#51
"Ditch" wrote in message
... Unreal. I just stood there with my mouth hanging open as I watched the Cessna float down the rwy, carrying power and touching down with about 300 feet of rwy Well OK, if you do not cut the power then you can run off the end of a 12,000 foot runway. But then that is not an instrument-flying issue; that is an issue with basic airplane control. -- Richard Kaplan, CFII www.flyimc.com |
#52
"Michael" wrote in message om... I suspect you're right - as long as there is really 5000 ft of landing distance available and no significant tailwind. However, lately I'm I would say an overrun cannot happen in a 172 on ILS into the wind or with calm winds as long as the power is cut at decision height. If the airspeed is high as discussed in this thread and the airplane is on the glideslope, then the airplane should be within gliding distance of the runway at decision height. As far as flying an ILS with a tailwind, I agree that could cause an overrun. I would also suggest that landing out of an ILS in actual IMC conditions with a tailwind is an exercise which should be attempted only by an experienced, advanced IFR pilot and/or with an experienced CFII on-board. In particular, a pilot who is uncomfortable flying a high-airspeed ILS with a headwind certainly should not attempt a tailwind ILS. -- Richard Kaplan, CFII www.flyimc.com |
#53
"Snowbird" wrote in message om... the last 3rd of a 6,500 ft runway. Dunno what the tailwind was -- nothing too startling (10-12 kts?) That is a very significant tailwind for landing; it would not surprise me if a 10 knot tailwind doubled your landing roll vs. a 10 knot headwind or if the total landing distance increased between 50% and 100%. -- Richard Kaplan, CFII www.flyimc.com |
#54
"C J Campbell" wrote in message ... Two lessons he 1) If the field is really at minimums, you have 200 feet to slow down to landing speed. That is not much time. Better you should be ready to land before you break out. 2) If you decide to go missed, then go missed. Don't change your mind just because you got a glimpse of the runway as you were flying overhead. -- Christopher J. Campbell World Famous Flight Instructor Port Orchard, WA I like to fly the ILS at or near the suggested climb speed in the 210 that comes out to be around 110kts using 10deg.flaps and gear down. Reasons are that in the case of a go around the transition from approach attitude to climb attitude is less of a change and the accelerations induced are minimal,. If anyone here has gone missed in the soup from minimal airspeed to a steep climb under hard acceleration I would suspect the effect to be disorienting at the least. Anything I can do to reduce unnecessary accelerations and maneuevers in IFR conditions seems to be a good thing. Slowing down from MDA shoulden't be a problem since most airports with ILS are usually long enough, full flaps, throttle back, and allow the plane to land. Sometimes there is a tendency on breaking out to try and force the plane down. I would be more concerned with speed control on a circling approach to minimums on a dark night with a crosswind. R.Wallace If you go around beating the Bush, don't complain if you rile the animals. |
#55
On Wed, 21 Jan 2004 21:56:10 -0500, Roy Smith wrote:
The graph doesn't go beyond a 10 kt tailwind; I can only assume Beech figured nobody would want to try a landing with any more :-) I believe that at air carrier airports (and, from personal experience, at BOS) ATC may continue using a runway with up to a ten knot tailwind. My first tailwind landing ever was done out of an ILS at BOS with about a ten knot quartering tailwind. But they have long runways (and I needed to be at the far end anyway to get to the GA ramp). Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
#56
Snowbird wrote:
Unfortunately, since many training ILS are done to a missed approach, landing from an ILS isn't something at which some instrument pilots get a lot of practice. That's why I do all my training approaches to a TGL. Which of course, means I don't get a lot of practice at missed approaches. I guess I ought to mix it up a little. Dave Remove SHIRT to reply directly. |
#57
"Richard Kaplan" wrote in message ws.com...
