#21
You'll still have vortices and wake. One day I flew through the wake of the late Mark Navarre (OD), and told him he "thumped" me. He complained that his glider (ASW-20?) wasn't supposed to have a wake. If you're heavier than air and you're flying, you ARE going to generate a wake. Back in the sixties, during a contest at Grand Prairie, TX, I was in the reurn part of an O&R task -- approaching Fort Worth. Ahead, crossing my path and well below was a B-36 taking off with all ten engines working mightely. About two minutes later, wake turbulence threw my Schweizer 1-23 almost inverted. Luckily, after recovery enough height remained to enable a "good finish". -- Charles Yeates ZS Jezow PW-6U & PW-5 http://www3.ns.sympatico.ca/yeatesc/world.html |
Charles Yeates wrote: Back in the sixties, during a contest at Grand Prairie, TX, I was in the reurn part of an O&R task -- approaching Fort Worth. Ahead, crossing my path and well below was a B-36 taking off with all ten engines working mightely. About two minutes later, wake turbulence threw my Schweizer 1-23 almost inverted. Luckily, after recovery enough height remained to enable a "good finish". BTW, the 1-23 and I earned a Gold C and two diamonds in ten days at Grand Prairie --EVERYTHING IS BIG IN TEXAS, eh? -- |
Thanks to all for the information on winglets and lift production in general.
It seems there is still a lot to be learned in design of airfoils, even NASA cant give a defintive, simple explanation of what produces lift, in what amount the sucking or deflecting proportions are. The hours of research available from some of your suggested links has left me with bleeding eyes and a sore back, for those who want the simple version, my reading of it is- Wings produce lift by diverting air down. The reactive force is up, the balance is drag. Winglets enhance the lift produced from the wing by minimising vortices (drag) produced where the upper and lower airflow mixes at the wing end. The balance again is drag, it wouldnt matter if they were up or down facing, for the purpose of aerodynamics. I particularly liked the spoon-in-waterflow demonstration (so did my kids) and recommend everyone tries it. Boom time here in oz, 1000k flights, competitions, sun, sun, sun. Wayne |
bagmaker wrote: Thanks to all for the information on winglets and lift production in general. It seems there is still a lot to be learned in design of airfoils, even NASA cant give a defintive, simple explanation of what produces lift, in what amount the sucking or deflecting proportions are. The hours of research available from some of your suggested links has left me with bleeding eyes and a sore back, for those who want the simple version, my reading of it is- Wings produce lift by diverting air down. The reactive force is up, the balance is drag. Winglets enhance the lift produced from the wing by minimising vortices (drag) produced where the upper and lower airflow mixes at the wing end. The balance again is drag, it wouldnt matter if they were up or down facing, for the purpose of aerodynamics. I particularly liked the spoon-in-waterflow demonstration (so did my kids) and recommend everyone tries it. Boom time here in oz, 1000k flights, competitions, sun, sun, sun. Wayne -- bagmaker Probably one of the best lectures I've ever heard on any subject, was given by Mark Maughmer of PSU on the subject of winglets. I highly recommend it if you ever get the opportunity. Chip F |
"bagmaker" wrote in message ... OK, I can get the theory (OR can I?) with winglets to reduce wingtip vortices. Surely the best direction for the tip is DOWN!, I understand this may be difficult for actually making, especially with gliders and groundloops, aesthetics, etc, but can someone explain why they are pointing up? Consider this.. The HIGH pressure area is UNDER the wing, we want to keep this from migrating to the LOW pressure area ABOVE the wing. :-) Look at it the other way: 2/3 of the lift is generated by the low presure over the wing, and 1/3 by the high pressure under it ... so what you want to do is to "seal" in the partial vacuum above the wing. Anyways, according to the 2/3 1/3 explanation you'd expect a winglet to have about 2/3 of its area above the chord line, and 1/3 below, which is rougly what you see on modern winglets on commercial aircraft. MH. |
http://www.mandhsoaring.com/winglets.html
Here is a link to the M & H web site with a bunch of tech lit on the subject. Great reading for insomniacs. My understanding is the winglet is an airfoil creating lift directed inboard to counteract the span wise flow that exists due the fact that the airfoil is finite in length. An infinite span would have no span wise flow and therefore no tip vortices (induced drag). It is not just fence to stop the span wise flow as that fence would have to be much larger and create as much or more drag than it reduces. As one of these papers indicates it is much easier to design a bad winglet and get a reduction in performance than it is to design one that actually works. Dr. Mark Maughmer (sp) at Penn State is the wizard (and the author of some of the tech lit referenced above). His designs are still evolving even after much study and experimentation so the idea that the average pilot can slap some board on his wing tip and actually get a performance advantage is a pipe dream. Fly safely. BC |
| Thread Tools | |
| Display Modes | |
| LS4 Winglets | Sleigh | Soaring | 2 | June 8th 05 02:38 AM |
| Ventus A 16.6 extensions wanted or 15 meter winglets | goneill | Soaring | 0 | January 5th 05 07:27 AM |
| winglets for LS-1 | Brad | Soaring | 4 | October 26th 04 07:11 PM |
| ASW20L extentions with winglets? | goneill | Soaring | 6 | September 17th 04 11:28 PM |
| Discus Winglets | Kevin Neave | Soaring | 2 | October 15th 03 12:35 PM |
