Cleaning Aluminum
Old December 14th 05, 06:32 PM posted to rec.aviation.homebuilt
Default Cleaning Aluminum
What is the best and easiest way to clean 6061-T6? I have a couple of sheets
that have some mild surface corrosion due to the paper they were wrapped in
got wet and I didn't know it.
Gig
Old December 14th 05, 10:04 PM posted to rec.aviation.homebuilt
Is your 6061 alclad?
Most of my sheet aluminum use is 2024, which is almost universally
alclad.
As you probably know, 6061 is more corrosion resistant than 2024.
If the corrosion is not deep or pitted, alodine it and go on. I. e.,
use phosphoric acid treatment to remove the stain and then passivate
the surface with a chromic acid etch.
Old December 14th 05, 11:12 PM posted to rec.aviation.homebuilt
alclad.
Thanks, there isn't any pitting at all just a surface layer of white powder
but it is hard to get off. 6061 rules!
Old December 15th 05, 12:20 AM posted to rec.aviation.homebuilt
Gig says, 6061 rules!
Well, yeah, I guess so. It's not quite as strong as 2024 but
excellent aircraft aluminum preferred by Chris Heintz.
Old December 16th 05, 04:39 AM posted to rec.aviation.homebuilt
On Wed, 14 Dec 2005 16:12:57 -0600, "Gig 601XL Builder"
wrDOTgiaconaATcox.net wrote:
roups.com...
alclad.
My rebel is mostly 6061 as well. Just rub it off with a scochbrite
pad.
Mercury another threat to aviation security? Aviv Hod Piloting 2 October 7th 04 07:24 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 03:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 06:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 04:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 07:24 AM
