Commercial certificate question
Old November 7th 05, 12:49 AM
RST Engineering
Default Commercial certificate question
You only have a definition for "one hour after sunset" if you have a legal
definition of "sunset", and you don't.
"Jose" wrote in message
And, as we have said for a number of years, none of these "non-day" times
have a legal definition within the FAR.
Well, I don't know about that. "one hour after sunset" is used thusly in
the FARs and and is therefore a kind of "non-day" that is defined in the
FARs, though a name isn't given to it.
  #32
Old November 7th 05, 01:12 AM
Stan Prevost
That hinges upon what the definition of "definition" is.
"RST Engineering" wrote in message
times have a legal definition within the FAR.
  #33
Old November 7th 05, 01:35 AM
Doug
Me, I just look out the window. If it's night out, I log it as night.
  #34
Old November 7th 05, 02:55 AM
Jose
This is only true if "sunset" is a term of art. Absent such a
term-of-art definition, the generally accepted definition of the English
word would be used. I suppose there could be a question as to whether
the sun's image needs to be fully, partially, or not at all visible
would come into play. The fact that the sun itself can be below the
horizon when it is still visible would likely be ignored in this case.
I suppose to take your position further, we'd need a definition of "one"
(this is non-trivial), and "after" (which is also non-trivial for
sufficiently energetic turbine engine spac...er... aircraft.)
The word "hour" would also need a definition. This one is easier, as
the "second" is precisely defined as a certain number of vibrations of a
cesium atom under specified conditions, and there are sixty of them...
wait - we need a definition of "sixty".
And we need a definition of all the words used in all the aforesaid
definitions.
Man, I wish I were a laywer.
Of course, then I'd have to study law. I can think of fewer more odious
occupations.
Jose
Money: what you need when you run out of brains.
  #35
Old November 7th 05, 06:36 AM
Scott D
On Sat, 05 Nov 2005 13:31:14 GMT, Matt Whiting
Just seems like a whacky requirement to me at this point in my flying
career. :-)
Don't feel bad, I had a guy come to me with over 4000 x-c hours with
about 4500 total and wanted to do his initial commercial multi and we
had to drone through the sky for the 2 hour day and 2 hour night
requirements. I felt like a theft taking his money but we had to do
it to satisfy the requirements..
Scott D.
  #36
Old November 7th 05, 06:41 AM
Jose
What did you do with him to take advantage of the time?
Jose
  #37
Old November 7th 05, 12:20 PM
Matt Whiting
career. :-)
Scott D.
I don't feel bad. It will be flying after all! :-) I'd just rather
spend the time and money practicing the new stuff like chandelles, etc.
Matt
  #38
Old November 8th 05, 03:52 AM
Stan Gosnell
Jose wrote in news:Qbhbf.3995$Lv.1888
@newssvr23.news.prodigy.net:
Yes, there is nautical twilight and astronomical twilight
As Spock would say - "fascinating". What is the reason for all these
different twilights? (never mind, if the FAA can have two different
definitions of night, I might as well just go google myself.
Jose
Civil twilight is defined to begin in the morning, and to end in the
evening when the center of the Sun is geometrically 6 degrees below the
horizon. This is the limit at which twilight illumination is sufficient,
under good weather conditions, for terrestrial objects to be clearly
distinguished; at the beginning of morning civil twilight, or end of
evening civil twilight, the horizon is clearly defined and the brightest
stars are visible under good atmospheric conditions in the absence of
moonlight or other illumination. In the morning before the beginning of
civil twilight and in the evening after the end of civil twilight,
artificial illumination is normally required to carry on ordinary outdoor
activities. Complete darkness, however, ends sometime prior to the
beginning of morning civil twilight and begins sometime after the end of
evening civil twilight.
Nautical twilight is defined to begin in the morning, and to end in
the evening, when the center of the sun is geometrically 12 degrees below
the horizon. At the beginning or end of nautical twilight, under good
atmospheric conditions and in the absence of other illumination, general
outlines of ground objects may be distinguishable, but detailed outdoor
operations are not possible, and the horizon is indistinct.
Astronomical twilight is defined to begin in the morning, and to end
in the evening when the center of the Sun is geometrically 18 degrees
below the horizon. Before the beginning of astronomical twilight in the
morning and after the end of astronomical twilight in the evening the Sun
does not contribute to sky illumination; for a considerable interval
after the beginning of morning twilight and before the end of evening
twilight, sky illumination is so faint that it is practically
imperceptible.
Regards,
Stan
"They that can give up essential liberty to obtain a little temporary
safety deserve neither liberty nor safety." B. Franklin
  #39
Old November 8th 05, 08:55 AM
Steph
"Stan Gosnell" wrote in message
Jose
imperceptible.
And stars of the 6th magnitude ( the faintest naked-eye stars) become
visible at the zenith.........
  #40
Old November 9th 05, 01:25 AM
Scott
On Mon, 07 Nov 2005 05:41:56 GMT, Jose
Jose
Nothing really, We did go over the 530 and its functions but we
basically just punched a hole through the sky. He was already roughly
familiar with the plane as far as the characteristics so he was
comfortable with it.
Scott D.
question about instrument proficiency check Sylvain Instrument Flight Rules 14 October 20th 05 10:11 AM
another annoying commercial wannabe question... gatt Piloting 4 May 7th 04 01:37 AM
Self fly hire in the US Nigel Piloting 25 March 28th 04 10:20 AM
Question Commercial pilot BTIZ Piloting 7 February 22nd 04 05:49 AM
Another Addition to the Rec.Aviation Rogue's Gallery! Jay Honeck Home Built 125 February 1st 04 06:57 AM
