"Somebody check your mike on the radio, please..."
Old November 21st 05, 06:27 AM posted to rec.aviation.piloting
Default "Somebody check your mike on the radio, please..."
"Jose" wrote in message
When entering a class-B, I call up approach at the appropriate time. I
will not be talking to ATC prior to that transmission.
An appropriate time is outside of class B, when approaching to enter. This
is the time we are discussing.
Better ratchet up that "wrong" counter one more.
George's comment was clearly with respect to the state in which the pilot is
*before* attempting to contact ATC. I think it's entirely plausible that
most VFR traffic would not already be in contact with ATC, prior to the
point in time at which they decide they need to contact ATC for the purpose
of entering the Class B airspace.
IFR traffic will be (but doesn't care about the boundaries of Class B
airspace anyway), and VFR traffic already in contact with ATC (because they
are using VFR radar advisories, for example) will, by definition, already be
in contact with ATC. But plenty of VFR traffic won't be, not until that
first call to ATC to ask to enter the Class B.
Pete
  #42
Old November 21st 05, 06:30 AM posted to rec.aviation.piloting
Thanks. Somehow I just wasn't getting that across.
George Patterson
If a tank is out of ammunition, what you have is a sixty ton portable
radio.
  #43
Old November 21st 05, 06:47 AM posted to rec.aviation.piloting
"Henry K." wrote in message
You'll never have to worry about ME doing that, Jay!
Henry, I thought you had a radio with some whizz bang options to allow you
to tell when the frequency was busy so you wouldn't step on others
transmissions.
  #44
Old November 21st 05, 07:47 AM posted to rec.aviation.piloting
You are correct, but I didn't read it that way. I read it as most VFR
traffic would not be in contact with ATC =as= they enter class B, or
within it.
Actually I thought I was wrong, but it turned out I was mistaken about
that.
Jose
He who laughs, lasts.
  #47
Old November 22nd 05, 12:32 AM posted to rec.aviation.piloting
And if the stack has an audio panel worthy of the name, the opposite
transceiver's audio is cut off during transmit to prevent an unholy squeal
coming down the audio line of the receiver that is still operating.
hmmm... what I had in mind was a split (pilot/copilot) stack, but upon
further thought the transmitter would overwhelm the receiver, even though
the receiver is not switched off.
ss.
  #48
Old November 22nd 05, 01:25 AM posted to rec.aviation.piloting
You sure? I've operated split (on different frequencies), and not been
cut off when the other pilot was transmitting. Does the audio panel
know what frequencies each radio is using?
Jose
  #49
Old November 22nd 05, 03:11 AM posted to rec.aviation.piloting
It has nothing to do with the audio panel. There is a "transmit
interconnect" wire between radios. It doesn't always get installed. I had to
have one retrofitted after completion of my Garmin 430---King KX-165A
installation.
Karl
"Curator" N185KG
squeal coming down the audio line of the receiver that is still
operating.
cut off when the other pilot was transmitting. Does the audio panel know
Jose
  #50
Old November 22nd 05, 03:31 AM posted to rec.aviation.piloting
installation.
With such an installation, wouldn't each pilot be frustrated while the
other pilot is transmitting, defeating much of the purpose of the split?
Jose
RIP Mike Valentine Mal Soaring 0 December 11th 04 09:27 PM
Changes in Instrument Proficiency Check Requirements Richard Kaplan Instrument Flight Rules 71 June 10th 04 09:02 PM
Why not use the F-22 to replace the F/A-18 and F-14? Guy Alcala Military Aviation 265 March 7th 04 10:28 AM
Radio silence, Market Garden and death at Arnhem ArtKramr Military Aviation 4 February 12th 04 01:05 AM
Use of hand-held GPS on FAA check ride Barry Instrument Flight Rules 1 August 9th 03 10:25 PM
