Toasted my engine
Old September 21st 05, 01:47 AM
RST Engineering wrote:
If the airplane was going through an annual inspection, the IA should have
generated a list of discrepancies of what didn't pass and given that to
the owner. At that point the annual was complete.
I'm not sure what you are saying. That the airplane has a current valid
annual at this point? That isn't so. THe logbook should have contained
words to the effect that the aircraft was inspected on (date) and a list of
unairworthy items given to the owner or operator.
I was saying the annual inspection was complete and current at that
point and if there were any unairworthy items, they need to be attended
to. The IA had completed his duties and is no longer involved. Once he
signs off the annual inspection, whether airworthy or not, the
inspection is complete and current.
If the airplane is "ratty" but the mag switch(es) had been installed in
accordance with the type certificate in effect as of date of manufacture and
there were no subsequent ADs to change it, then the IA cannot on his own
hook declare them unairworthy.
Similarly, if the fabric punched "at the bottom of the airworthy scale" then
the fabric is airworthy. THe IA does not get to set a higher standard than
the FAA requires.
An ordinary A&P could then bring the aircraft back to airworthinness
condition without the need for the IA.
That's true, but the aircraft still does not have a current annual
inspection.
The inspection is current and complete, but not airworthy. That
inspection will be current for the next year and if it was not airworthy
it can be brought into airworthiness and flown during that time period.
The A&P has 0% authority with the inspection process.
I don't believe that there is anywhere where the FSDO could have demanded
anything except to do a ramp inspection after the aircraft had been
flying.
They can demand green cheese. What they get or are entitled to get are two
separate matters.
Old September 21st 05, 02:19 AM
RST Engineering
wrote in message ...
have generated a list of discrepancies of what didn't pass and given that
to the owner. At that point the annual was complete.
of unairworthy items given to the owner or operator.
I was saying the annual inspection was complete and current at that point
and if there were any unairworthy items, they need to be attended to. The
IA had completed his duties and is no longer involved. Once he signs off
the annual inspection, whether airworthy or not, the inspection is
(S)he cannot sign off the annual inspection. 43.11 (a)(5) is quite specific
as to what has to happen when the aircraft is inspected and not found
airworthy. If you have another section of the regs that countermands this
section, please post it. Otherwise I maintain that the inspection is
neither complete nor current.
The inspection is current and complete, but not airworthy. That inspection
will be current for the next year and if it was not airworthy it can be
Citation from regulation, please? Otherwise I maintain as above, not
current, not "in annual".
A&P, IA
Old September 21st 05, 02:28 AM
Bob Noel
"RST Engineering" wrote:
[a bunch of stuff snipped]
Maybe I haven't followed this thread well enough. Are you saying that
an Annual Inspection is not complete and valid if there is a list of
unairworthy items given to the owner? I don't mean to imply that the
aircraft is airworthy or "in annual", rather that the inspection was
finished and that any appropriate A&P could sign off the repair of
those unairworthy items (as appropriate), right? (In this case I'm
asking about a hypothetical case, not the specific stuff earlier in
the thread).
thanks
Bob Noel
no one likes an educated mule
  #24
Old September 21st 05, 02:58 AM
Cut from 43.11:
(5) Except for progressive inspections, if the aircraft is not
approved for return to service because of needed maintenance,
noncompliance with applicable specifications, airworthiness directives,
or other approved data, the following or a similarly worded statement--
``I certify that this aircraft has been inspected in accordance with
(insert type) inspection and a list of discrepancies and unairworthy
items dated (date) has been provided for the aircraft owner or
operator.''
The annual inspection is an annual inspection.
Whether or not it is "approved for return to service" is the outcome of
the inspection.
No other inspection is necessary for the next year.
91.409
Sec. 91.409 - Inspections.
(a) Except as provided in paragraph (c) of this section, no person may
operate an aircraft unless, within the preceding 12 calendar months, it
has had --
(1) An annual inspection in accordance with part 43 of this chapter
"and" has been approved for return to service by a person authorized by
§43.7 of this chapter;
The big word here is "and" for allowed operation of the aircraft.
"in annual" is a slang term for an annual inspection that has been
returned to service.
I think we're stuck on the term "annual" meaning two different things.
Cheers
Dave
A&P, IA
  #25
Old September 21st 05, 01:40 PM
Kobra
I'm not that knowledgeable about the internal details of the engines, so
could you explain how that bolt could get sheared off?
See my post about three lines up under . I found some info in
the Cardinal Flyers group.
Kobra
  #26
Old September 21st 05, 04:37 PM
Matt Barrow
Already gone from my screen...oh well!
"Kobra" wrote in message
Kobra
  #27
Old September 21st 05, 06:58 PM
RST Engineering
Probably so. I see where you are coming from. It has always been my policy
to neither charge for nor sign a logbook when there are unairworthy items to
be taken care of. I see your point -- but I don't operate that way.
In any case, refusing to sign a legitimate annual when the mag switch(es)
were in conformance with the type certificate and the fabric punched at the
lower limit of acceptable strength was unethical in the least sense of the
word.
Cut from 43.11:
operator.''
the inspection.
91.409
has had --
(1) An annual inspection in accordance with part 43 of this chapter "and"
has been approved for return to service by a person authorized by §43.7 of
this chapter;
  #28
Old September 21st 05, 07:14 PM
Steve Foley
Fuelers often ground airplanes. (Sorry, but I couldn't resist).
"RST Engineering" wrote in message
Oh, and BTW, mechanics cannot ground airplanes. IAs cannot ground
airplanes.
  #29
Old September 22nd 05, 12:39 AM
Robert M. Gary
Saying the engine has 800 hours doesn't really say much. I'd be more
interested in how many years since overhaul. There are a lot of planes
for sale out there with low time engines that have sat for many years.
I would not feel comfortable flying behind an 800 hour engine if it has
sat for 10 years.
-Robert
  #30
Old September 22nd 05, 12:41 AM
George Patterson
sat for 10 years.
I'm a little nervous flying behind one that has sat for 6 months.
George Patterson
Give a person a fish and you feed him for a day; teach a person to
use the Internet and he won't bother you for weeks.
Engine Balancing and Resonance Vibration Problem AllanFuller Owning 13 September 12th 05 01:51 AM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 07:42 PM
Car engine FAA certified for airplane use Cy Galley Home Built 10 February 6th 04 04:03 PM
What if the germans... Charles Gray Military Aviation 119 January 27th 04 12:20 AM
Real stats on engine failures? Captain Wubba Piloting 127 December 8th 03 05:09 PM
