comes to mind or if you like the Lear better than other jets. However,
there are several schools out there that have programs that get you
some jet time. All ATP is one example. For $43,994.50 you go all the
way from where you are today to having some jet time. However, if you
plan to earn back your money flying jets, it could take quite some
time. You'll likely spend the first 10 years or so of your professional
life teaching in single engine trainers before you have enough hours to
get hired flying jets.
-Robert
Old September 20th 05, 05:50 PM
How flexible is that schedule? You could go to an ab-initio school that
feeds people into the regional airlines in 12-18 months and get all the
ratings, and if you really want, you could get a job with a regional
and get line-qualified as a copilot (FO) in another year maybe, and
quit. They'll probably want you to pay for your training after that,
but if you've got Learjet kind of money that won't be a problem, and
the insurance companies will take you real seriously.
If you don't have quite that much time, you could pay to get a type
rating at FlightSafety and look for work flying right seat for check
couriers, that sort of thing, that don't require such a permanent
commitment, though it's still not going to be a cakewalk. You'll build
hours and get paid almost as much as you might make as an assistant
manager at a hot dog stand.
Also, you might want to consider whether you really need a turbojet
airplane... A Lancair Columbia will cruise over 200kts which makes
500-mile trips go plenty fast, and will cost you a hell of a lot less
in fuel and maintenance, and you can order one new from the factory for
half of what you'd pay for a clapped-out jet, and you can get insured
in one even as a VFR student if you're willing to pay out the nose. Of
course, if you're talking about 1000 mile trips in real weather,
nothing beats a jet, but even the brand-new very-light jets don't all
live up to that, especially when you put a couple butts in the seats.
-cwk.
Old September 20th 05, 05:58 PM
Steve Foley
Just for comparison:
I was talking to a friend of mine who is a corporate pilot. I spend $200 to
fill the tanks in my Cherokee 140. His company spends $7,000 to fill the
tanks in his Hawker.
"Steve" wrote in message
wanting to do
hrs would I
to get the
courses run from 5
where I could
there another
Old September 20th 05, 06:59 PM
Mike Rapoport
"Steve Foley" wrote in message
news:CkWXe.8108$LV5.2992@trndny02...
to
The difference is that the $200 is your money.
Mike
MU-2
Mountain Flying Course: Colorado, Apr, Jun, Aug 2005 [email protected] Piloting 0 April 3rd 05 09:48 PM
Interesting. Life history of John Lear (Bill's son) Big John Piloting 7 September 20th 04 06:24 PM
Interesting Resume (V Long) Bob Chilcoat Piloting 24 September 13th 04 07:44 AM
Ultralight Club Bylaws - Warning Long Post MrHabilis Home Built 0 June 11th 04 06:07 PM
the thrill of flying interview is here! Dudley Henriques Piloting 0 October 21st 03 08:41 PM
