Dawley Aviation PIREP, or: Atlas is BACK
Old January 3rd 06, 12:43 AM posted to rec.aviation.owning
Default Dawley Aviation PIREP, or: Atlas is BACK
"Matt Whiting" wrote in message
A. Smith wrote:
"Matt Barrow" wrote in message
Jay is merely parroting the OWT and misinformation that has been running
around out there for _years_.
Jay quotes an expert in the field and you accuse him of parroting
misinformation? LOP is good when properly done, but I think the
statement from Dawley says it is NOT being properly done for the most
part. The company I work for overhauls 400+ aircraft engines a year.
Our teardown shop can tell you which ones have been ran LOP and which
have not.
I think the point is that it is the temperatue seen by the exhaust pipe
that matters, not whether it is LOP or ROP. And the temps mentioned by
Mr. Dawley sound more like runnint at peak, rather than either side.
People seem to automatically blame running on the lead side and that
simply isn't supported by the data. It is an old wives tale pure and
simple.
Matt
Which is my point, people think they know how to run LOP but actually are
running at peak, causing damage. The guy at Dawley didn't say running LOP
did the damage, just that when the LOP operation began being pushed is when
the damage started showing up.
Allen
Old January 3rd 06, 01:25 AM posted to rec.aviation.owning
How do you design an engine to run LOP?
Matt
Compression ratio, cumbustion chamber shape, valve placement, valve
material, crankshaft counterweight design...............................
Example?
Matt
Old January 3rd 06, 02:40 AM posted to rec.aviation.owning
Example?
The original Continental in the original Malibu.
  #24
Old January 3rd 06, 03:23 AM posted to rec.aviation.owning
Example?
I've seen a claim to this effect on Avweb, but haven't seen anything
from TCM. Do you have any data from them that claims this engine was
designed differently for LOP operation? I'd like to see more details.
Matt
  #25
Old January 3rd 06, 02:52 PM posted to rec.aviation.owning
A. Smith wrote:
Really? How?
I suggest that if you are really interested in this you get with Lycoming
or TCM and see what they suggest for your engine. There are only a
handful of engines that were designed to be ran LOP.
So much for "expertise".
Matt
Matthew W. Barrow
Site-Fill Homes, LLC.
Montrose, CO
  #26
Old January 3rd 06, 02:53 PM posted to rec.aviation.owning
"john smith" wrote in message
Example?
Was configured to run LOP, not designed for it.
  #27
Old January 3rd 06, 03:01 PM posted to rec.aviation.owning
"A. Smith" wrote in message
om...
simple.
Matt
when the damage started showing up.
That's a nice stretch of the original quote....and I've heard of mechanics
finding all sorts of damages from running LOP when the engine was not run
LOP at all. It's been a favorite excuse for years.
Remember that for YEARS, the favorite leaning technique was to lean to peak,
then enrich slightly (which would put temps at about 50ROP, the "Red Box"
Red Box = No Fly Zone
At and below about 60% power, there is no red box.
At about 65% power or so, 100ºF ROP to Peak.
At about 70%, 125ºF ROP to 25ºF LOP.
At about 75%, 180ºF ROP to 40ºF LOP.
At about 80%, 200ºF ROP to 60ºF LOP
Before you stick your foot into it even deeper, read this and pay particular
attention to the charts and graphs:
http://www.avweb.com/news/columns/182084-1.html
Don't worry about the text so much as the graphical data.
  #28
Old January 3rd 06, 05:47 PM posted to rec.aviation.owning
1600º is LOR (Lean of Rich) not LOP. 1600º is right at peak, as has been
That's funny!
  #29
Old January 3rd 06, 09:00 PM posted to rec.aviation.owning
om...
simple.
Matt
LOP did the damage, just that when the LOP operation began being pushed
is when the damage started showing up.
peak, then enrich slightly (which would put temps at about 50ROP, the "Red
Box"
Which orifice did you pull these numbers from?
particular attention to the charts and graphs:
Do you even bother to read what you cite? Look at the gauges in the
aircraft panel in the article you quote. The LH EGT shows 1595 degrees and
the RH shows 1585 degrees. Both seem pretty near the 1600 degrees that
softens stainless. Why do they use these particular power settings? To
manipulate the data in their favor.
  #30
Old January 3rd 06, 10:34 PM posted to rec.aviation.owning
Matt Barrow wrote:
it has to be done quickly, like 3-4 seconds ("The
Big Pull" as Deakin describes it).
When flying with an engine equipped with their turbo-normalization system,
Tornado Alley recommends the pull from full rich to LOP take about 6
seconds.
Peter
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) Rich Stowell Aerobatics 28 January 2nd 09 03:26 PM
Prairie Aviation Museum PIREP Jay Honeck Piloting 6 October 19th 05 10:18 PM
Atlas Air N-522-MC will be back into LUX. ellx Instrument Flight Rules 0 January 4th 05 08:47 PM
General Aviation Legal Defense Fund Dr. Guenther Eichhorn Aerobatics 0 May 11th 04 11:43 PM
Here's the Recompiled List of 82 Aircraft Accessible Aviation Museums! Jay Honeck Home Built 18 January 20th 04 05:02 PM
