Round Engines
Old January 23rd 06, 08:07 PM posted to rec.aviation.piloting
Default Round Engines
Yeah, those were the days all right.
I'm sure you probably didn't run into these guys, or probably wouldn't
remember them if you did, but from the F94C community, I remember a back
seater named Ray Nishibayashi. He flew out of New Castle Delaware. In the
F89 community, I had a friend named Bob Montgomery. He was a guard pilot.
There sure was a lot going on back in the old days :-)
Dudley
"Big John" wrote in message
Dudley
Some more on that era and Willie.
The Air Cadet Class of 49C (?) graduated and in 6 months half had
killed themselves in operational Squadrons.
This caused the Training Command to fire everyone at Willie and bring
in a new group of instructors and a new Training Group Commander (Leon
"the peon" Gray). The new instructors were rotating pilots from
Fighter Squadrons in Far East and Europe, about 15 from each. I came
in from 8th FG in Japan and was an instructor in CIS (Central
Instructor School) there until all the newbe's were checked out in
back seat of T-6 and picked up students. F-80/T-33 check outs were
conducted in the Training Sections (#1 and #2) after finishing the
days instruction with students. My good buddy from 35th Squadron in
Japan gave me half a dozen touch and goes in T bird and signed me off.
I then went and said I want a F-80 and they gave me one and I went and
flew it. Not like the highly supervised checkouts today.
The F-80C and T Birds all had the semi automatic starting system with
the 'big' engine. Much easier to start and rarely a hot start unless
you started with tail pointing into a strong wind.
When I hit Willie, Luke had been closed and Willie sent tower
operators (mobile unit) and crash crew over when we started a new
class and used it for touch and goes on student check outs to relieve
traffic at Willie.
Korea started and they reactivated Luke and expanded Nellis. One story
about Nellis, they had a snack bar on corner of ramp nearest to
Runway. A student lost control of a 51 and ran into it and destroyed
it. No one got hurt in the crash which was a miracle. Didn't repair
but moved it to a new building on line.
On Scott and engine test. As I recall they didn't have the tail on and
were just running the new BIG engine to exercise the controls and give
him experience operating it. Think I saw it that way taxiing by before
it blew up? Lucky to have survived (with no injuries). Some bar talk
about not wanting to fly that bomb )
Your right about Willie and the rest of those fields. Right in the
middle of things. As student flow continued and losses in Korea were
less than 'progged' they backed up at Willie as Luke and Nellis
couldn't accept them. I helped to set up some Air to Air camera
training in T-33's to keep them busy and give them a head start on air
to air combat. It was fun to put them on the perch for a high side
attack. Did have one or two run into the target as happened in aerial
gunnery when you pushed )
If I haven't said, after leaving Willie went to Hamilton and ADC,
F-94C (best supersonic airplane I ever flew), F-89 (all versions after
'C') and tour with Navy VF-23 (Big Banshee, F2H3)and F-101B.
Enough war stories for today. My new computer (Athlon 3300 64) is
running infant morality mode and so far so good.
Big John
On Mon, 23 Jan 2006 11:06:11 GMT, "Dudley Henriques"
Hi John;
Never flew the P80, but I remember those early days during the transition
period from props to jets quite well. The loss rates were high as a kite
as
you have stated. But I'll bet you'll agree that in spite of it all, Willie
and Luke were the places to be in those days.:-))
Starting those early jets J33's, J47's etc really kept you guys on your
toes
balancing throttle and temps. Phrases like "bringing it around the horn"
and
"hot start" were quite commonly heard on the flight line back then and
hardly heard any more.
By contrast, the T38 is a "push to start" "go fast" buggy. :-)
Putting a bird on a stand and running it was a great idea, although I
remember the day Scott Crossfield blew the tail off the X15 at Edwards
doing
an engine testbed ground test on the XLR99 engine. He said it was quite
funny really.
They put him in the bird and everybody else went into the blockhouse. They
called it "developing the confidence of the pilot" :-) When it blew, the
front half of the airplane actually flew forward off the stand about 20
feet. I always said, Crossfield should have logged the time! :-))
Dudley
Dudley
Guess you never flew the P-80 A/B?
