#21
Eric,
Do all Schleicher gliders lack carbon fiber above the baggage compartment? For example, is that true of my ASW-27 (sn 29)? How far back does the carbon free area go? If so, is that a reasonable location for a transponder antenna? I want to install a transponder, but I will not use an external antenna. Thanks, Bob Zahradnik Durango, CO Eric Greenwell wrote: mhr wrote: These questions are particularly pertinent to owners of experimentally certificated gliders since the owner can do all the work. As well, for owners of experimentally certificated gliders made of carbon fiber, a functional installation could be quite difficult unless the new antenna is mounted externally, which no racer would want to do. There are alternatives for the gliders that can not install an antenna in the fuselage, such as one in the cockpit; for example, I've seen rubber ducky type mounted on the cockpit sill even with the pilot's shoulder or more rearward. My unit is mounted like that, but with a whip style instead of the ducky style. Schleicher gliders are not carbon above the baggage area, so an antenna can be mounted there. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Two years ago Tom Brenza did a nice job installing an ELT behind the
seatback on the left. The whip antenna then curls up along the roof of the luggage compartment. I guess he knew that that section was not carbon. I've talked to John about this, and while he is usually very helpful, he had little transponder experience. The headreast idea may work for an ELT antenna, but my tired old brain doesn't need a transponder antenna transmitting right behind my head. Behind the spars would be ideal if it would work. Bob Zahradnik Durango, CO |
The last time I read it, ELTs are mandatory, not
optional at all, has this changed? '8. Required use of ELTs (RCM 26, 27, Minor) The use of ELT's will become a mandatory requirement for entry to all SSA competitions beginning in 2006.' I am waiting to see the # of entries in contests the first year this is implemented. I am especially interested in comparing the # of 'new' contest entrants in 2006 compared to the previous 3 years or so. I am guessing there will be more than a 20% decrease in total contest participants the first year glider-mounted ELTs are required in all SSA contests. I am also guessing that some classes/entire contests will be cancelled from lack of participation if this rule is fully implemented this way. But I've been wrong before. The fact that UH is responding to this thread makes me think that more flexible options are being well considered. Perhaps this rule will be morphed into a better solution. In any case, I am heartened to see lively discussion about this subject... I would like to see a new poll: Question-Are you in favor of mandatory requirement of permanently installed impact activated ELTs in every glider in every SSA soaring contest? Mark At 20:42 02 December 2005, wrote: Part of the research on this was a poll of contest managers and CD's who worked during 2005. On the subject of making mandatory 10 of 28 favored this. Of those saying no to mandatory, 12 said yes to making it available by organizer option. 6 said no to either option. This guidance, in addition to the Poll response, was considered in the decision to make the option available to organizers as a part of the rules without requiring a waiver. I'm not convinced all organizers will require them- far from it. Nor do I think they are sure to be sued since they will not be the cause of the accident. That said,I sincerely hope none of them has to answer the question 'Why did you not require this safety device when it could have helped save a life?' As a long time racer, and member of the rules committee, I personally can't see how to make any case for not requiring them. That said, I am in the minority on this and support the half way approach as what is to go forward. Have one friend missing for one night and you will understand. As to the assertion that this has not been thought through, this is simply not the case. You may not agree with the result, but I can assure you this has been considered with great care and in consideration of the opinions of many. Respectfully UH Mark J. Boyd |
Too much "chicken little" there, Mark!
I purchased and installed an impact activated ELT in my glider for less than $100 so I could race this past season. I doubt if the cost of an ELT is going to make the difference between racing and not racing for most people, especially since it is actually a potentially useful addition to one's glider! Let's see - $1000 for a logger, $3000 for a glide computer/vario, $750 for a PDA and software, $1500 for a nice comfortable parachute, etc... Racing isn't cheap - in any sport! I would think that anyone who can afford a glider and the cost of going to a race will be able to foot the one time expense of the ELT. Now, what we really need is FLARM in all contestants to actually try to avoid midairs! Kirk 66 |
#28
#29
Eric,
It's a Filser ELT-2, non-TSO european glider ELT. Fits over the spars in my LS6, with the rubber ducky (and on-off switch) just behind my headrest. W & W lists it for $219 or so - I ordered mine from a competitor (who doesn't seem to carry them any more) and paid half that. Lucky, I guess, since it was listed for $200 or so. I installed it myself on my battery tray - it happens to be the same size as my old (and deceased) GR1000 logger, and fit in the same mount. Its totally self contained, so no wires to fiddle with, and I don't have carbon fiber in the fuselage to worry about. I just arm it before takeoff and check 121.5 on my radio before and after flight. The point is - there are a lot of options out there - especially now that the TSO requirement will apparently be dropped - and cost shouldn't be a real hindrance. After all, you are adding a good piece of safety equipment to your glider that is probably as likely to save your life as your parachute! Kirk 66 |
#30
Eric,
I installed mine this past weekend, the antenna is located forward and under the instrument panel glareshield, attached to the rudder pedal bracket and installed within 20° of vertical as required by the manual. AmeriKing, $206 including shipping from Paul Remde. See details he www.jimphoenix.com Jim Eric Greenwell wrote: wrote: Too much "chicken little" there, Mark! I purchased and installed an impact activated ELT in my glider for less than $100 so I could race this past season. So, tell us what model it is, where your got it, and how you dealt with the antenna! -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
| Thread Tools | |
| Display Modes | |
| magneto installation help | Dick | Home Built | 5 | February 10th 05 04:02 PM |
| Skycraft Landing Light Installation Pix | Jay Honeck | Owning | 5 | February 6th 05 03:05 PM |
| Great deals on avionics installation kits and tools | Randy Cooper | Aviation Marketplace | 0 | January 14th 05 05:07 AM |
| Equipment Installation | Stan Prevost | Owning | 0 | November 16th 04 06:28 PM |
| Buying an L-2 | Robert M. Gary | Piloting | 13 | May 25th 04 05:03 AM |
