Jet sailplane photos
Old November 15th 05, 07:30 AM
rich
Default Jet sailplane photos
Mike the Strike wrote:
I've seen the Silent jet fly a few times in Arizona and have to agree
that it's quieter than most piston-engine planes - certainly much more
so than our tow planes.
However, these small jets probably need to be made easier to use -
starting currently looks a bit finicky - and more powerful. On a hot
Arizona day, I'd need four of the little suckers to get me comfortably
airborne.
I have to agree that they could have an interesting future.
Mike
All in due time I'm sure, now for those retrofit STC's.
Rich
Old November 15th 05, 06:11 PM posted to rec.aviation.soaring
airborne.
They are currently most attractive to the lighter sailplanes, not the
pilots with a fully ballasted 15 meter racer. A really good fit might be
for sustainer-equiped gliders instead of self-launchers. For that
purpose, the easy operation, low weight, simple installation, low
maintenance, and (relatively) low cost would be ideal. The Silent, for
example, would only need one engine for sustainer use (and only 5
gallons of fuel for 1 hour operation), and noise at ground level
wouldn't be factor at all.
Glasflugel has announced a jet engine as an option on their 304S glider,
so maybe the future is "now" (or at least, "soon").
Eric Greenwell
Washington State
USA
Old November 15th 05, 08:46 PM posted to rec.aviation.soaring
airborne.
Eric Greenwell
Washington State
USA
That was Bob Carlson's idea. Instead of 75 gallons of water in my Nimbus 2C
wings, he asked, how about Jet-A? Instead of dumping ballast when running
out of altitude and ideas, burn it in the jet engines and come home. The N2
could cruise at over 100mph for 7.5 hours using Bob's twin jets.
Unfortunately, that 75 Gallons of Jet-A would cost $250 today.
Bill Daniels
Old November 16th 05, 12:13 AM posted to rec.aviation.soaring
Think how much a 750 mile (1000+ by car, each way) retrieve would cost
(with motels) - and how long it would take!
I'm also thinking about what would be involved in the tanks for that
much fuel, how you would get 75 gallons of Jet-A into it at the airport,
and if everyone at the airport would scatter when you arrived back to
land after a successful flight - with the 75 gallons still on board. And
also the conversations with the FAA about a glider with 75 gallons of
Jet-A. Life would be interesting, for sure!
Eric Greenwell
Washington State
USA
Old November 16th 05, 12:48 AM
bagmaker bagmaker is offline
Senior Member
First recorded activity by AviationBanter: Aug 2005
Bill Daniels[color+blue]
$250 for 12000 km flying? still sounds cheap!
I hate to throw spanners, but doesnt a micro turboprop fit the bill for us? Nothing I know of available, but.......
Wayne C.
Old November 16th 05, 05:50 AM posted to rec.aviation.soaring
"bagmaker" wrote in message
Nimbus 2C
running out of altitude and ideas, burn it in the jet engines and come
home.
The N2 could cruise at over 100mph for 7.5 hours using Bob's twin jets.
Wayne C.
bagmaker
I'm not sure how well the engine controllers work on these tiny jets but
they should allow them to be more efficient at higher altitudes. The
maximum range could be quite a bit more.
The micro jets are cool because they tuck into the fuselage so neatly and
the residual weight after the fuel is burned is low. Anything with a prop
is clumsy by comparison.
I'm sure they have a future in soaring.
Bill Daniels
Old November 17th 05, 02:20 AM posted to rec.aviation.soaring
The ECU's compensate for altitude automatically. The
engines do get somewhat better fuel efficiency at higher
altitudes. Unfortunately, single stage turbines suffer
some performance loss with altitude, requiring higher
RPM for the same thrust. Climb rates suffer, but true
airspeeds get better. The cooler temps at altitude
help a lot. In the next few weeks I'm hoping to get
into wave and see what kind of performance I get after
starting them up at 20,000' or so.
As for the finicky starting mentioned by Mike in Arizona,
that problem has been fixed. Turns out I had a bad
fuel preheat tube. I haven't had a balky start since.
I've also cleaned up the wiring and switching a lot.
Starting is very straightforward now. I'll likely
be back in Arizona in the spring to practice acro and
renew my low-level card.
Bob C
At 04:54 16 November 2005, Bill Daniels wrote:
'bagmaker' wrote in message
of water in my
Nimbus 2C
ballast when
home.
Bob's twin jets.
$250 today.
fit the bill for
Wayne C.
bagmaker
these tiny jets but
altitudes. The
Bill Daniels
Old November 17th 05, 03:56 PM posted to rec.aviation.soaring
Bob, my question is about approved types of fuel.
In the jet aircraft I fly, occasion use of av-gas is approved; however,
some aircraft have a limitation in their Flight Manuals as to how many
gallons of av-gas is allowable before a hot-section inspection becomes
mandated. Av-gas (100% or mixed) is useable in these aircraft for a
couple of reasons: as an emergency return-to-home fuel, and as a way to
control microbal growth in the fuel systems, particularly in tropical
environments.
The downsides of using av-gas in turbine engines are that it burns
hotter and deposits lead on the turbine blades (does the micro jet
engine use turbine blades and a containment ring?). The Lead deposits
reduce the engine's efficiency, and the higher exhaust gas temperatures
simply reduce the life of the components.
But when the chips are down, av-gas can be used...in jet-powered
airplanes. Thus my question: Can the micro-jet engine use av-gas?
Raul Boerner
Old November 18th 05, 04:14 AM posted to rec.aviation.soaring
Jet-A or kerosene are the only approved fuels. The
microjets use a small portion of the fuel to lubricate
the bearings, thereby eliminating oil pumps, reservoirs,
seals, etc. Jet-A and kerosene are better lubricants
than gasoline.
The jet engine pylon can be retracted while airborne.
After shutdown, the engines cool to a safe temperature
in about 30 seconds. I have video footage of the retraction,
but it's not on any of the short clips on the website.
Bob C
At 18:06 17 November 2005,
Bob,
In all of the great videos I've seen of you and the
jet-powered Silent,
I never saw you retract the engines in the air. Is
it impossible
because of temperature? Or is it just a coincidence
Thanks
Uri
as to how many
inspection becomes
aircraft for a
in tropical
environments.
that it burns
the micro jet
The Lead deposits
gas temperatures
jet-powered
use av-gas?
Raul Boerner
====---- Willow Grove NAS Airshow Photos 2005 ---==== SITE BACK UP TopGunHank Naval Aviation 0 June 4th 05 01:12 AM
Sailplane with Hawk/Eagle Photos Wanted Ken Kochanski (KK) Soaring 7 January 14th 05 08:02 PM
~ PHOTOS FROM THE FALLUJAH MASSACRE [won't find *these* photos on TekTeam26 Military Aviation 0 April 12th 04 02:49 AM
MT. DIABLO HIGH SCHOOL CONCORD, CA PHOTOS MT. DIABLO HIGH SCHOOL PHOTOS Home Built 1 October 13th 03 04:35 AM
FS: Aviation History Books Neil Cournoyer Military Aviation 0 August 26th 03 09:32 PM
