#31
"Newps" wrote in message ... Matt Barrow wrote: Well knock me over with a feather!! Above 18,000 feet, where the separation is 1000 feet The separation is a minimum of 1000 feet, no reason I can't just give you more airspace. So where in the FAR' is there authorization for VFR ops above FL180? and AFAIK, VFR operations are definitely NOT allowed? The example given was 33,500 feet...RVSM air space. You won't be given an OTP clearance but then at 330 you wouldn't need that since you're hard pressed to find many clouds up there that aren't already thunderstorms. So you're saying one could operate VFR at FL330? -- Matt --------------------- Matthew W. Barrow Site-Fill Homes, LLC. Montrose, CO |
#32
The US mountains where 1500AGL is over 18K' are all in AK. There is also no
class A over the Aleution Islands. Mike MU-2 "Blanche" wrote in message ... Steven P. McNicoll wrote: "Blanche" wrote in message Uh....if you're between 18K and 60K in the US, then you are required to be on an IFR flight plan, hence only at even number altitudes. 33,500 is inappropriate. That's not correct. You're required to be on an IFR flight plan in Class A airspace, but not all airspace between 18K and 60K in the US is Class A. By the way, 33,500 IS an even number. My bad. I meant all thousands, not the half thousands that we're used to in VFR. Second my bad...what airspace in the US 18K and 60K is not Class A? Not counting the big mountain in Washington state. (sorry, can't remember the name) |
#33
It isn't a VFR op.
Mike MU-2 "Matt Barrow" wrote in message ... "Newps" wrote in message ... Matt Barrow wrote: Well knock me over with a feather!! Above 18,000 feet, where the separation is 1000 feet The separation is a minimum of 1000 feet, no reason I can't just give you more airspace. So where in the FAR' is there authorization for VFR ops above FL180? and AFAIK, VFR operations are definitely NOT allowed? The example given was 33,500 feet...RVSM air space. You won't be given an OTP clearance but then at 330 you wouldn't need that since you're hard pressed to find many clouds up there that aren't already thunderstorms. So you're saying one could operate VFR at FL330? -- Matt --------------------- Matthew W. Barrow Site-Fill Homes, LLC. Montrose, CO |
#34
"Mike Rapoport" wrote in message ink.net... It isn't a VFR op. VFR on top is not a VFR op? "Matt Barrow" wrote in message ... "Newps" wrote in message ... Matt Barrow wrote: Well knock me over with a feather!! Above 18,000 feet, where the separation is 1000 feet The separation is a minimum of 1000 feet, no reason I can't just give you more airspace. So where in the FAR' is there authorization for VFR ops above FL180? and AFAIK, VFR operations are definitely NOT allowed? The example given was 33,500 feet...RVSM air space. You won't be given an OTP clearance but then at 330 you wouldn't need that since you're hard pressed to find many clouds up there that aren't already thunderstorms. So you're saying one could operate VFR at FL330? -- Matt --------------------- Matthew W. Barrow Site-Fill Homes, LLC. Montrose, CO |
#35
"Matt Barrow" wrote in message ... So where in the FAR' is there authorization for VFR ops above FL180? There isn't any. The FARs tend to prohibit things, not authorize them. So where in the FARs is there prohibition of VFR ops above FL180? So you're saying one could operate VFR at FL330? Sure, as long as you're not in Class A airspace. |
#36
"Matt Barrow" wrote in message ... VFR on top is not a VFR op? No, it isn't. VFR-on-top is an IFR operation. |
#37
No, like Steven said, it is an IFR operation.
Mike MU-2 "Matt Barrow" wrote in message ... "Mike Rapoport" wrote in message ink.net... It isn't a VFR op. VFR on top is not a VFR op? "Matt Barrow" wrote in message ... "Newps" wrote in message ... Matt Barrow wrote: Well knock me over with a feather!! Above 18,000 feet, where the separation is 1000 feet The separation is a minimum of 1000 feet, no reason I can't just give you more airspace. So where in the FAR' is there authorization for VFR ops above FL180? and AFAIK, VFR operations are definitely NOT allowed? The example given was 33,500 feet...RVSM air space. You won't be given an OTP clearance but then at 330 you wouldn't need that since you're hard pressed to find many clouds up there that aren't already thunderstorms. So you're saying one could operate VFR at FL330? -- Matt --------------------- Matthew W. Barrow Site-Fill Homes, LLC. Montrose, CO |
#38
Actually VFR glider operations are frequently authorized above 18K' (in
class A). Near Minden, NV, ATC simply opens up blocks of airspace allowing gliders to soar in mountain waves. Mike MU-2 "Steven P. McNicoll" wrote in message nk.net... "Matt Barrow" wrote in message ... So where in the FAR' is there authorization for VFR ops above FL180? There isn't any. The FARs tend to prohibit things, not authorize them. So where in the FARs is there prohibition of VFR ops above FL180? So you're saying one could operate VFR at FL330? Sure, as long as you're not in Class A airspace. |
#39
"Mike Rapoport" wrote in message ink.net... Actually VFR glider operations are frequently authorized above 18K' (in class A). Sure, in accordance with FAR 91.135(d). "An operator may deviate from any provision of this section under the provisions of an ATC authorization issued by the ATC facility having jurisdiction of the airspace concerned." |
#40
"Mike Rapoport" wrote in message nk.net... No, like Steven said, it is an IFR operation. Well, Newps and a couple others have been saying that VFR on top at 33,500 feet was legit. (or at least they snipped the original statement). I agree with you that and hold that anything over 18,000 feet is strictly a IFR operation and conducted in 1000 foot increments (also that if someone is at a 500 foot intermediate level they are only passing through that altitude, not cruising. "Matt Barrow" wrote in message ... "Mike Rapoport" wrote in message ink.net... It isn't a VFR op. VFR on top is not a VFR op? "Matt Barrow" wrote in message ... "Newps" wrote in message ... Matt Barrow wrote: Well knock me over with a feather!! Above 18,000 feet, where the separation is 1000 feet The separation is a minimum of 1000 feet, no reason I can't just give you more airspace. So where in the FAR' is there authorization for VFR ops above FL180? and AFAIK, VFR operations are definitely NOT allowed? The example given was 33,500 feet...RVSM air space. You won't be given an OTP clearance but then at 330 you wouldn't need that since you're hard pressed to find many clouds up there that aren't already thunderstorms. So you're saying one could operate VFR at FL330? -- Matt --------------------- Matthew W. Barrow Site-Fill Homes, LLC. Montrose, CO |
| Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 03:24 PM |
| Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 12:35 PM |
| Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 03:37 AM |
| Washington DC airspace closing for good? | tony roberts | Piloting | 153 | August 11th 05 01:56 AM |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
