Dawley Aviation PIREP, or: Atlas is BACK
Old January 1st 06, 03:18 PM posted to rec.aviation.owning
Default Dawley Aviation PIREP, or: Atlas is BACK
We were grounded last week, after discovering a cracked exhaust pipe and
rotted muffler baffles during routine maintenance.
Amazingly, we discovered that Dawley Aviation (*the* exhaust repair station
in the Midwest, and the place my A&P recommended) is located in Burlington,
WI -- literally on the road to Racine -- which was where we were headed for
"Xmas II". So, we ripped off the old system and tossed it in the back of
the Subaru with all the luggage and presents.
Four hours after leaving Iowa City, we were at Dawley's VERY impressive
offices. They are clearly a well-established business, with a large, clean
factory floor, and a nice, clean front office area, housing half a dozen
office workers in private offices. It looked more like a bank than any
aviation business I'd ever had the pleasure of seeing before -- quite
different from most of these kinds of places.
Steve, their VERY knowledgeable sales manager, was there to greet us. It
was obvious that he (and the staff) weren't used to having customers drop
stuff off (a steady stream of UPS and FedEx trucks flowed in and out while
we were there), but he took it all in stride and seemed genuinely pleased to
actually SEE someone for a change.
It turned out that Steve had trained with the same CFI as I did, over in
East Troy, Wi, so we were instantly fast friends as we traded "Old Bob"
stories back and forth. He took the cruddy old parts from me, identified
what could be re-used, and said that I could pick the new system up on our
way out of town the next day. It was as easy as that, and we were soon off
to Racine for Xmas with Mary's family.
The next day we swung back into their office, and it was all ready to go.
Dang, they literally replaced EVERYTHING except one flange on both the
triple pipes and the muffler. Everything else is brand-spanking new.
Steve wished Mary and the kids a happy new year, gave each of us a bag of
peanuts (which they apparently always throw in the box -- it's a Dawley
tradition that goes way back to their beginning), and charged us $620. Not
cheap, by any stretch, but still way cheaper than new.
All in all, a very pleasant experience, and a real pleasure to work with a
guy that's so knowledgeable. In answer to questions, Steve went on at great
length about the metallurgy behind the work, and the reasons exhaust systems
fail. (Incidentally, he said that the best thing that EVER happened to
their business was everyone running "lean of peak" and driving their EGTs up
above 1500 degrees. As temperatures approach 1600 degrees, the metal simply
starts to fail, and you end up saving pennies on gas, and blowing dollars on
exhaust systems.)
My A&P put everything back together yesterday, and Atlas is now snug back in
his hangar, with a new exhaust, new oil/filter, new Iridium spark plugs, and
(hopefully) no more oil leak. Now all we need is some flying weather!
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old January 1st 06, 04:23 PM posted to rec.aviation.owning
Sounds like my A&P too my bag of pranuts
"Jay Honeck" wrote in message
news:ywRtf.692885$xm3.601961@attbi_s21...
Not
Old January 1st 06, 05:17 PM posted to rec.aviation.owning
exhaust systems.)
Done improperly LOP will start to melt exhaust systems. If you're
getting over 1500 EGT then you're not LOP, you're at peak. 75 LOP is
the same temp as 75 ROP.
Old January 1st 06, 07:08 PM posted to rec.aviation.owning
exhaust systems.)
1600º is LOR (Lean of Rich) not LOP. 1600º is right at peak, as has been
stated. My engine typically peaks at 1590º. With the BMP (Big Mixture
Pull), I go from ROP through Peak to well LOP in about one second.
Yesterday on my flight I was running at 1490º, or 100º LOP. Now, if I
run it 100º ROP, what will my EGT read ?
BTW - my CHTs were 320º.
Ken Reed
Old January 1st 06, 09:03 PM posted to rec.aviation.owning
exhaust systems.)
That's funny as this isn't supported by the data the GAMI folks have
taken. It shows the EGTs being pretty much symmetrical about the peak.
