Nexrad versus on-board radar
Old December 19th 03, 04:10 PM
Wyatt Emmerich
Default Nexrad versus on-board radar
Flying back from Atlanta to Jackson, my Echo Flight finally received its
downloaded Nexrad data. It showed me flying right in the middle of a big
blotch of red. I look outside the window. I'm in light 40 F light drizzle
with ceilings of about 6000 above a broken 2000 layer. I turn on the
Bendix/King RDR 2000 on-board radar. It shows nothing. Nothing on the
stormscope.
Why the huge contrast between the on-board and the Nexrad return? Perhaps
the Nexrad was picking up water far above me, while the on-board was looking
ahead (I was at 5,000.)
Old December 20th 03, 08:33 AM
Tom Sixkiller
"Wyatt Emmerich" wrote in message
stormscope.
looking
Isn't Nexrad satellite based? In that case, you would be seeing the moisture
_above_.
Old December 20th 03, 02:24 PM
Dan Luke
No. It's radar based.
_above_.
NexRad sees precipitation returns.
Dan
C172RG at BFM
Old December 20th 03, 02:27 PM
Tom Sixkiller
"Dan Luke" wrote in message
Doesn't it have satellite overlays?
_above_.
So...why is he getting the returns he is?
Old December 20th 03, 02:28 PM
Dan Luke
Perhaps the Nexrad was picking up water far above me, while the
on-board was looking ahead (I was at 5,000.)
Perhaps, but I have seen persistant false weather depictions on my
WxWorks NEXRAD display a couple of times.
Dan
C172RG at BFM
Old December 20th 03, 07:02 PM
EDR
In article , Tom Sixkiller
_above_.
NexRad is the current ground based system. What he is referring to is
an uplink of the images.
Old December 20th 03, 09:18 PM
Dan Luke
What's are those?
_above_.
He's seeing false returns or artifacts of the process that creates the
NEXRAD composite or some fault in the system he's using to receive
NEXRAD. Also, I suppose it's possible that NEXRAD was showing some very
high altitude virga that his on-board radar was pitched too low to see.
Dan
C172RG at BFM
Old December 20th 03, 11:28 PM
Mick Ruthven
I've never used in-aircraft Nexrad. But the Nexrad images displayed on the
web by the National Weather Service has two modes, Precipitation and Clear
Air. When there isn't significant precip they use Clear Air mode that is
much more sensitive and will displays colors without any precip. Don't know
if that applies to the in-aircraft version.
stormscope.
looking
Old December 21st 03, 03:57 AM
McGregor
Most likely the answer. Check the DBZ scale, if it starts with negative
numbers the radar is in clear air mode. In precip mode it starts at 5 dbz.
"Mick Ruthven" wrote in message
know
Old December 21st 03, 05:10 AM
Dan Luke
Is it possible that it's something like doppler where they have a
sensativity setting, and when it's not raining all that hard they
crank up the sensativity which creates returns for moisture that's
really, really fine?
In the case I described, there was no precipitation at all.
Dan
C172RG at BFM
EAA Board Of Directors (Here We Go Again) RST Engineering Home Built 32 January 21st 05 10:46 PM
Uplink weather advice Richard Kaplan Instrument Flight Rules 15 September 1st 03 12:39 AM
Marine Radar in a plane? Jay Honeck Home Built 31 August 13th 03 07:56 PM
