Go Back   Home » AviationBanter forum » rec.aviation newsgroups » General Aviation
GA to 8ohm Headphone Adapter Completed
Old November 18th 05, 03:37 PM posted to rec.aviation.misc
Default GA to 8ohm Headphone Adapter Completed
Having posted to this group before, I though I would just provide
the follow up.
I completed a transformer design - thanks for people who
posted in the group with information.
Instead of paying $75 - $150 for an adapter, I constructed
what is the equivalent of 500 ohm source impedance to
4 ohm (actually, 2 8-ohm earbuds in parallel) adapter.
I've tested the unit and am quite happy with it.
I used a stereo 1/4" male adapter cable into a 3-piece
PVC tube assembly (2 end caps and a 3" piece - stock off
the shelf from Home Depot).
I used a Radio Shack $2.99 audio transformer and using
my old engineering days book, insured that I had the right
impedance transformation ratio.
Not including my labor (hee hee), I spent a grand total
of approximately $7 in parts.
In general, most aviation radios expect too see 200-ohm to 600-ohm
loads. Higher loads are typically fine, but lower isn't a good idea.
If one uses 16-ohm headphones or 32-ohm headphones (not uncommon
at all), the load impedance seen by the radio is higher.
This prevent excessive current loading, but higher will affect
"optimum" power transfer. It is safe, nonetheless.
The reason I did this: As an engineer and musician for a music company,
I have some very high-end custom molded, in-ear headphones that
I found are very comfortable and work very well in the plane.
Now - I have to obtain a boom mic to use . . .that hasn't been
as easy as it sounds for my "low budget" approach . . .
I thought some of you might be interested to hear how I finished that up.
Good flying!
Gary
Old November 19th 05, 12:00 AM posted to rec.aviation.misc
Shorty's used to sell one that was built inside a 35mm plastic film
container. Plug on one end, jack on the other. WAAAAYYY overpriced, of
course.
"Gary G" wrote in message
the follow up.
Gary
Old November 19th 05, 01:54 AM posted to rec.aviation.misc
And they stole the design from an article I wrote in Kitplanes some ten to
fifteen years ago on exactly the same subject with exactly the same design
with exactly the same parts, including the film canister.
"Michael Ware" wrote in message
course.
Old November 22nd 05, 02:29 AM posted to rec.aviation.misc
course.
Did you let'em know that you knew? :-)
Matt
Old November 22nd 05, 04:03 AM posted to rec.aviation.misc
One would think that you, being a ham, would have used one of
the aluminum canisters for RF shielding vice the modern plastic
unit. I can only assume that you told them the little trick of
getting the cap of the metal unit on?
-Gord.
(use gordon in email)
