Shotgun Starts
Old September 30th 05, 11:11 PM
Dick
Default Shotgun Starts
Was talking with some WW2 guys who remembered the use of 10 gauge shotgun
shells to start an aircraft engine. I've seen several movies showing
something but my question is how did it work? shell in seperate cylinder
from pistons and how push crank over, etc??
Old September 30th 05, 11:35 PM
Lakeview Bill
From what I have read, the output of the firing mechanism, which was really
only a large column of moving air, was fed directly into one of the existing
cylinders.
If you can get your hands on a copy of the original version of "The Flight
of the Phoenix", there's a scene where Jimmy Stewart (who had been a B-24
bomber pilot in WWII), is trying to start a cobbled-together aircraft with a
shotgun starter. He only has a limited number of shells; naturally, it
starts on the last one.
BTW: Did you know that ejection seats were once powered by cannon shells?
"Dick" wrote in message
t...
Old September 30th 05, 11:40 PM
wright1902glider
Its called a Kauffmann (sp?) starter. The blast turns a turbine thats
geared in to the crankshaft somehow. See the movie Flight of the
Phoenix... the original w/ Jimmy Stuart, not the gawd-aweful remake.
Harry
Old September 30th 05, 11:45 PM
Robert Bates
Is it an inertia type starter? I've never seen one but I always assumed
that it was like the air start on the M14P.
"wright1902glider" wrote in message
shotgun
Harry
Old October 2nd 05, 07:36 AM
J. Severyn
Try this link for info:
http://www.sjvls.org/bens/bf010cs.htm
J. Severyn
KLVK
t...
Old October 3rd 05, 04:04 AM
Accessory Section 8
It's a Coffman, or Eclipse starter. Gun gases spun a wheel, which
could also be spun by hand or foot treadle, an electric motor, or other
means in some versions.
They were not totally unique to aircraft, a few were used in military
vehicles and other oddball applications.
They were generally junked and replaced by direct drive electric
starters when they became available.
Cartridge start was also used on jets. Various bombers and fighters
have had cartridge start, as did some civilian aircraft. Boeing 727s
sometimes had cartridge start on the center engine (don't ask me how I
know...) so the aircraft could start if it diverted to a field with no
start cart. You had one shot, then you called out the recovery team. I
think United had a Lear for things like that, otherwise, another
revenue aircraft had to be internal-chartered, if no other airline had
a maintenance presence on field.
Old October 3rd 05, 04:42 AM
Flyingmonk
Cool, I knew/heard about these cartridge starters, now I know about the
third engine on the 727.
Thanks for the additional info.
Bryan "The Monk" Chaisone
Old October 3rd 05, 04:12 PM
jmk
The British Camberra used them. It's a high altitude spy plane that we
licensed the design for, so that we could turn it into the U-2. One of
the changes we made was to get rid of the cartridge start, because the
huge mass of black smoke was considered "not high tech."
Old October 3rd 05, 07:12 PM
Orval Fairbairn
In article .com,
Canberra and U-2 were totally separate aircraft! U-2 was a
single-engine, indigenous Lockheed design, based on high-performance
sailplanes of the day.
Canberra was a twin-engined British design for a high-altitude bomber.
The Martin Co. modified the Canberra into the B-57; the special
reconnaisance aircraft was the "RB-57D/E," which looked somewhat like
the B-57, but with much longer wings and different engines.
Old October 3rd 05, 08:09 PM
I understand that the U2 was based on the F104 Starfighter.
Seemed unlikely to me too but then I compared the Fuselages.
Toronto Area Glider Pilot Ground School Starts Thu. February 24, 2005 Ulf Soaring 0 February 3rd 05 07:16 PM
EAA Airventure 2005 Starts on a Monday Fitzair4 Home Built 9 September 21st 04 04:04 AM
Air Force Raptor fighter starts operational trials, By John J. Lumpkin Otis Willie Military Aviation 0 May 1st 04 11:18 PM
Training starts with aerospace physiology Otis Willie Military Aviation 2 December 4th 03 12:03 PM
Toronto Area Glider Pilot Ground School Starts Wed. November 19 Ulf Soaring 0 November 1st 03 12:09 PM
