#51
heck that sounds like a good idea. wasn't there a time that engineers
would tow a plane behind a ground vehicle to see if it would fly? sounds like a way to avoid risking getting hurt if some design flaw comes up. make sure to sandbag for CG! I don't recall hearing of that, except for launching gliders. But a BD-5 was pushed along on a boom ahead of a pick-up truck as a sort of poor man's true motion simulator. I believe that something similar may have been done with another design as well--possibly one of Rutan's. |
#52
Peter Dohm wrote:
And there are a significant fraction that almost NEVER fly. That "almost" is a real concern. I presume that pilot proficiency is as important as the aircraft. Absolutely, Peter. The smaller machines can be a handful at first. Even when perfectly balanced, they can be very quick to respond. Way much more so than anything built in Wichita or Florida. My parasol, as an example, flies strictly by thought control. (Stole the set-up from the Russians ![]() You only THINK about moving the stick. If you actually MOVE it, you're going for a roller coaster ride! Mind you, it's not unstable, twitchy or anything like that. It's just quick! The control pressure is very light, and the pressure gradient (i.e.: the increase in stick pressure due to control deflection) is less than a pound per G. It's a finger tip airplane. One finger tip on top of the stick. Somebody used to a Cessna or Piper is going to be at a real disadvantage for the first flight(s?). Until they get used to it. Then, the old Cessna suddenly feels like flying a 2-ton dump truck. Richard |
#53
Peter Dohm wrote:
heck that sounds like a good idea. wasn't there a time that engineers would tow a plane behind a ground vehicle to see if it would fly? sounds like a way to avoid risking getting hurt if some design flaw comes up. make sure to sandbag for CG! I don't recall hearing of that, except for launching gliders. But a BD-5 was pushed along on a boom ahead of a pick-up truck as a sort of poor man's true motion simulator. I believe that something similar may have been done with another design as well--possibly one of Rutan's. I got to "fly" that contraption - once. That was enough. It was sorta fun, but with the truck driver manning the "throttle", the limited lateral range, and limited roll range, it was - well - interesting... I heard it was later destroyed by some guy who claimed 10,000 hours of glider time... Richard |
#54
"kd5sak" wrote in message m... Same tactic killed Wiley Post and Will Rogers. Don't fly myself, but in a lifetime of reading I've seen several references to crashes occuring from pilots trying to turn back to a runway when they had a reasonably flat bit of terrain in front of them. It's been said that Post knew better, but had the family fortune tied up in the plane he and Will were traveling in and just let that drive his decision making. What do some of you actual pilots think? Harold KD5SAK It seems to me that when I learned to fly the normal landing was a "power off" landing. You always cut the power on the downwind leg heading away from the airport and from the end of the runway. Then, after a little while, you proceeded to make a 180 degree turn back to the airport and landed. This was done with the engine cut to idle. Sometimes, they cut even beyond idle and quit completely! :-) It was called a normal landing and you were supposed to do all of them that way. Clearly there is some altitude and distance from the end of the runway where a "turnback" type maneuver is no problem at all, and actually closely approximates the normal landing of my youth. Equally clearly there is also some altitude and distance from the end of the runway where such a "turnback" maneuver is clearly impossible. Obviously the trick is knowing exactly where in the range between A and B that you are at the moment the engine quits and behaving accordingly. Most flight instructors cop out totally and just say "Go straight ahead." Personally, I have had engine failures on "takeoff" where straight ahead was best. I have had engine failures on "takeoff" where "turnback" was best. And I even had ONE engine failure on "takeoff" where neither "turnback" nor "straight ahead" would work and I had to do something creative! :-) Highflyer Highflight Aviation Services Pinckneyville Airport ( PJY ) |
#55
"Richard Riley" wrote in message oups.com... There's a difference between a glider with a 30:1 L/D and a Cessna with 9:1. Doing a 180 in a glider from 400' is like doing it in a Cessna from 1200'. Richard, Richard, Richard ... A normal poweroff landing is a 180 back to the field from 800 feet. Cessnas make them quite handily all of the time! :-) Highflyer Highflight Aviation Services Pinckneyville Airport ( PJY ) |
#56
