eLSA certification
Old January 11th 06, 11:33 PM posted to rec.aviation.homebuilt
Default eLSA certification
In reviewing the definitions from the FAA na dfrom comments posted in
this newsgroup, there seem to be some special opportunities when
building aircraft that could fit LSA derfinitions.
If my understanding is correct, it would be possible for someone to
build (for instance) a Van's RV-6a with a Lyc O-235 or Conti O-200 and a
ground adjustable prop set to its extreme climb configuration to limit
speed to 138 mph. As long as the plane's max TOW is stated to be 1320
lbs, that would fit the LSA category.
Is this assumption correct?
TIA,
CV
Old January 11th 06, 11:49 PM posted to rec.aviation.homebuilt
Default eLSA certification - correction
TIA,
CV
That should say RV-9a, not RV-6a. The RV-9a is stated by Van's to use a
118hp O-235.
Old January 12th 06, 12:02 AM posted to rec.aviation.homebuilt
As long as you had a wing loading between 8 or 9 lbs per sq ft
at MGW. 8^)
Reggie
FYI
http://www.constitutionparty.com/
Old January 12th 06, 03:16 PM posted to rec.aviation.homebuilt
It would never be an E-LSA it might be an experimental-Homebuilt that meets
the requirements for LSA pilots.
"Cal Vanize" wrote in message
In reviewing the definitions from the FAA na dfrom comments posted in this
newsgroup, there seem to be some special opportunities when building
If my understanding is correct, it would be possible for someone to build
(for instance) a Van's RV-6a with a Lyc O-235 or Conti O-200 and a ground
adjustable prop set to its extreme climb configuration to limit speed to
138 mph. As long as the plane's max TOW is stated to be 1320 lbs, that
TIA,
CV
Old January 13th 06, 12:04 AM posted to rec.aviation.homebuilt
Cal Vanize wrote in
a ground adjustable prop set to its extreme climb configuration to
limit speed to 138 mph. As long as the plane's max TOW is stated to
be 1320 lbs, that would fit the LSA category.
TIA,
CV
It "could" fit the LSA catagory, in that a sport pilot may fly it, but
it would not be an eLSA or sLSA... it would be and Experimental Am.
Built. (is the clean stall on an RV-9 below 51mph???)
It would be stupid.... you should build a 601 or Sonex instead, or wait
for the RV-12
-- ET :-)
"A common mistake people make when trying to design something
completely foolproof is to underestimate the ingenuity of complete
fools."---- Douglas Adams
Mechanical Systems Certification Engineer-Aviation [email protected] Home Built 0 April 2nd 05 09:25 PM
Adding IFR Plane Certification To Planes Without It Blanche Cohen Owning 10 November 29th 04 07:37 PM
Aircraft certification questions. psyshrike Owning 42 November 22nd 04 07:10 PM
certification of composite aircraft sebastian Home Built 6 March 25th 04 04:48 PM
Aircraft engine certification FAR's Corky Scott Home Built 4 July 25th 03 07:46 PM
