Wake Turbulence behind an A-380
Old November 28th 05, 02:13 AM posted to rec.aviation.piloting
Default Wake Turbulence behind an A-380
"Jay Honeck" wrote in message
"will descend further
and be significantly stronger" than those from other large jets,
potentially even affecting jets traveling in the opposite direction
some 2,000 feet below.
Who's authors haven't heard about RVSM- ICAO's or WSJ's?
D.
Old November 29th 05, 12:54 AM posted to rec.aviation.piloting
On Thu, 24 Nov 2005 at 08:56:56 in message
, Ron Garret
That's actually what keeps the plane in the air.
See http://www.av8n.com/how/htm/airfoils...ation-vortices
rg
That is a good article. I would partially disagree in that he minimises
viscosity of the air as a factor. True it is small, however if the air
had no viscosity then there would be no circulation and hence no lift.
He actually shows diagrams without circulation which produce no lift.
The necessity of viscosity was demonstrated by Jean le Rond d'Alembert.
In fact he did painstaking mathematics, without recognising viscosity,
and failed to be able to show why there should be any forces on a body
in an airflow at all. He went to his grave a puzzled and dissatisfied
man.
That is d'Alembert's Paradox.
David CL Francis
Old November 29th 05, 03:50 AM posted to rec.aviation.piloting
I know the jet you're referring to but can't remember it... however, I
do also remember that Herb Baker's T-28 has exactly the same system and
you can see a video of it he
http://herb-ditto.com/Herb.wmv
It makes for a very cool display.
Old November 29th 05, 05:14 AM posted to rec.aviation.piloting
In article .com,
Nice promo video.
Turbulence Marco Rispoli Piloting 19 October 17th 04 07:53 AM
Wake Turbulence Question HankPilot2002 Piloting 11 July 14th 04 05:49 AM
caution - wake turbulence John Harlow Piloting 1 June 4th 04 05:40 PM
Wake turbulence avoidance and ATC Peter R. Piloting 24 December 20th 03 12:40 PM
How much turbulence is too much? Marty Ross Instrument Flight Rules 8 August 21st 03 06:30 PM