"Jerry Springer" wrote in message ... To the Cessna 172 driver that asked for proof that homebuilt aircraft were safe please post you information saying they are not as safe as any other aircraft flying. I find that is mostly the uniformed that that have a preconceived notion that an aircraft built at home must not be as safe as factory built aircraft. Most homebuilders are very particulier and realize that it is their butts and their families and friends that will be flying in these creations. Jerry(flying my RV-6 over 16 years)Springer As both an FAA Technical Safety Counselor and an EAA Technical Counselor I have inspected a lot of airplanes, both certified and homebuilt. For what it is worth, the average homebuilt is built to a much higher standard than the average certified factory built airplane. I suspect this is due to several factors. First, the type of people who invest the time for both building and for skills acquisition that is required to actually build an airplane are the type of people who are very proud of what they do and how they do it and take the care required to do it both well and right. Secondly, when the guy who built it is also the guy who is going to fly in it, it lends one a certain incentive to avoid cutting corners or making do with something that is a bit less than it really should be! :-) Highflyer Highflight Aviation Services Pinckneyville Airport ( PJY ) |
#57
"Richard Lamb" wrote in message
ink.net... Peter Dohm wrote: heck that sounds like a good idea. wasn't there a time that engineers would tow a plane behind a ground vehicle to see if it would fly? sounds like a way to avoid risking getting hurt if some design flaw comes up. make sure to sandbag for CG! I don't recall hearing of that, except for launching gliders. But a BD-5 was pushed along on a boom ahead of a pick-up truck as a sort of poor man's true motion simulator. I believe that something similar may have been done with another design as well--possibly one of Rutan's. I got to "fly" that contraption - once. That was enough. It was sorta fun, but with the truck driver manning the "throttle", the limited lateral range, and limited roll range, it was - well - interesting... I heard it was later destroyed by some guy who claimed 10,000 hours of glider time... Richard The picture of it that I recall suggested that it might be - well - interesting... Peter |
#58
"John Ammeter" wrote in message ... My "first flight" WAS my second flight... I was "taxi testing" my RV-6 when I became airborne for about a hundred yards or so. Since I was not authorized to commit flight per the FAA obviously I had not flown.... right?? John Sure is funny how often that happens, John. I think taxiing around in a new airplane must really be dangerous! :-) Highflyer Highflight Aviation Services Pinckneyville Airport ( PJY ) |
#59
"Highflyer" wrote in message ... "kd5sak" wrote in message m... Personally, I have had engine failures on "takeoff" where straight ahead was best. I have had engine failures on "takeoff" where "turnback" was best. And I even had ONE engine failure on "takeoff" where neither "turnback" nor "straight ahead" would work and I had to do something creative! :-) Highflyer Highflight Aviation Services Pinckneyville Airport ( PJY ) Hmmm, I imagine one could add a bank left or right and center the bubble, what was the right choice when neither turn back or go straight was correct? You have my curiosity itching something fierce. Harold KD5SAK |
#60
"john smith" wrote in message ... In article , "Peter Dohm" wrote: In any event, we climbed to a little more than 350 feet before I pulled the power to idle; and promptly began my turn back tothe runway. Idle thrust is still quite a bit of applied power. Instead of pulling the throttle (air), pull the mixture (gas). This will give you a windmilling prop with all the associated drag. When you are ready to restore power, push the mixture back in. Try it and see how your results change. I recall pulling the mixture on a newly overhauled A-65 Continental on a little airplane. It had a wooden prop. I pulled the mixture and the prop didn't have enough inertia to overcome the compression on the fresh overhaul and the prop stopped. Since the A-65 doesn't have an electrical starter the only way to get a restart was to get out and flip the prop. It seemed to me that do so would require me to land first! The stopped prop had considerably less drag than the engine at idle. By the way, any multiengine instructor can tell you that an engine at idle has less than nuetral thrust and does NOT contribute any thrust. :-) Highflyer Highflight Aviation Services Pinckneyville Airport ( PJY ) PS: The 10th annual Pinckneyville RAH Flyin is coming up May 19, 20, and 21. Plan now to attend. Send Mary a note at or there may not be enough food for you! :-) |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| Lancaster California: Another Fatal Cirrus Crash | Larry Dighera | Piloting | 63 | March 31st 06 10:34 AM |
| 1 Fatal ...r.a.h or r.a.p? | Montblack | Piloting | 81 | February 12th 06 09:54 AM |
| 1 Fatal ...r.a.h or r.a.p? | Montblack | Piloting | 38 | February 9th 06 03:00 PM |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 02:27 PM |