"Snowbird" wrote in message om... the last 3rd of a 6,500 ft runway. Dunno what the tailwind was -- nothing too startling (10-12 kts?) That is a very significant tailwind for landing; it would not surprise me if a 10 knot tailwind doubled your landing roll vs. a 10 knot headwind or if the total landing distance increased between 50% and 100%. Hi Richard, As far as I could tell, it didn't do a thing to my landing roll. What it affected, drastically, was the distance it took my plane to slow to landing speed and consent to stop flying. I'm very glad I had a CFI who had me try this. Experience is worth 1000 words. After doing so, I can easily see how an overrun accident (or loss of control if someone tried to force the plane to land) could occur on a long, ILS-served runway. One size definately does not fit all situations for ILS procedures. I don't think it's a great idea to fly ILS routinely at 60 kts -- as someone pointed out, the margin over stall is much lower and the configuration changes needed for correction much larger than at 90 kts. OTOH, a practice of never retarding the throttle until over the threshold (as I believe Rick Durden suggested) would IMHO definately be a bad idea on a shorter runway (say 5000-6000 ft) w/ a tailwind. And my advice to instrument students is: make sure you actually land out of a good number of ILS in a number of different circumstances, preferably ILS in IMC or at night. For that matter, make sure you land out of a variety of approaches. Cheers, Sydney |
#58
I would say an overrun cannot happen in a 172 on ILS into the wind or with calm winds as long as the power is cut at decision height. If the airspeed is high as discussed in this thread and the airplane is on the glideslope, then the airplane should be within gliding distance of the runway at decision height. Yes, that's true. However, I consider an immediate power cut at decision height to be poor procedure. The normal ILS is flown on a 3 degree glideslope. However, the power-off glide in anything approaching landing configuration (meaning gear down if retractable and at least some flaps) will be 7-10 degrees. So a power cut at DH means a significant pitch change at low altitude. Since most of the fleet has tractor props and conventional tails, the power cut will also cause a significant out of trim condition - nose down. In good vis and with a Skyhawk-class airplane, it's not a big problem. Try that trick in your C-210 or my PA-30 in less than a mile vis, and unless you've practiced it extensively and recently, the landing is goint to be very, very ugly - possibly ugly enough for maintenance bills. People have been known to drive the gear right through the wings doing this. Since my IFR students are either flying high performance singles or twins or expect to move into them, I just can't see teaching the procedure you seem to be advocating. I instead teach a gradual power reduction with retrim, such that the pitch attitude never really changes and the airspeed bleeds off gradually. Yes, it eats more runway and on short runway may require a speed reduction on the ILS, but it seems like a beter tradeoff. Personally, I slow to about 95-100 mph (not kts) on the ILS at about 300 ft, which seems like the best compromise between retaining the option for a single engine missed approach and allowing a landing with a tailwind on a short ILS runway. In a single engine plane, I see no reason not to slow down further out. I know that an ILS can be flown in a Bonanza at 90 mph in turbulence - I've seen an instrument student do it. As far as flying an ILS with a tailwind, I agree that could cause an overrun. I would also suggest that landing out of an ILS in actual IMC conditions with a tailwind is an exercise which should be attempted only by an experienced, advanced IFR pilot and/or with an experienced CFII on-board. Well, I like to give my student the necessary tools to handle it. Of course since I don't instruct renters and don't deal with FBO's, finishing in the minimum allowable 40 hours is not my highest priority - nor theirs. In particular, a pilot who is uncomfortable flying a high-airspeed ILS with a headwind certainly should not attempt a tailwind ILS. Now that I can agree with. A high speed ILS is certainly something I consider important. It's just that a high speed ILS and a tailwind landing on a short runway simply don't mix. Michael |
#59
#60
Umm perhaps an approach speed of 1.3 Vs or whatever is called for in the
POH for approach to land? Awww hell.. you got a point.. If you are comin down the ILS you probably have Southwest right on your tail trying to give you a Boeing enema and Approach is hollering at you to keep your speed up.. Would it be poor form to come down at the top of the green arc and just not use flaps then? Dave. Snowbird wrote: Dave S wrote in message hlink.net... While it IS poor form to come blazing down the ILS to 200 ft minimums in a skyhawk at 100 kts It is? Gosh, what's "good form"? Sydney |
| LSA Approach speeds | Ace Pilot | Home Built | 0 | February 3rd 04 06:38 PM |
| How much protection on approach? | Michael | Instrument Flight Rules | 20 | January 15th 04 06:58 PM |
| Completing the Non-precision approach as a Visual Approach | John Clonts | Instrument Flight Rules | 45 | November 20th 03 06:20 AM |
| Which of these approaches is loggable? | Paul Tomblin | Instrument Flight Rules | 26 | August 16th 03 06:22 PM |
| IR checkride story! | Guy Elden Jr. | Instrument Flight Rules | 16 | August 1st 03 10:03 PM |
