MAGNETO TIMING LIGHT Plans
Old November 13th 05, 05:15 PM
Roger
Default MAGNETO TIMING LIGHT Plans
I am looking for plans to build a Mag timing light with the buzzer that
changes pitch. I remember seeing plans in a Magazine. Maybe Sport Aviation.
Roger @MD43 C150E
Old November 13th 05, 06:14 PM
Darrel Toepfer
From my reply to your post in rec.aviation.piloting:
http://www.rst-engr.com/kitplanes/KP9910/KP9910.htm
Not sure about the pitch changing buzzer though...
Old November 13th 05, 08:51 PM
Roger
Thanks,
This is a big help.
Roger
"Darrel Toepfer" wrote in message
Aviation.
Old November 14th 05, 04:56 AM
nrp
I made a mag timer from an old transistor radio - one that had a 4 ohm
speaker. I connected two light test leads to the speaker voice coil
terminals & connected two more light leads to the radio output
transformer. The leads were commoned into their respective pair at two
remote alligator clip leads that could be attached to the magneto
terminal and ground. Tune in a noisy station & the sound can be
clearly heard only when the mag points are open. The change in sound
level (with Slick mags at least) is dramatic as the ponts close and
open.
I electrically "banged" the thing with the impulse many times without
effect, although I suppose a pair of back-to-back diodes back at the
transformer output would protect the radio circuitry under more trying
circumstances.
Jim Weir's RST thing below is more elegant but are the circuit boards
still available?
Old November 16th 05, 06:24 PM posted to rec.aviation.owning
The transistor radio for mag timing is really cool. Here's another
simple idea:
Drive the magneto from a 50 ohm output audio oscillator. The resonant
frequency of the coil and capacitor is around 1kHz. You can hear
the note from the mag coils.
When the points are open, you can tune for resonance by listening. It
will be the loudest then.
When the points are closed, the note will go away.
Takes an oscillator that will do about 5v into 50 ohms or you will have
trouble hearing it.
Bill Hale
MAGNETO TIMING LIGHT Plans Roger Piloting 4 November 13th 05 08:50 PM
HOW MANY GLIDER PILOTS DOES IT TAKE TO CHANGE A LIGHT BULB Mal Soaring 59 October 4th 05 06:39 AM
Timing light for electronic ignition Ron Home Built 4 August 20th 04 06:18 PM
internal timing of slick magneto Jerry Jensen Home Built 1 June 25th 04 08:59 PM
The light bulb Greasy Rider Military Aviation 6 March 2nd 04 01:07 PM
