odyssey battery
Old September 27th 05, 05:37 PM
Philippe Vessaire
Default odyssey battery
Hello,
Is someone use odyssey battery for a Continental O200?
what ref do you use?
The PC680 seems a little oversize.
Thanks
Pub: http://www.slowfood.fr/france
Philippe Vessaire Ò¿Ó¬
Old September 27th 05, 10:25 PM
Drew Dalgleish
On Tue, 27 Sep 2005 17:37:49 +0200, Philippe Vessaire
Hello,
Thanks
I'm using a 680 to start my lycoming 0-290. It replaced a motorcycle
battery that was bigger and had less power. A bit oversize maybe but
I'm very happy with it.
Old September 27th 05, 11:11 PM
Reggie
Local: Tues, Sep 27 2005 8:37 am
Subject: odyssey battery
Thanks
We use a PC680 on a hi compression , 100 in^3 ,4 cycle.engine.
Has enough capacity to run the starter for 30 sec,and supply all the
power to the avionics for longer than we have fuel.
It's been doing this for more than two years with no noticeable
loss of capacity.
BUT you need to know the starter stalled amps, cranking amps,main buss
amps, secondary buss amps, and insure that regulator charging voltage
conforms to the limits set by Odyssey.
The Harley MC uses a PC545....Tiny little thing........
Reggie
Old September 28th 05, 04:20 AM
I put a PC680 on my C-85 Fly Baby about two years ago, and it's doing fine. I
replaced a standard aircraft battery, so the "oversize" PC680 was actually quite
a bit smaller than the one I took out.
I posted the details of my PC680 conversion to the Fly Baby mailing list. Skim
to "Installing My Odyssey Dry Cell" on this web page:
http://www.bowersflybaby.com/tech/battery.html
Once I got my starter clutch replaced, the PC680 cranks the engine quite nicely.
Old September 28th 05, 11:48 PM
abripl
Ron,
I use the PC680 to start my 200HP, high compression (10.5 to 1)
Franklin engine. I have a second battery PC925 for avionics, etc. About
two years old both, no problems so far.
SQ2000 canard: http://www.abri.com/sq2000
Old October 6th 05, 03:19 AM
Juan Jimenez
Scott Manning uses two 680's on his Canadian Stinger BD-5J Microjet that
he's currently flying in the airshow circuit. But he's going to be taking
them out and going back to NICADs soon.
"Philippe Vessaire" wrote in message
Hello,
Thanks
Battery Question [email protected] Soaring 19 September 15th 05 02:38 AM
Batteries, charger for Yaesu handheld - NiCad or NiMH? David Herman Owning 10 November 7th 04 05:30 PM
14 Volt Gel Cell? Joe Allbritten Soaring 32 May 11th 04 02:37 AM
Icom A5 Battery Tester ?? Harry Gordon Piloting 5 January 10th 04 02:29 PM
Odyssey Battery-Jerry Springer Badwater Bill Home Built 35 September 7th 03 06:17 AM
