Why are non precision approaches not lined up?
Old October 6th 05, 09:27 PM
Stan Gosnell
Greg Farris wrote in
The title just about says it - I've always wondered WHY many
non-precision approaches (not talking about LOC only here, but VOR,
VOR/DME, NDB etc) are not lined up with the runway heading. Sometimes
it looks as though the approach desginers have gone out of their way
to make sure the non-precision approach is just a few degrees off - as
if to say - "look stupid - this is not a precision approach . . ." But
if this were so, then we would have to wonder why SOME of these
approaches ARE lined up and straight-in. I'm surev there's a simple
explanation that will be pointed out here.
The term 'precision approach' refers to having vertical guidance (a
glideslope), not to the runway alignment. A precision approach does
have to be aligned relatively closely, but not precisely. I can't
recall the exact number of degrees off the top of my head, but it's not
exact. Even if a non-precision approach is perfectly aligned with the
runway, it's still a non-precision approach, because there is no
glideslope. An ILS without a glideslope, which becomes a localizer
approach, is a non-precision approach.
Regards,
Stan
"They that can give up essential liberty to obtain a little temporary
safety deserve neither liberty nor safety." B. Franklin
Old October 6th 05, 09:32 PM
Dave Butler
Greg Farris wrote:
Nope - Look at the VOR 14 approach to ITH (Ithaca New York - Just
grabbed the book and picked that one by chance). The VOR is on the
centerline, the runwya heading is 144.6° and the VOR approach is 133°. When
you break out, you have to turn 11.6° right to land. I don't see why they
couldn't have published it right on the 145° radial.
The VOR is on the centerline? I gotta get my eyes examined.
Old October 6th 05, 09:34 PM
Paul Tomblin
The VOR most definitely is NOT on the centerline. Look at the airport
diagram on that approach - it's a hundred feet or more from the
centerline.
Because then you would never cross the extended centerline, but would be
that same distance (a hundred feet or more) to one side. I'm guessing
that in a case like this they want the course to cross the runway
centerline some specific distance from the runway. Even ROC's VOR/DME 4
(an approach which I've never heard used in 10 years of being based at
ROC) is offset a tiny bit.
Paul Tomblin http://xcski.com/blogs/pt/
I read [.doc files] with "rm". All you lose is the microsoft-specific
font selections, the macro viruses and the luser babblings.
-- Gary "Wolf" Barnes
Old October 6th 05, 09:57 PM
Tauno Voipio
VOR/DME, NDB etc) are not lined up with the runway heading. Sometimes it
looks as though the approach desginers have gone out of their way to
make sure the non-precision approach is just a few degrees off - as if
to say - "look stupid - this is not a precision approach . . ." But if
this were so, then we would have to wonder why SOME of these approaches
ARE lined up and straight-in. I'm surev there's a simple explanation
This has little to do with non-precision / precision classification.
If you can get hold of them, get some ILS approach plated for
Norway. There are ILS:es with approach path 60 degrees off
runway direction.
The approach path has to fulfill separation requirements for
both other flight procedures with protection zones and for
obstacle celearance.
Tauno Voipio
tauno voipio (at) iki fi
Old October 6th 05, 10:11 PM
Matt Whiting
It is due, at least in the cases I've seen, to the location of the
associated navaid, be it VOR or NDB. Sometimes they can't be sited on
the extended centerline of a runway, or possibly the navaid existed
prior to the airport. Aren't most GPS approaches lined up with a runway?
Matt
Old October 6th 05, 11:04 PM
Steven P. McNicoll
"Matt Whiting" wrote in message
news
No, the VOR is not on the runway centerline. It is several hundred feet
off to the side of the runway. Why they didn't use the runway heading for
this approach I don't know, but it could be for noise abatement,
obstruction clearance, or other reasons.
If they did that the MAP would be several hundred feet off to the side of
the runway.
Steven P. McNicoll
"Greg Farris" wrote in message
When you break out, you have to turn 11.6° right to land. I don't see why
they
You're apparently looking at the wrong airport. If you look at the plate
for the VOR RWY 14 approach at ITH you'll see that the VOR is not on the
extended runway centerline. Here's a link to the plate:
http://www.myairplane.com/databases/.../00779VG14.PDF
Old October 6th 05, 11:18 PM
Dave Butler
exact.
Here's an example of a precision approach that's not aligned with the runway,
the LDA Rwy 6 at ROA, Roanoke, VA. Terrain appears to be the motivation for the
misalignment.
http://www.myairplane.com/databases/.../00349LDA6.PDF
GPS/WAAS VNAV approaches and runway length Nathan Young Instrument Flight Rules 8 October 25th 04 07:16 PM
Closest SDF, LDA and LOC-BC Approaches Andrew Sarangan Instrument Flight Rules 17 June 5th 04 04:06 PM
The new Instrument Rating PTS C J Campbell Instrument Flight Rules 7 May 27th 04 01:35 AM
FS2004 approaches, ATC etc henri Arsenault Simulators 14 September 27th 03 01:48 PM
Garmin Behind the Curve on WAAS GPS VNAV Approaches Richard Kaplan Instrument Flight Rules 24 July 18th 03 02:43 PM
