Low battery voltage level
Old December 22nd 05, 12:28 AM posted to rec.aviation.ifr
Default Low battery voltage level
Hi All,
I'm looking for recommendations for a low battery warning voltage level. I
was going to use 12.8V - is this liable to be triggered by noise/dips in the
bus voltage? My guess is when heaters or motors kick in there could be a
momentary drop due to high current that could trigger my low voltage
indicator. Also it it worth putting a long time constant filter on this?
Thanks!
Mark.
Old December 22nd 05, 01:01 AM posted to rec.aviation.ifr
The 12 volt generator/alternator will be at 14-15 volts
nominal when within the working range of RPM. The voltage
regulator should keep the voltage within that range without
any significant variation.
Just what are you intending to be warned against? The load
meter gauge shows the load being carried by the generator
system, the ammeter shows whether the generator or battery
is supplying the power being used, An ammeter should be
showing only a slight charge all the time as it keeps the
battery "topped off." If the battery is any good, the
ammeter will return to low indicated charge within a few
minutes after starting the engine. At a low idle, the
battery will show a discharge because the generator is not
carrying the load and the battery is discharging to carry
what the demand is at the time. This is not a problem in
the short term, such as a power-off landing or glide, but
anytime that the engine is in the power range, the generator
[alternator] should be carrying all the load.
Power relays need about 10 volts to stay engaged. If you
are building a home-built airplane, you could have a yellow
warning light at less than 13.9 volts and a red warning at
12.8. Open cell no-load voltage is 2.2 volts or 13.2 volts
on a lead/acid battery.
Certificated aircraft require certificated parts. You can
get a cigarette lighter plug-in monitor.
James H. Macklin
ATP,CFI,A&P
Merry Christmas
Have a Safe and Happy New Year
Live Long and Prosper
Jim Macklin
"markp" wrote in message
| Hi All,
voltage level. I
noise/dips in the
there could be a
low voltage
filter on this?
| Thanks!
| Mark.
Old December 22nd 05, 01:17 AM posted to rec.aviation.ifr
Thanks Jim.
I'm an electronics designer, I have been asked by my customer to provide a
warning when battery volts drop below 12.5V. I already measure voltage with
a data logger. The logger has an accuracy of +/- 2% on bus rail voltage
monitoring (this is around +/-0.25V at 12.5V). My customer wants a warning
when battery voltage goes below 12.5V irrespective of whether the engine is
running or not. To achieve this the threshold must be set at 12.75V to
guarantee catching 12.5V, but it could of course be the other way round and
we'll actually warn at 13V. All a bit hairy really.
Given the inherent inaccuracy, I'm concerned that this voltage warning will
be triggered un-necessarily and is essentially impractical when set to
12.75V. Personally I'd put the threshold to 12.5V nominal and have a large
time constant filter on it to catch glitches and momentary dips - this would
trigger at a minimum of 12.25V, max 12.75V. I can also measure engine speed
with the logger and inhibit warnings under 50% rpm when the alternator is
not charging, this is currently what the prototype sytem does and is
reliable, but my customer wants warnings below 12.5V regardless.
Any comments welcomed!
Regards,
Mark
"Jim Macklin" wrote in message
news:22mqf.30260$QW2.2267@dukeread08...
James H. Macklin
ATP,CFI,A&P
Merry Christmas
Jim Macklin
| Hi All,
voltage level. I
noise/dips in the
there could be a
low voltage
filter on this?
| Thanks!
| Mark.
Old December 22nd 05, 02:04 AM posted to rec.aviation.ifr
running or not. [...]
Ask the customer how long a dip they would tolerate without a warning,
and why. An intellegent answer may require some dialog. And wouldn't a
large time constant filter =miss= momentary dips? That's what it's for
- to ignore the quick stuff and only warn on the more permanent stuff.
Jose
You can choose whom to befriend, but you cannot choose whom to love.
Old December 22nd 05, 02:50 AM posted to rec.aviation.ifr
From a practical psychological standpoint, a warning should
be only for a serious failure, and not a routine variation.
When you get a flashing red light with every power
reduction, pretty soon the red light will have lost its
warning effect. From a pilot's perspective, I would like an
alert that the voltage is below a level that will maintain
the battery, about 13.5 volts with a steady yellow light,
but I'd want to have a flashing red if the voltage was below
the 12 volt level. This would happen only with a dead
cell in the battery or with a complete charging failure and
be soon enough to give time to reduce loads and make a safe
landing, but not cry wolf too often.
With some computer logic, you could monitor rpm of the
engine and the alternator and perhaps even the performance
of the voltage regulator (dwell time?).
You might contact Bob Nuckolls [Wichita, KS](see EAA Sport
Pilot magazine back issues for his address/contact info).
He is an engineer and pilot who might have some useful ideas
and FAA certification input.
Obviously you can make an engineering research device to
sample the electrical system for data every second and to
store data on a flash memory chip (USB drive) to include
temperatures, rpm, volts, amps, data which can be used in a
laboratory. But a pilot doesn't need to know more than it
is working or it isn't...time to land ASAP.
I like the airplane to have a volt meter and a load meter.
If the voltage is "in the green" and the load is less than
85% continuous, with all the lights and loads ON, I'm happy.
James H. Macklin
ATP,CFI,A&P
Merry Christmas
Jim Macklin
| Thanks Jim.
rail voltage
wants a warning
at 12.75V to
other way round and
when set to
and have a large
dips - this would
the alternator is
does and is
regardless.
| Regards,
| Mark
| "Jim Macklin" wrote
in message
voltage
without
load
generator
battery
not
carry
in
but
generator
you
yellow
at
volts
can
| James H. Macklin
| ATP,CFI,A&P
| Merry Christmas
| Jim Macklin
| | Hi All,
warning
| voltage level. I
triggered by
| noise/dips in the
in
| there could be a
my
| low voltage
constant
| filter on this?
| | Thanks!
| | Mark.
Old December 22nd 05, 04:15 AM posted to rec.aviation.ifr
I suggest you make the voltage threshold adjustable.
Old December 22nd 05, 05:34 AM posted to rec.aviation.ifr
In my last 40 years as a professional avionics engineer have I seen this
many errors in a single document.
PLEASE take this post and TRASH it.
Old December 22nd 05, 10:25 AM posted to rec.aviation.ifr
Which error?
James H. Macklin
ATP,CFI,A&P
"RST Engineering" wrote in message
have I seen this
| Jim
| "Jim Macklin" wrote
in message
voltage
without
load
generator
battery
not
carry
in
but
generator
you
yellow
at
volts
can
Old December 22nd 05, 11:16 AM posted to rec.aviation.ifr
large time constant filter =miss= momentary dips? That's what it's for -
Yes, this is what I meant, filter out the momentary dips so it doesn't
trigger the warning.
Low voltage warning level markp Home Built 1 December 27th 05 06:11 AM
Displaced AFSS "controllers" heading for BIL and GRB Chip Jones Instrument Flight Rules 12 April 10th 05 10:22 PM
Parachute fails to save SR-22 Capt.Doug Piloting 72 February 10th 05 06:14 AM
14 Volt Gel Cell? Joe Allbritten Soaring 32 May 11th 04 02:37 AM
ICom A-5 Question - Battery Level Indicator Harry Gordon Piloting 22 December 5th 03 01:07 AM