The boost pump was the main fuel pump from the P-59. Was a monster
that pulled something like 20+ amps.
Once you got an indication of TPT you used both hands and pulled the
throttle back just into edge of idle cut off and then pushed out to
the idle position. This cycling let you keep the TPT from exceeding
limits as engine spooled up to idle. As the RPM rose you reached a
point where the starter dropped out and the TPT kept staying in limits
without cycling the throttle and as RPM stabilized in idle you also
had the idle TPT.
Flying that early small engine (3850 lbs thrust), if you had to go
around in the pattern it took over 20 seconds from idle to full power.
Really had to stay ahead of bird in pattern. Lot of 51/47 jocks
checking out had trouble with this.
Shut down was easy. Let idle for a minute or two to stabilize temps
and then go to idle cut off and clean cockpit up.
At Willie (first jet school) we had the 'Captive Air'. This was a
P-80A mounted on supports (concrete/steel) with gear not touching
ground. This trainer let us put a student in cockpit and standing on
wing talk him through an engine start and simulated flight. (Start
engine and then cycle gear and flaps like would happen on a real
flight.) Last time I was at Willie for a reunion (they then had
T-38's) the Captive Air facility across the field had been torn down
and not saved for posterity (
Been a long time since I thought about the early jets. We killed at
least one student a month and a instructor every quarter at Willie
when we started student jet training for Korea.
Big John
On Thu, 19 Jan 2006 16:29:53 GMT, "Dudley Henriques"
m...
Dudley
Those were the good old days but we only realize it now )
The biggest I fired up was the R2800 (P-47D).
Looking back I think I remember it sounded like a 'Harly Hog' today
for those who haven't heard one start and run.
Hundreds of hours behind a R1340.
Big John
I have a few hours in the Jug (N) and some time in the Bearcat.
Preferred
the 51 for show work, but the cat was a real ride coming off the deck
with
some excess power to convert :-))
Never flew the 4360, but I had a friend who had one in his Corsair. He
used
to laugh like hell when he told me that it sometimes took him more time
to
get it started than it did to make the flight he started it for.
I've always wondered what the hell everybody thought was so damn hard
about
flying the jets. That little list of humor you posted is just about
right
on.
In the T38, you climb in; push the start buttons and watch the temps
rise,
then you point it where you want it to go and hang on. (of course it
helps
if you actually HAVE it pointed where you want it to go when you hit the
burners :-).
You can fly the T38 all day long without touching the rudder pedals, and
that includes aerobatics!!
It's great to be able to look back on all that fun. :-)))
Dudley
  #62
Old January 23rd 06, 11:26 PM posted to rec.aviation.piloting
Thanks for the stories guys!
  #63
Old January 24th 06, 06:22 AM posted to rec.aviation.piloting
Dudley
Names don't strike a bell. We, WADF, didn't have much contact with
East Coast, EADF.
My last F-89J flying was as Air Force Advisor to the Maine Air Guard.
With my MB-1 back ground helped them go Nuc (first Guard Sq to do so).
In the 'J' with the MB-1, I developed the head on attack and sold it
to ADC. Gave the bird a Pk of over 95%. Only bird to do head on's in
USAF as far as I know.
Enough war stories. I'm going to quit taking up band width and go to
bed.
Big John
On Mon, 23 Jan 2006 19:07:15 GMT, "Dudley Henriques"
Dudley
Dudley
traffic at Willie.
Big John
Hi John;
as
toes
and
doing
funny really.
Dudley
Dudley
had the idle TPT.
Big John
om...
Dudley
Big John
Preferred
with
used
to
about
right
on.
rise,
helps
burners :-).
Dudley
  #64
Old January 24th 06, 06:42 AM posted to rec.aviation.piloting
Dudley
East Coast, EADF.
bed.
Big John
John,
Fascinating thread...
I live in the Phoenix area (since late 1997) and had never heard of Luke
ever being closed.
Ironic that Luke prospers while Williams got the axe.
FWIW, they've just opened a great new GA terminal at Williams Gateway and
businesses continue to move into all the former AF facilities. The future
seems bright for "Willie" as a public airport.