So if you go lean of peak far enough you should be able to pretty much
equal the temps seen on the rich side of peak. And CHTs are actually
lower on the lean side so you should be saving your cylinder heads some
grief.
http://www.gami.com/frames.htm
Now if folks are running "at peak", then I see Steve's point, however,
"lean of peak" doesn't have to be problem if done properly.
Matt
Old January 1st 06, 09:04 PM posted to rec.aviation.owning
EGTs up above 1500 degrees. As temperatures approach 1600 degrees,
the metal simply starts to fail, and you end up saving pennies on gas,
and blowing dollars on exhaust systems.)
Not the same. It is better as you have the same EGT with much lower CHTs.
Matt
Old January 2nd 06, 12:25 AM posted to rec.aviation.owning
"Newps" wrote in message
up above 1500 degrees. As temperatures approach 1600 degrees, the metal
simply starts to fail, and you end up saving pennies on gas, and blowing
Done improperly LOP will start to melt exhaust systems. If you're getting
over 1500 EGT then you're not LOP, you're at peak. 75 LOP is the same
temp as 75 ROP.
The PROPER way is not so much running ROP or LOP but rather the transition
from full rich to LOP - it has to be done quickly, like 3-4 seconds ("The
Big Pull" as Deakin describes it).
Where jus about everyone gets into trouble is running near peak (i.e., just
a few degrees either side).
Jay is merely parroting the OWT and misinformation that has been running
around out there for _years_.
Matt
Matthew W. Barrow
Site-Fill Homes, LLC.
Montrose, CO
Old January 2nd 06, 12:30 AM posted to rec.aviation.owning
"Matt Whiting" wrote in message
a guy that's so knowledgeable. In answer to questions, Steve went on at
great length about the metallurgy behind the work, and the reasons
exhaust systems fail. (Incidentally, he said that the best thing that
EVER happened to their business was everyone running "lean of peak" and
driving their EGTs up above 1500 degrees. As temperatures approach 1600
degrees, the metal simply starts to fail, and you end up saving pennies
on gas, and blowing dollars on exhaust systems.)
taken. It shows the EGTs being pretty much symmetrical about the peak. So
if you go lean of peak far enough you should be able to pretty much equal
the temps seen on the rich side of peak. And CHTs are actually lower on
the lean side so you should be saving your cylinder heads some grief.
Here's the summary:
http://www.avweb.com/news/columns/182084-1.html or, I you prefer, here's the
Printer Friendly version:
http://www.avweb.com/cgi-bin/udt/im....ry.id=1820 84
Read the graphs and charts.
Matt
Matthew W. Barrow
Montrose, CO
Old January 2nd 06, 12:40 AM posted to rec.aviation.owning
great length about the metallurgy behind the work, and the reasons exhaust
systems fail. (Incidentally, he said that the best thing that EVER
happened to their business was everyone running "lean of peak" and driving
their EGTs up above 1500 degrees. As temperatures approach 1600 degrees,
the metal simply starts to fail, and you end up saving pennies on gas, and
Yeah...he's really knowledgeable....on myths and legends.
Matt
Matthew W. Barrow
Montrose, CO
Old January 2nd 06, 12:48 AM posted to rec.aviation.owning
Well, I suspect what he *means* is that people are leaning incorrectly in
attempting to run LOP, and/or they are trying to run LOP with carbureted
engines. Everyone is trying to save fuel nowadays, with avgas so high, and
people are simply cooking their exhausts systems in the process.
Steve has no reason to lie (in fact, he has every reason to say just the
opposite!) -- and, as sales manager of the largest exhaust shop in the
world, I suspect he has figured out where his customers are coming from.
Jay Honeck
Iowa City, IA
Pathfinder N56993
Prairie Aviation Museum PIREP Jay Honeck Piloting 6 October 19th 05 10:18 PM
Atlas Air N-522-MC will be back into LUX. ellx Instrument Flight Rules 0 January 4th 05 08:47 PM
General Aviation Legal Defense Fund Dr. Guenther Eichhorn Aerobatics 0 May 11th 04 11:43 PM
Here's the Recompiled List of 82 Aircraft Accessible Aviation Museums! Jay Honeck Home Built 18 January 20th 04 05:02 PM