Wonder why Luke and Williams' fortunes swung in opposite directions...?
Jay Beckman
PP-ASEL
AZ Cloudbusters
Chandler, AZ
  #65
Old January 24th 06, 11:06 PM posted to rec.aviation.piloting
Jay
Seems like there was a subdivision problem or Luke was encroaching on
something? Been so long ago.
When Korea started and after, they had to cut a path through the
airway going west from Phoenix to let the birds get to the gunnery
ranges down toward Yuma (think the ranges are now named for
Goldwater?). Remember some finger pointing between FAA and USAF before
things were settled.
Final agreement was (as I recall) they cut a low altitude gate (below
4000 ft) across the airway and the jets had to stay low going out and
let down and come back in at low altitude to get home.
Willie was out in the boon docks at that time so that was probably why
it was first choice to keep open unless it was a political decision
which we didn't know about.
I keep reading about things moving into Willie and flying activities
there now. Was sorry to see the USAF give it up (
Big John
On Mon, 23 Jan 2006 22:42:05 -0700, "Jay Beckman"
Dudley
East Coast, EADF.
bed.
Big John
John,
ever being closed.
Jay Beckman
PP-ASEL
AZ Cloudbusters
Chandler, AZ
  #66
Old January 25th 06, 12:15 AM posted to rec.aviation.piloting
news
Jay
It would seem everyting old is new again as development near Luke is
something that is often in the news these days.
Goldwater?).
Correct, the ranges down along the Mexican border are the Barry Goldwater
range(s.)
I think things have sort of flip flopped these days. They seem to prefer to
send the F16s down to the Goldwater range at 7500' and higher and want GA
down lower. I always make sure I'm talking to Luke Approach whenever I head
southwest of Phoenix and I tend to delay my climb to the usual 8500' and
stay down at 4500-6500' until I'm west or northwest of the Gila Bend VORTAC.
We're quickly running out of "boondocks" out here. Good thing businesses
and ASU jumped on Willie quickly or some developer would have snapped that
land up in a heartbeat.
Did some T&Gs there when I was training for my private ... 10,000' runways
look awfully big when you're in a spam can and they take forever to fly the
downwind leg!
Regards,
Jay Beckman
  #67
Old January 25th 06, 02:52 AM posted to rec.aviation.piloting
downwind leg!
What makes you think you have to fly the length of the runway to do
T&G's?
  #68
Old January 25th 06, 04:36 AM posted to rec.aviation.piloting
T&G's?
Well, except for the "three bounce currency", you are expected to fly
the pattern, whose size relates to the runway length.
Jose
Money: what you need when you run out of brains.
  #69
Old January 25th 06, 05:18 AM posted to rec.aviation.piloting
"john smith" wrote in message
runways
downwind leg!
T&G's?
Because I didn't want to explain to the tower why I truncated the pattern
for 30C when 30R, 30C and 30L were all in use...howzat?
FWIW, we only did a couple and it was kind of a kick to already be at
pattern altitude with over 1/2 the runway still to go. We were back in the
air on the go before we'd even reached the end of the skidmarks in the
touchdown zone. And, I only had about 22 hours at that point so alternative
ways to fly the pattern were not something I'd given much thought to at that
point.
Jay B
  #70
Old January 25th 06, 05:38 AM posted to rec.aviation.piloting
Default "On the go" (was Round Engines)
We were back in the
touchdown zone.
I've heard this phrase many times, but am curious as to its etymology.
Anybody know where it originated?
Jose
Home Built Aircraft - Alternative Engines - Geo/Suzuki OtisWinslow Home Built 1 October 12th 05 03:55 PM
Book Review: Converting Auto Engines for Experimental Aircraft , Finch Paul Home Built 0 October 18th 04 11:14 PM
P-3C Ditches with Four Engines Out, All Survive! Scet Military Aviation 6 September 27th 04 02:09 AM
Engines and Reliability Dylan Smith Piloting 13 June 30th 04 04:27 PM
Accident Statistics: Certified vs. Non-Certified Engines Ron Wanttaja Home Built 23 January 18th 04 06:36 PM
